Ms-7352 cpu fan is not detected
Fan is not detected
3 Suggested Answers
  • 117 Answers
SOURCE: how can I upgrade the cpu for the ms 7352 V1.0
Check your documentation that came with the motherboard or computer.. Go to the computer web site for more info or call tech support for the computer or motherboard.
Posted on Mar 25, 2012
  • 3799 Answers
SOURCE: I would like to upgrade the CPU for an HP DX7400 using mobo MS-7352 v1.0. What is best CPU to use for upgrade please?
go to this site and pick one that is better that whatever one you have( can't tell you what is an upgrade as you haven't said what CPU you have.)
http://h18000.www1.hp.com/products/quickspecs/12764_div/12764_div.HTML
Posted on Mar 31, 2012
Intel ms 7352
check your ram slots and the video card try other video card and make sure that you had turned on the printer as well see if the power cord for the printer is plugin i have done that as well was unpluged
Mar 05, 2014 | Computers & Internet
N 1996 ms 7352 driver
ms-7352 ver. 1.0 lan setup download for window xp
Feb 12, 2014 | MSI K9VGM-V Motherboard
My msi ms - 7352 ver :1.0 won't display but wen i plug the power cable on the power supply the cpu fan and power supply fan spin but wen i turn the pc on it doesn't display
Auto power on the mother board means there was not found RAM or VGA adapter. If you herd Beep tones
follow this link to identify the error
https://forum-en.msi.com/faq/article/bios-beep-codes
if not pls check the power supply 4pin connector correctly plugged .
Also need to check the cpu and post error codes by post diagnostic card to identify the eror.
Oct 24, 2013 | Computers & Internet
MS-7297 Ver 2.1 Not booting: system fan not detected. I've bought in ebay a working msi mobo (so vendor says it works) that I can't boot because a message saying system fan not detected (bios...
you need the right heat sink for the cpu that you are using for the board check on board for cpu plug in, then plug the fan in make sure that you have enought heatsink paste on cpu not to much just enought to do the job. if that dose not do it then the board is bad.
Sep 24, 2013 | MSI Computers & Internet
System fan cannot be detected in MS 7352 V1.0
Hello here is the homepage:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3459272&prodTypeId=12454&prodSeriesId=3459270&swLang=13&taskId=135&swEnvOID=1093
The bios is set to give a warning when the system fan is not working or goes dead (in this case it probably isn't detected or has gone out). You should be able to get into your bios and look for items such as "processor fan warning: on/off" "system fan warning: on/off...etc. If you turn the system fan warning to off it will resolve the problem you are having. The fan for the cpu, must be connected to the CPU_FAN connector on the mainboard.
If the problem is still there, replace the fan, and renew the thermal paste, between the cpu and the cooling element.
Clean also the pc out for dust, with compressed air.
BE CAREFULL when you work on the mainboard, and please take antistatic precautions.
Visit also a computer repair shop, if working on the mainboard is unfamiliar to you.
Good luck
Jan 19, 2013 | Intel Computers & Internet
Mar 31, 2012 | MSI Computers & Internet
How can I upgrade the cpu for the ms 7352 V1.0
Mar 25, 2012 | Computers & Internet
My hp clj 2600n printer wont stop reading initialzimg on control panel machine not spinning
This is the Power On Sequence
Power-on sequence
The power-on sequence is for the purpose of the printer initialization and checking for possible malfunctions.
The following is the sequence from when the printer is turned on until it enters STBY mode.
  1. Power on
  2. Central processing unit (CPU) initialization
  3. ASIC initialization
  4. Video interface communication start
  5. Residual paper check by each sensor signalling paper presence
  6. Initial drive for main motor, pickup motor, and fuser/delivery motor
  7. Fuser heater initial drive by controlling fuser temperature targeting for 100°?C
  8. Initial drive for scanner motor
  9. Failure/Abnormality check
    • Detect scanner failure
    • Fuser failure
    • Door open during the above periods
  10. Communication with memory tag
  11. Cartridge presence detection
Main motor failure detection
The CPU determines the main motor failure, stops the printer, and notifies the formatter of error
status, when it encounters the following conditions.
  1. Main motor start-up abnormality.
The interval of the MAIN MOTOR SPEED DETECTION signal (/MAINMFG) does not become the specified interval after 1000 ms of the main motor drive start.
  1. Main motor rotation abnormality. The interval of the /MAINMFG signal stays at an irregular interval for 100 ms and longer after once it has become the specified interval.
Fan motor failure detection
The CPU determines the fan motor failure and notifies the formatter when it encounters the following
condition.
The FAN LOCK signal (FANLCK) is “H” for approximately 10 seconds and longer during fan motor
rotation.
Your description makes it sound as though the printer has a main CPU failure as all other faults should display an error or error code. In the light of this it seems that the printer will need to be looked at by a service engineer asap.
Sep 21, 2009 | Office Equipment & Supplies
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
