Question about Dryers
Maytag code d2 on panal and coin drive William not startg
Display panal only lights on d2 and dryer William not start
  • 1314 Answers
SOURCE: I NEED FAULT CODES FOR DRYERS
PF Power Failure
“PF”
flashes to indicate that a power failure occurred while the dryer was
running. Press START to continue the cycle, or press PAUSE/CANCEL to
clear the display.
F-01 Primary Control Failure “F-01” flashes when there is a primary control failure. Replace the machine
control electronics. See Accessing & Removing the Electronic Assemblies.
F-02 Keypad/User Interface
Failure
“F-02”
flashes when there is a stuck button or user interface mismatch. This
fault code will ONLY appear when in the diagnostic test mode. See TEST #5.
F-22 Exhaust Thermistor Open “F-22” flashes if the thermistor is open. See TEST #3a.
F-23 Exhaust Thermistor Shorted “F-23” flashes if the thermistor has shorted. See TEST #3a.
F-26 Motor Drive System Failure “F-26” flashes if there is a motor drive system failure. See TEST #2.
F-28 Moisture Sensor Open “F-28” flashes if the moisture sensor strip is open. This fault code will ONLY
appear when in the diagnostic test mode. See TEST #4.
F-29 Moisture Sensor Shorted “F-29” flashes if the moisture sensor strip has shorted. This fault code will
ONLY appear when in the diagnostic test mode. See TEST #4.
1M 2M 3M 5M 6M
= Contacts closed
Contacts
Function
Start
Run Red
Lt. Blue
Blue-White (Elec)
White (Gas)
Green-Yellow
Red
Black-White
BLACK
BLUE
WHITE BLUE
WHITE
WHITE
Pluggable Drive Motor Switch Gas Valve - Gas Dryer
Centrifugal Switch (Motor)
Gas Valve this is about close as i can come its matag electronic but not comercial should be about the same software though some where on or in the dryer should be a tech sheet with codes
Posted on May 21, 2008
maklean
  • 1665 Answers
SOURCE: codes for maytag stacked electric coin op dryers
Hi Have a look below
http://outdoorcooking.manualsonline.com/manuals/mfg/maytag/
Posted on May 26, 2008
Illeagle
  • 525 Answers
SOURCE: commercial dryer coin op programming
Below is Maytag's commercial laundry website where you should be able to acquire the information requested.
http://www.maytagcommerciallaundry.com/content.jsp?pageName=CustServ
Posted on Jul 17, 2009
TheMobilian
  • 8220 Answers
SOURCE: Coins stuck in Maytag Atlantis dryer. Could
First unplug the machine. Then remove the door.
You will then be able to remove the "goalpost" front panel. Then you will be able to get the hold down off so you can lift the top. Are the coils inside the drum vanes? Just remove them and dump the coins out and reattach the vanes. A lot of trouble for a few coin. That's the story of my life.
Posted on Apr 18, 2010
richroth
  • 9472 Answers
SOURCE: commercial coin operated dryer program
D2, issues are a common problem with this dryer.
make sure you have 120 volts at terminals L1 + L2.
Shut power to this dryer off (top + bottom) go to the rear/top of this dryer and remove the cover plate and look at the hot and neutral wires and make sure they are correctly secured into the wire nuts.
Other things to try is remove the cover plate from the bottom motor contactor. At start time or when you are having these problems with the dryer push the contactor in manually, does the motor turn? Then its not a electrical problem. If not the then have a electrical problem either inside the dryer or to it.
Posted on Jan 15, 2011
My lg front load dryer lights up with check filter and the flow restricter light comes on too. The dryer won't start to tumble or heat. all clean and no air restiction. ???????
have you cleaned the in side pipes ??? and the output pipes. then make sure as you will then need to press power and select at same time and it should chime then turn off, press power and set settings and should start.
May 19, 2015 | LG Dryers
Panal lights come on and i hit on dryer but does not come on
check belt and if not try new start capacitor on the motor
Jul 23, 2014 | Whirlpool Dryers
Coin operated dryer
replace the belt.
Feb 02, 2014 | Washing Machines
Change the price on maytag top loading washer
Price change for a model MAT12.
Remove the access plate above the coin acceptor with a key. The display should show code 6 and two numbers. Code 6 is the regular cycle and the number of coins required to start. Press the perm press button to advance the number of coins. 06 equals 6 quarters, 08 equals 8 quarters, etc.
Reinstall the access door when finished.
Stephen
Feb 19, 2012 | Maytag MAT12CSD Top-Load Coin Operated...
I have a Kenmore 97284810 gas dryer. I need to take off the front panal to check the ignitor and see if the pilot light comes on. There is an approx. 2' x 10' panal across the bottom of the front, but it...
Use a putty knife & there is 2 clips on the top of the panel in the corners. Use a flash light you will see them. Push on them with your puddy knife as you pry up & down. Look on sears a the pictures & you can see where they are at.
Sep 29, 2010 | Dryers
Maytag MCE8000AZW Neptune Drying Center. Display
my bottom dryer the light dont come on or when i press start it wont start all i hear is a click...any solutions?
Jan 31, 2010 | Maytag Dryers
My tub on my dyer has quit working-where is the belt located and it is hard to change??
first you nead to unplug the dryer.next you nead to remove the lint filter and remove the two screws that are under it.now grab the top on both sides and pull it forward and up.roll top back and let it lay on back wall.look between the drum and the frount panal and remove the two 5/16 screws one on both sides.next pull the frount panal forward 6"and pull up on the frount panal.rotate the frount panal and let it rest on the side of the dryer.you do not nead to remove the wires from the door switch.next look under dryer drum and you should see the old belt.remove the belt.next place the new belt over top of drum,next with your left hand grab the frount top of the drum and lift it about 2"and with your right hand grab the drum belt and feed it under the drum.2/3 the way back.next lay down in frount of dryer and look under the drum.you will see that the idler assembly neads to be reinastaled in the slot in frount of motor.with your right hand hold the idler assembly and with your left hand you nead to feed the drum belt thrugh the idler assembly and over the moter pully.next you nead to replace the frount panal to the two clips one on each side at the bottom.next with your left hand push back on the drum and with your right hand push the frount panal forward and set the drum with the frount panal and replace the two 5/16 screws.next lower the top panal and replace the two screws and the lint filter.plug the dryer in and test unit out.
Jan 21, 2010 | Whirlpool LER4634J Electric Dryer
Model ler8857eqo wont start has powr timer makes clicking sound when timer is turned off start button clicks back out
you nead the unplug the dryer and pull the dryer away from the wall to get to the back panal.next remove the vent hosefrom the dryer.next remove the back panal and the power cord cover.if you look down and to the left you will see a white plastic thermal fuse.remove the wires from the fuse and check that it is closed.if it is open the replace the fuse and reassemble dryer.
Jan 19, 2010 | Whirlpool LER4634J Electric Dryer
The lights on the dryer work it wont start it didnt have any problems drying before this happened no odors or smells i have a maytag MDE5500AYW. please help. thank u
If the display on the dryer reads '88' then place a heating pad over the display. After a few minutes, the '88' code will clear, and it will work fine. Sounds crazy, but works every time for me.
Sep 28, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
Top Dryers Experts
