Question about Sharp ER-A320 Cash Register
Register wont stop feeding paper/running when its on, it just keeps printing out 0.000
Sharp era420 not printing on left side
If its feeding paper but not printing, make sure that you are using the correct thermal paper and that there is no extra bits of paper stuck under the printing head. Otherwise it might need a replacement printing head. If its not feeding the paper at all, then make sure that the receipt is turned on.
Mar 18, 2014 | Sharp Retail Supplies
Wont stop paper feeding
Check the Remaining Print Jobs in your PC and Delete ALL OF THEM
Feb 28, 2014 | Brother HL-2240 Monochrome Laser Printer
Sharp xe-a506 cash register wont print after paper change
If you see "HEAD UP" or "PAPER EMPTY" on display, make sure the head lever on the side of the printer is locked in closed position and press CL (clear) button.
If the paper is feeding out blank, make sure you have the shiny side of the paper facing the front of the machine - if no shiny side to paper, you have wrong paper.
If that doesn't fix it, please let me know which side is having the trouble (receipt or journal) and whether the paper is feeding or if you have an error message.
Nov 02, 2011 | Sharp XE-A402 Electronic Cash Register
Same problem. Printer runs but wont feed in any
observe if pick up mechanism function as when you send printing job. if yes, may pick up roller already worn out and need replacement.
Jun 02, 2010 | HP Officejet 5510 All-In-One Thermal...
I bought a printer from Btother MFC3360C. The paper didn't feed. I attempted many times to get it to work by trying to print some things. I finally fixed the paper problem and the damn thing starts pr
those buttons dont stop whats in the queue. You need to go to your printer icon, right click and select the first tab on the list, from there, you will see all the files being dumped to the printer, right click file and select delete, this will erase everything in the buffer.
thanks adi
Apr 24, 2009 | Office Equipment & Supplies
I can only print by manually feeding in each page -HP 4MV Printer
Good old 4MV.
paper jam is just the way the printer i stelling you "something" wrong with paper feed".
you need to locate a "4MV repair kit" , they are not cheap. but, if you wan to keep the printer, it is worth it.
http://www.fixyourownprinter.com/kits/hp/K78 cost of the ket is $50
includes Instruction CD rollers, and other repairable parts.
Dec 15, 2008 | HP LaserJet 4mv Printer
The paper feed wont stop
the paper picking rollers i think r weak try cleaning the rollers n try it again.
thank u
May 26, 2008 | Canon SmartBase MP730 All-In-One InkJet...
Tape wont register on this after we changed the tape
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
mechanism.
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
Dec 07, 2007 | Sharp EL-2196BL Calculator
FINISHER PROBLEMS
firstly you have to check what teh copier is set on i.e tray1 or tray2 , select one of the trays,and try to print this should work if , otherwise place the paper on bypass tray right hand side try this, somtimes the sensors are displaced which detect paper, try this and let me know.
Aug 15, 2007 | Toshiba e-Studio65 Copier
Sharp ER-A320 Cash Register Logo
Top Sharp Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
