Question about Moen Home
Shower hard to turn to off position
MoenT2152Single Handle Posi-Temp Pressure Balanced Shower Trim with Single Function Showerhead from the Brantford Collection
    Novelist:
    Champion:
  • 227 Answers
It sounds like you have something jammed within the cartridge. You can either remove the cartridge and flush line and reinstall it or just buy a new cartridge and replace the old one. The cartridge you need is a number 1222 mowing positive cartridge. Here are instructions to change the cartridge. MOEN CARTRIDGE REPLACEMENT
There are two different types of Moen cartridge for a single handle valve. The first and most common one is the plastic 1225 cartridge that is used for all Moen single handle valves that are not posi-temp shower valves. This cartridge also comes in brass which is number 1200, but it is more expensive and doesn't last any longer or work any better than the plastic cartridge. The posi temp cartridge is a number 1222. This is the replacement cartridge for shower valves that you turn rather than pull. As you turn the valve it goes from cold to warm to eventually hot. The tools needed for this procedure are pliers, Phillips screwdriver, a small flat screwdriver or awl, a 3/4 inch copper cleaning brush, silicone or heat proof grease, a knife to pull the cap on an acrylic handle, or a 7/64 inch Allen key to remove lever handle.
If it is an acrylic handle simply pry off the cap and unscrew the screw with a Phillips screwdriver. If it is a lever handle there is a set screw which is 7/64 of an inch. Use an Allen key to remove this set screw. If it is a lever handle when the handle is removed you must use a Phillips screwdriver to remove the handle adapter.
Before removing the cartridge make sure that the water is turned off and open the valve to bleed off the pressure. Leave the valve in the open position as it will facilitate the removal of the cartridge if the spindle is in the open position. It can be turned off at the main which is usually the easiest thing to do, or you can remove the faceplate and there may be integral stops behind the faceplate. Use the integral stops if your water main is hard to reach. On the brass spindle of the cartridge there is a notch on one side. Before you remove the cartridge take note of what position this notch is in because that is the position in which the cartridge will be placed. Do not forget this step as a posi temp cartridge will not function properly if installed with the notch in the wrong place. If you install the regular cartridge with the notch in the wrong place, hot and cold will be reversed. Simply remove the handle and spin the spindle 180°.
Pull off the chrome stop tube that encloses the cartridge. There is a horseshoe-shaped retainer clip that must be removed. Use the small screwdriver or all to pry up the top of the retainer clip. A plastic square head removal tool comes with the cartridge that you have purchased. Place this on the cartridge and spend back and forth to loosen the cartridge. Then take your pliers pull the brass spindle straight back towards you. If this proves too difficult and you are unable to pull it out you will have to buy a Moen cartridge pulling tool. Be sure to buy the right tool as they are not interchangeable. The posi temp tool is much fatter than the regular tool. The tool operates the same way a hub puller. Back off the knot on the tool as well as the screw. Place over the cartridge and advance the screw all the way. Now advance the nut.
After the cartridge is removed take the 3/4 inch copper cleaning brush and insert into the cartridge housing while spinning clockwise. When removing the brush also keep spinning it clockwise. After brushing, open the water main for about three seconds to flush the line out.
When installing the cartridge make sure that your notch is aligned properly and that the cartridge is pushed in all the way and that the two tabs on the cartridge are aligned vertically. Install the retainer clip. If it doesn't go in all the way either the cartridge has not been pushed in foreign off or the two tabs are not aligned properly. You can use the plastic tool to align the tabs properly and to help push in the cartridge all the way. Reassemble faceplate and handle and you are done.
Posted on Jul 19, 2016
3 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: Removing flow restrictor from Moen Brantford posi-temp shower he
How I remove them is take a drywall screw and screw in to the flow restrictor. Then grab it with a pair of pliers and pull out.
Posted on May 16, 2010
  • 1015 Answers
SOURCE: Low hot water pressure on
I think you are on the right track. The first thing I would do is change the cartridge. While you have the valve apart examine the inlet ports as good as you can to see if there is any mineral buildup. You can use a short length of a small gauge mallable wire to run into water ports to se if you can break anything loose. Another thing you can do is to turn supply stop on slightly while you have the valve disassembled to wash any particles out. Hope this helps you and thanks.
Posted on May 14, 2011
My single moen posi temp shower knob wil not completely turn off my water. In the closed position it still runs a slow stream of water.
Remove the handle and see if it will turn off without the handle and if it will reposition the handle alignment and your good to go. If no the cartridge will need to be replaced.
Feb 12, 2011 | Moen & Posi-Temp Single Handle Shower Or...
May 16, 2010 | Moen T2153BN Brushed Nickel Brantford...
Low water pressure. New installation, replacement
posi temp's usually have shut off valve's to the left and right of center.remove trim plate and check,make sure they are turned full on.i am pretty sure they are quarter turn type,and they have a screw driver slot,when there horizontal they should be fully open
May 09, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Moen L3175 faucet with low water pressure
IS THIS A SHOWER ONLY? IF SO ,I WOULD REMOVE THE SHOWER HEAD FIRST THEN TURN YOUR WATER ON.THE HEAD JUST MIGHT NEED TO BE CLEANED AFTER 11 YEARS.
May 10, 2010 | Moen L3175 Chrome Legend Single Handle...
My shower has been leaking for months. someone
turn the water off to the shower,sometimes you must shut down the whole house at the main ,near the water meter,then take the handle off slide the clip in front up and out then pull posi-temp straight out.replace posi-temp in reverse order.be mindful of the H/C indicator on posi-temp this will ensure you have hot and cold on right sides,if reversed just flip posi-temp.
Jul 08, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Need a shower valve replacement cartridge
I found the cartridge at globeunion [nooutgoing@email.com], 888-328-2383. They told me they are shipping the cartridge to me today at no cost ("lifetime warranty") and they immediately emailed a part diagram of the whole Fontaine NF-VCTST-BNV-TSRVH Single Handle Pressure Balanced Tub and Shower Trim and Valve with Rain Showerhead (from the Monaco Series).
Larry
Jan 29, 2009 | Fontaine NF-VCTST-BNV-TSRVH Brushed Nickel...
Moen single handle valve tub/shower
The Moen Posi-Temp Valve is a pressure balanced valve and when not used for long periods of time they can stick causing only cold or hot water to pass through the valve.
A New Posi-temp cartridges can be purchased at most plumbing supply houses or big box outlets such as Lowes or Home Depot.
As long as you had cold water before, a new cartridge will solve the problem. In the future it would be wise to occassionally operate the valve at least a couple of times a month in order to keep the pressure assembly from becoming lodged in position. Just follow the instructions included with the new cartridge on the proper removal of the old cartridge and the installation of the new cartridge. a little silicone grease inside of the valve before installing the new cartridge will also help.
Be sure that there is no particles of the old cartridge left in the valve.
sanray
Dec 27, 2008 | Moen & Posi-Temp Single Handle Shower Or...
Home Logo
324 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
