Question about Lowrance iFINDER H2O C GPS Receiver
My i finder h2oc wil not turn on - Lowrance iFINDER H2O C GPS Receiver
I have lost my webcam 's cd intel CS330...
Don't have the driver, but it should be in the Intel website...
You can also try a driver finder program. Has helped me a lot in the past.
Aug 03, 2010 | Intel Deluxe PC Camera CS330 Webcam
I can not focus the finder scope
Most finders focus by either turning the lens, or the eyepiece portion of the finder. Look through the eyepiece at a distant object and try turning one or the other as described above.
Jan 18, 2010 | Bushnell Deep Space 78-9512 (120 x 60mm)...
Have jus t got the Bushnell 450 and the finder
Many finders need to be FOCUSED! Try turning one of the ends of the finder scope --- to focus the image.
Jan 10, 2010 | Bushnell Optics
MY H2OC LOWRANCE HAND HELD GPS IS LOCKED ON MY LAST POSITION
check the BAUD rate is correct as in the manual
Jul 20, 2009 | GPS
Skil 2100daf angle finder
I was trying to reset the zero on my angle finder. It's a Powerfist Digital Angle Finder, the same as the Skil 2100.
After turning the unit on, if I press the Miter and Hold button together and hold them, the unit goes into 'calibration' mode. (The display flashes 0.0). If you do nothing, it will always stay in this mode forever after that.
You can then reset your unit - it takes time however and patience.
With the aid of a large protractor, draw angles on a large sheet of paper (I used a couple of 11 X 17" pages) from 0 degrees all the way up to 220 degrees.
Turn on your angle finder and make sure the numbers are flashing 0.0. This will be your 0 degree reading. Hold the finder closed and press the Hold button once.
The display will now read 10 degrees. Open up the finder until it matches your 10 degree marks on your paper and press the Hold button again.
The display will now read 20 degrees. Open up the finder until it matches your 20 degree marks and press the Hold button again.
Continue setting your angles in this fashion up 'til you reach 220 degrees. The next button press will close the calibration cycle and the numbers will stop flashing.
Your unit is re-calibrated. Now, if it's off - you've only yourself to blame.
Apr 23, 2009 | Skil 2100DAF Digital Angle Finder
Server2003
No I am sorry you will have to contact Microsoft directly for a cd-key.
Thanks,
Lee
Jul 08, 2008 | Microsoft Windows Server Standard 2003 for...
Lowrance iFinder H2Oc analog speedometer...
I found that it works better to push exit three times from the map view.
Mar 08, 2008 | GPS
New H2O C cannot find any satelites
hi
I have been useing the H2O std unit for about 3 yrs and dont claim to be expert but may be able to help you if your still haveing same problem contact me at randy487vs@yahoo.com
Dec 29, 2007 | Lowrance iFINDER Expedition C GPS...
Lowrance iFINDER  H2O C GPS Receiver Logo
19 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
