Question about Behringer Eurolight Lc2412 Dmx Lighting Console Theater Dj Led Lc 2412
Programing all sliders to run without toggeling between the preset and memory banks
I have all 24 channels programed for dmx. I cant figure out how to use both preset and memory to run without toggeling between the two. In a readout from Behringer it says to to use faders 1 2 and 3 in the A PRESET section to create a stage design with the lights.does this mean to assign dmx to those channels or possibly raise the pre dmxed faders to full on position. then it says to press flash button 1. soft A then quit. Do I follow this procedure through all the faders 1-12? I'm lost.
3 Suggested Answers
  • 5603 Answers
SOURCE: Can the faders on the behringer sl2442 be cleaned
I will give you something to try and beyond that, you have to replace the fader.
Try spraying a LITTLE CRC 226 into the fader slot. Procure this at a Home Depot store in a small blue spray can in the electrical department. (about $2.60) DO NOT USE CONTACT CLEANER such as De-Oxit.
Spray a bit in and see if it improves the situation.
IF NOT what has happened is the sliding fingers have worn through and folded back and dug into the resistance element in the fader. That is fatal!
The faders, once you find the right type are not very expensive say less than $5 BUT there are usually massive number of screws to take out and knobs to remove to get the board out. SOMETIMES the ones you get have to have the "handle" shortened by a quarter inch. Do this with tin snips and clean off burrs with a file.
You need to match the resistance, the hole pattern, AND the "taper" which for those will be an "audio taper" The fader will have a part number on the side and MOST are made by "ALPS". Digikey and Mouser are my usual sources online.
Un-soldering the old fader takes care and solder removal tools. DO NOT force the leads out till the solder is all out and the lead is free. You will lift the circuit traces off the board.
Clean the residue of soldering flux when done and re-assemble.
Posted on Oct 27, 2009
  • 5603 Answers
SOURCE: Hi - I have had
The LED cans are not easily dimmable to very low levels. The signals sent are all digital. It is POSSIBLE that the A channel fader doesn't go low enough electrically within the console and the conversion to the control stream of data is NOT commanding a low enough level. LED's are HARD to dim below a certain point and what would happen is that in the multiple strings of each color, some stings would go completely out before others... SO it is possible they have a minimum SET in the PAR can that is the lowest level that can be done without dropping off some of the internal groups and making a mess of the color. There would be NO solution available to you in this case.
Posted on Jul 08, 2011
Have read instructions, where do I start to set this up?
set a preset, then save on memor- u can save simple preset or multiplus preset on chase mode
Nov 20, 2011 | Behringer Eurolight Lc2412 24channel...
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Jun 29, 2011 | Audio Players & Recorders
Using 24 chauvet par 56 led and chauvet obey 40. when going to bank 5, 6 or even 11, some fixtures will remain on while some will flicker. 2 fixtures per channel on the console. DMX addess starting at 1...
Read about terminating the chain with a resistor 120 ohms. If your run has appreciable length, a termination MAY be necessary to avoid digital reflections that can corrupt the message between the control and the lights. Having separate power sources CAN subject the units to "ground bounce" that can also corrupt the digital control. You need to power all the units from a single source or conditioner if possible. Another solution might be to use one of the DMX radio links which would isolate the ground problem. Another fix you MIGHT try is to get some of the clamsheel ferrite devices that clamp around the wires. Put these around the digital cables, not the power cords:
http://www.google.com/products/catalog?hl=en&sugexp=ldymls&xhr=t&q=ferrite+core&cp=8&bav=on.2,or.r_gc.r_pw.&wrapid=tljp1304006132890014&um=1&ie=UTF-8&cid=761843538070174409&sa=X&ei=-Y25TaXFGsjYiALh_8ky&sqi=2&ved=0CFEQ8wIwAw#
Apr 28, 2011 | Chauvet (4) Chauvet Led Par 56-24c 7...
I can't figure out how to set the radio station pre sets
hi,
there is no auto presetting available. u have to set all channels in preset manually. if u power off the subwoofer all setting will be erased.for manual preset do the following.
1. Press the FUNCTION button to select "TUNER".
2. Press the FM/AM button to select a band.
3. Select the station you want to listen to (Hold down the TUNING Up or Down button until the
frequency display begins to change. When a station is tuned in, the tuning process will stop automatically.)
when it tune the first station available do the following to preset it,
4 .Press the MEMORY button.( on remote)
5. Within 5 seconds, select a preset channel to store the
station using the PRESET buttons of the remote control
unit.
6. Within 5 seconds, press the MEMORY button.(The station is stored and the MEMORY indicator goes off. To store more stations, repeat steps 3 to 6) .
for listening preset ed station ,Press the PRESET button repeatedly until the desired
preset station is found.
ok
Dec 24, 2010 | Teac CD-X9 Shelf System
Don't have a manual or the remote for KLH audio video receiver model r5100. Cannot figure out how to program the presets on the am/fm radio. Can someone tell me how or do I have to have a rermote to...
There should be numbered buttons on the receiver.Set the channel to what you want to preset,then press and hold down the numbered button you want.The sound will probably go away for a couple of seconds but when it comes back on the channel is preset.If you press the band button while you're already on FM and it goes to another FM,you can also preset more channels for FM.There should only be one AM band,then it will switch back to FM.
Good luck! Greg
Aug 10, 2010 | KLH R5100 Receiver
I have an RX-DT680 unit on which i am trying to set the preset FM Stations to and am wondering what I have to do to accomplish this?
1. Select desired channel 2. Press " tuning memory" until "program" flashes 3. Press " preset tuning" up or down to select position 1-10 4. Press " tuning memory" again, flashing " program" disappears 5. Channel is now selected @ position 1-10 6. Find channel @ selected site by pressing "preset tuning" up or down
Oct 02, 2009 | Panasonic Audio Players & Recorders
Diagram
ok i am typeing this right out of the book/
operating your tv: Once you have connected your tv to an anntenna or cable system,plugged the tv in, and put batteries in the remote, you are ready to use the tv. the first thing you should do is program your tv so it memorizes all of available analog& didgital channels.PROGRAMING YOUR TVS CHANNEL MEMORY: your tvs memory determines the channels thet are available using the "up ch down" buttons. if a channel is not in memory . you can tune to it with the numbeer buttons, but not with the up and down buttons . follow these steps to program your tvs memory:
1) Preset
press the MENU button twice to enter preset menu
To memorize all available analog and didgital channels
press the ch down button to highlight FULL SCAN then press VOL.+ to begin channel scaning, the channel scanning starting with analog channels then to didgital channels. after your tv finishes memorizing the channels, it will return to normal tv viewing. I hope that this fixes your problem thats just the main section on the programing part so if you need further info just ask!
May 21, 2008 | Disney DTD1363-CAR 13" TV/DVD
Pioneer projection tv model sd-p404
In menu go to cable/then press auto programming see if this fixes your set.
Dec 06, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Behringer Eurolight Lc2412 Dmx Lighting Console Theater Dj Led Lc 2412 Logo
35 people viewed this question
Top Behringer Computers & Internet Experts
Seanzilla
Brett Duxbury
Brett Duxbury
Are you a Behringer Computer and Internet Expert? Answer questions, earn points and help others
