Question about Hotpoint Dryers
Hopoint dryer model hbxr453ev1ww squeaks and has a grinding noise when drying
Squeaks and metal on metal grinding noise
  • 146 Answers
SOURCE: Loud Squeaking Noise kenmore gas dryer 80 series
You need to change your drum rollers. To get to them you take the dryer apart from the front not the back. There are 2 screws where the filter goes in on top. Then pull the top toward you and up. Then remove the 2 - 5/16 inch screws on each side of the front panel about 2 to 3 inches down. Then pull the front up and out. Then you will see everything. Replace the belt, drum rollers, and idler making sure to oil each as you re-install them. Then put back together and your on your way.
Posted on Dec 21, 2007
docjohn174
  • 943 Answers
SOURCE: Kenmore 80 series dryer.
thanks for the question The noise might seem like its from the front but theres nothing at the front Now at the back you have 2 drum kollers By the motor you have aidler pully most times the idler is the problem you can buy a repair kit that comes with all the parts you need to fix noise belt , 2 drum rollers and idler pulley .replace them all . Thanks for the question The appliance doc
Posted on Sep 11, 2008
dragonsthatk
  • 547 Answers
SOURCE: GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
Posted on May 17, 2009
SOURCE: Squeak when running the dryer
It's the roller axles and/or the motor shaft. Remove the front of the dryer and lubricate same.
Posted on May 27, 2009
hunter19_46m
  • 7482 Answers
SOURCE: grinding noise in Maytag dryer
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS Your problem sounds like drum rollers have flat spots on them or in need of lubrication.If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Posted on Mar 03, 2010
My dryer is making a very loud squeaking noise. Still dries okay.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 03, 2011 | Dryers
When the dryer gets hot, the tumbler begins to make a continous squeaking noise as if there is metal to metal; not a grinding noise. If you allow it to cool down and restart, it doesn't start until it...
Well ya never mention in your question what brand you have but a GE or Hotpoint dryer has a small plastic insert that wears thin over time. It begins to do a squeak squeak squeak type of noise.And that noise is intermittent, on a Frigidaire model the noise would start out low and gradually get worse. The bearing sometimes gets so bad it gets chopped off and the tub falls into the heating element.
Jun 30, 2011 | Dryers
My Maytag dryer model # LSG7804AAE is making a lot of noise when drying. It is squeaking and if I turn the tumbler by hand it seems very stiff and feels like it is rubbing against something. Thankyou.
heatman101
Asker
Jan 26, 2011 | Maytag Dryers
Kenmore dryer, model 417.84052500 make a very loud noise like metal on metal when it runs...gets worse the longer it runs
heatman101
Asker
Jan 04, 2011 | Dryers
My dryer GLEQ642AS makes a screeching sound, much like metal on metal, when running, but it still dries the clothes. Could a bearing need replacing? It is just 5 years old, but dries 2 loads daily. If the...
heatman101
Nov 30, 2010 | Dryers
GE Model DDE7200RALWH squeaks like a metal on metal sound.
heatman101
Nov 24, 2010 | GE DBSR453EBWW Electric Dryer
I have a maytag dryer model MDE3757AYW that is making a loud squeaking/sqealing noise. the drum still turns and dries the clothes though.
heatman101
Oct 02, 2010 | Maytag Dryers
I have a dryer model # DWSR483EB1WW (General Electric) that squeaks really badly. It almost sounds like metal rubbing metal, what could it be?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 06, 2010 | GE DWSR463EGWW Electric Dryer
The dryer squeals extremely loud when drying. It sounds like metal scraping against metal.It appears the drum may be rubbing against something. I have lubricated all moving parts.
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 27, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
14 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
