Question about RTO Ho Herpa Freightliner Truck Tractor
WHAT DOSE THE CODE EEC 71 ON A FREIGHTLINER MEAN
2 Suggested Answers
emissionwiz
  • 79186 Answers
SOURCE: what does the code eec 61 on a freightliner mean
A check engine light and fault 61 code is an electrical failure to the injector or a bad solenoid on the injector, but you will most likely find your problem at the terminal crimp.
Posted on Nov 11, 2011
I have a 2013 freightliner. . Cummings eng.. code eng 0... what would this mean?
You would need to contact a Freightliner dealer on this.
May 24, 2017 | Cars & Trucks
Freightliner code 128 s254 07
on 2006 freightliner century with 12.7 detroit 60 Error code
eng contreller no resp. 128s254 07.
Apr 26, 2012 | RTO Ho Herpa Freightliner Truck Tractor
What does the code eec 61 on a freightliner mean
Nov 11, 2011 | RTO Ho Herpa Freightliner Truck Tractor
What does check dcl mean
DCL is Data Communincations Link... the communication connection between the computers in the instrument cluster and the rest of the car. its usually caused (99% of the time) by a bad connection.
The Data Communications Link (DCL) is a wiring system that allows the sharing of information between the Electronic Engine Control System (EEC-IV) , the Electronic Instrument Cluster (EIC) and external equipment.
The EEC-IV system transmits the following information through the DCL to the EIC:
Engine RPM.
Engine coolant temperature.
EEC-IV malfunction indication.
Fuel used.
The DCL system transmits Malfunction Indicator Lamp (MIL) information to the EIC. The EIC uses MIL information to generate a CHECK ENGINE warning in the event of an engine sensor failure.
The EIC will display the message "CHECK DCL" on its Message Center Display if it is not receiving data from the EEC-IV. This warning is turned off whenever data communication is restored.
The EEC-IV monitors the Data Communication Link for faults. If a fault occurs in data communication a continuous Memory Code is set in the EEC-IV. The DCL Codes (529 for EEC-IV and 533 for EIC) can occur separately or together. These codes are not immediately cleared when data communication is restored.
The existance of a DCL code does NOT mean that a module has failed. also I would check for an oil leak or coolant leak that would be the cause of the smoking under the car.
Check this link for some help on fixing it: http://www.lincolnsonline.com/tech/00086.html
Hope helps.
Sep 11, 2011 | 1993 Lincoln Continental
Active faults 1 at startup screen
if you press and hold the mode button it should beep then you will get the component location. ecu 128 for example is in the engine- mid 136 is the abs. once you see that, press the mode button again and you will get the code. sid 123 for example- press mode button again and you will get the failure code. FL 02, could indicate when it is reading a high or low reading, short or open... etc. once you have the three parts of this code then you should be able to contact your local dealer to find out what the code means. Truck diagnostics are not always easy... active codes really just give technicians a place to start... hope this helps
Dec 16, 2009 | RTO Ho Herpa Freightliner Truck Tractor
Home cinema sony dav f200 error cde c:13:71
ive got a sony dav f200 home cinema system,it lets me play music cds but trying to play dvds(not copied or american) it comes up with and error code c:13:71. what does it mean?
Mar 14, 2009 | Sony Televison & Video
Brother 4100 fax error code # 71
Error 71 is a laser scanner error.
Inkworks
866-381-0541
Nov 19, 2008 | Brother IntelliFAX 4100 Laser Fax
RTO Ho Herpa Freightliner Truck Tractor Logo
51 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
