Question about Saws
Reciprocating saw manual
How do I change the blade in a Speedway Reciprocating saw?
  • 313 Answers
SOURCE: Dewalt DW303 reciprocating saw
go to www.dewaltservicenet.com look for the icon find it now.enter the model # of the tool & search
Posted on Sep 19, 2008
rowdy45176
  • 2176 Answers
SOURCE: Change blade on Dewalt DC385 XRP reciprocating saw
The button is for changing the shoe position, you should find a lever on the opposite side that you need to lift up on to release the blade. You might be able to get a owners manual at Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number and it will direct you how to download one. Let me know if you need more help
Posted on Mar 22, 2009
SOURCE: Reciprocating saw stops reciprocating
your missing a tooth on a large round gear in the gearbox.
when the gear on the engine rotates into the position where the little engine gear spins because there is no tooth to come into contact with the engine runs but the gearbox doesnt spin, hence no reciprocation, but engine runs.
if you bump the blade it will start going again, but when you cut it will stop offasionally in mid cut. you can repair this but stop using it the engine gear will be destroyed otherwise
I have a dewalt dw303 that you can use for parts, I need a new trigger or something the motor is dead and I found a new saw. go to craigslist.org, rochester ny tools section and look for dewalt dw303 that is my listing. for ten bucks ill sell you all the gears you need. i think it is close to the same model, i am sure it is the same gearbox.
try opening your gearbox, im positive that is what is wrong.
Posted on Apr 23, 2009
rowdy45176
  • 2176 Answers
SOURCE: lubrication and maintenance reciprocal saw DeWalt
Before you attempt any of this I would recommend going to Dewaltservicenet.com and see what the inside of this tool looks like. It appears that you need to remove part of the front gearcase to get into the lube. The back e.g. brushes is not that big of a deal. If there is a Service Center near you they have a Max repair rate that they will fix anything on this saw at a preset firm price and if it is less that is what they would charge.
Posted on May 18, 2009
SOURCE: Blade won't lock.
There is a ball lock in it and you have to twist the ball lock but if the ball lock is frozen generally WD40 will help unfreeze it and work it until the ball is free and should work just fine.
Posted on Jul 22, 2009
How do I remove blade that's broken off in a Skil 9216 reciprocating saw?
Turn the release as far as it will go, then tap on something blade down till it emerges.
Aug 03, 2014 | Skil 9216-01 9.0 Amp Variable Speed...
How to change a dewalt DW317 jigsaw Reciprocating Shaft
You will need to remove the blade holder then the 4 screws that hold the front cover on. You can go to DeWalt's service site using the link below and view or print a parts diagram which will help.
DEWALT ServiceNet
May 24, 2014 | Dewalt DW303 Heavy Duty 65 Amp...
Blade clamp
i purchased a clarke reciprocating saw, and the first time i tightened the blade it broke, where can i get the parts to fix it
Mar 09, 2014 | Clarke Power Products Electronic...
Reciprocating
That sounds dangerous! Does it actually cut after you do that? It sounds like it has bad gears and wouldn't cut if you put pressure to the blade. On a dw303 it's likely not worth repair if that's the case.
Jan 23, 2014 | Dewalt Dw303m Reciprocating Saws
I have a dewalt model dw008 reciprocating saw.while removing a broken blade a small steel ball fell out. #52 in their parts manual.where does it go?
Here is a parts diagram. Item 52 is the ball. It fits behind item 49. Item 49 has a groove machined into it so that when it is moved it allows the ball to move away from the blade far enough to insert the blade. Once the lever is released the ball moves back and locks the blade into place.
DeWalt parts diagram
Jul 20, 2012 | Dewalt DW008 24V XTR Reciprocating Saw...
How do i change blade on dewalt dw303 reciprocating saw
Open the yellow tab on the side of the blade guard and lift the blade out. Install a new on and close the tab. If the blade has been damaged, it may need to be pried off the locating pin at the attachment point.
Aug 08, 2011 | Dewalt DC385B 18v. Cordless Bare...
Cannot put blade into 310 reciprocating saw the instructions in the manual do not make it clear
Point tool away from body.
2. Rotate blade clamp collar (the knurled diamond pattern knob just at the back of where the blade goes) to release position.
3. Insert blade shank from the front.
4. Rotate blade clamp collar to lock blade into position.
May 25, 2011 | Dewalt DW310K Heavy Duty Reciprocating Saw...
How do i intall a blade on a DW303 Reciprocating saw?
To install blade into saw:
1. Loosen set screw.
2. Insert blade shank from the front between the reciprocating shaft and the blade clamp.
Locate hole in blade over pin on reciprocating shaft.
3. Tighten set screw. If the blade should break off and the shank does not come out of the clamp,
be sure the set screw is loose and eject the shank with a nail or pointed object.
May 05, 2011 | Dewalt DW310K Heavy Duty Reciprocating Saw...
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
