Question about Kenmore Dehumidifiers
Just purchases a kenmore dehumidifier and appears to work, but the bucket is completely dry.
  • Kenmore Master
  • 2,760 Answers
Ck your settings on control panel , lots of times they set the set point high at factory so it wont turn its self on to remove water . also ck your rooms available humidity level sometimes there's not enough water in air for one to remove much
Posted on Jun 06, 2015
SOURCE: Kenmore 580-51650000 dehumidifier
It is more than likely the compressor is not running, only the fan.
It seams that the humidity sensor is flaky on these units. You can,
operate the unit, by opening up the dehumidifier and unplug the sensor from the main board. The unit will cycle on and off and remove the water from the air.....good luck
Posted on Apr 21, 2008
SOURCE: Dehumidifier Error?
This error code indicates that the problem is most likely a shorted defrost thermistor or possibly a pinched wire going to the thermistor. You will need to replace the sensor assembly - part # 6877A30013L. The Sears website has it listed for 9.99 + shipping. The humidity sensor & defrost thermistor come together in a wiring harness that plugs onto the main circuit board. It is fairly simple to repair. Just remove the front & rear grill & the metal cabinet. Remove the thermistor from the copper tube on the cooling lines; remove the humidity sensor from the front of the evaporator; pull the wire plug off the bucket switch; & remove the small 7 pin plug from the main circuit board inside the metal control box. Reverse procedure to install new sensor assembly.
Posted on Nov 13, 2008
  • 11 Answers
SOURCE: Kenmore 54501
Normal 0 When you push the power button, the blower fan comes on. In a few minutes you should hear a second "click"--that is your compressor starting. Do you hear that second click?
Posted on May 29, 2009
  • 51 Answers
SOURCE: Kenmore 54501 Dehumidifier no water in bucket
may have lost ref charge check name plate for type of ref with 12 and 22 cost of gas cost proh. check tubing in rear should be ice cold to gather condensate if not probably lost gas
Posted on Aug 09, 2009
heatman101
  • 43501 Answers
SOURCE: 54501 Kenmore Dehumidifier. It
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Sep 07, 2011
Kenmore 54351 Dehumidifier is leaking -- water isn't going into the tray, but seems to be leaking out into the floor.
Mine is doing the same thing. The bucket is dry and the floor is flooded, so it is not an inability to condense, and it is not that the bucket has overflowed, and the bucket does not have a leak. It had been working great and then this suddenly started happening, it's as if the water is not flowing along the proper route and instead is gathering behind the bucket.
Nov 27, 2012 | Kenmore 54351 Dehumidifier
The dehumidifier runs, but does not collect water in its reservoir. (the lights all light up, it cycles on and off, but all it appears to be doing is running the motor - not actually functioning.) And,...
heatman101
Jun 22, 2011 | Kenmore 54701 Dehumidifier
My dehumidifier is two years old and only used during the summer months. This season it is running but not removing moisture from the air...the collection bucket is completely dry. Help!
heatman101
Jun 06, 2011 | Haier 45-Pint Dehumidifier
Kenmore dehumidifier # 54501.. Will not start..."01" comes up in the screen and the "full bucket" red light flashes on and off, but it is empty. put the bucket in and out many times but still will not...
According to this, a user was able to remedy the error by replacing the sensor assembly. Unfortunately, I have no idea how to do this, and I cannot direct you to a place to purchase a new part, so you may be better off getting it repaired at a local Sears retailer.
Aug 03, 2010 | Kenmore 54501 Dehumidifier
Danby DDR6009RRE dehumidifier bucket switch operation question.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 27, 2010 | Danby DDR6009REE Dehumidifier
Dehumdifier won't drain
You just need to get the water flowing and start the siphoning process by taking out the water bucket while it's full of water and raising it up high enough to start the water flowing. Once the water starts flowing, you can put the bucket back and the water will keep flowing (by capillary action). If the bucket empties completely, you may have to do it again periodically to get the water flowing again.
Sep 17, 2008 | Kenmore 54701 Dehumidifier
Hopper not seated right
I had the same problem with my Kenmore dehumidifier. The bucket couldn't be properly seated because the plastic cracked slightly at the site where the bucket normally is held. Because of this, the button that it is supposed to be pushed in to keep the dehumidifier running wasn't pushed in all the way. A friend has a Kenmore with the exact same bucket- tried hers, and it works perfectly.
The problem I have now is that I can't find the bucket for sale.
Jun 24, 2008 | Kenmore 5230 Dehumidifier
No water in bucket
possible that the cooling fins have frosted over...this happens when a cold surface appears in a humid room that does not have enough heat to prevent the freeze-up on the fins. If you look at the fins (above the water bucket), you may see the frost. One solution is to turn up heat in room, followed by placing a fan to blow air through fins if still frosted. If you do not have a frost problem, then ensure compressor is running. If comp is running, then return dead unit.
Feb 16, 2008 | Kenmore 53301 Dehumidifier
Dehumidifiers Logo
216 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
