Question about KitchenAid KGRS807SSS Gas Kitchen Range
Kgrs807 oven won't heat
Oven won't heat, it seems to start but shuts down after a couple of minutes, the oven is cold.
KitchenAid gas convection oven model # kgst307hbl4 won't turn off
seems like the safety switch not work. be careful
Mar 27, 2017 | Ovens
Bosch Axxis WTE86300US turns itself off after ten minutes, won't turn back on for a few minutes after that
I would bet you have a bad sensor. There are a couple of sensors that monitor heat. When it gets too hot they shut it down as a safety precaution. Once it is cool enough it will start up again.
Sep 26, 2012 | Bosch Dryers
Thinkpad A22m 2628-3SU laptop premature shutdown
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
May 18, 2012 | IBM ThinkPad A22m 2628 Notebook
Defrost Cycle Problems with Heat Pump
It's a defrost board issue. The timer on the board or something similar is hanging up. Unfortunately the solution is to replace the board. By lowering the temp. on the T-stat you are resetting the timer on the board. As you see that only works until the next cycle.
Feb 22, 2009 | Weather King 12AJA4801AH Air Conditioner
Cook timer keeps chiming
it starts chiming every min AFTER the timer counts down the allotted time?? thats normal operation its remonding you that the timer has completed cookin and to remove food from oven.. it will continue cooking with residual heat if not removed
Nov 25, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Microwave fuses down when I press start to heat
are you saying the unit go's dead if thats the case there is internal protection shutting it down and some troubleshooting would be required to figure out what is causing it.
Aug 25, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
KitchenAid KGRS807SSS Gas Kitchen Range Logo
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
