I cannot get a signal, how do i do it/
I have a an Ikasu tv. I have been trying to get a signal but to no avail. It may have been caused by the bad weather we have had. Can you help me please?TFT Colour DVB/VGA/MOnitor tv
DR NITIN
  • 221 Answers
SOURCE: vga drivers for hp laptop
It's not possible to connect your Monitor to the Laptop as the Pre Installed LCD Pannel of the Laptop reserves the Resources for Display Unit.
For more information on this, you may contact HP Customer care.
Goto www.sahajayoga.org to attain your Self Realization and find a Sahaja Yoga Center to goto.
Posted on Jun 22, 2008
  • 9 Answers
SOURCE: problems connecting my acer laptop with tv
Sound and picture are two seperate things unless you use an HDMI cable so lets just deal with the picture first
After you do the connection, you need to tell your laptop to present the picture to the TV.
1- On your keyboard, one of your function keys (F1, F2 etc.) will have a short cut for this as a secondary functionality. Check for the function key that has an icon on it that looks like a screen (usually it is f4 or f7). Then hit the key that activates  your secondary functions and the key you just identified. This should activate the VGA output and in most cases will also give you a configruation screen (where you can select it as a secondary display, dual display etc.)
If this short cut doesnt work, you can try this
2- Make sure VGA cable is connected on both ends. Right click your desktop on the computer and select "Properties". On the new dialog, select the last tab "Settings". Click the drop down box under "Display" and you should see the TV as the secon option, select it. Then select the check box that says "Extend my display...", click Apply and OK. This should expand your screen to the TV, you should now be able to drag windows from your laptop's screen to your TV's.
Good luck! (Instructions on option 2 are for XP, if you use Vista let me know and I will look up the terminology for that)
Posted on Oct 31, 2008
  • 40 Answers
SOURCE: No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Posted on Jul 31, 2009
SOURCE: NO SOFTWARE FOR IKASU USB TV TUNER
i have a ikasu usb digital tv tuner and no software
Posted on Mar 01, 2010
bshldn
  • 736 Answers
SOURCE: I have an Element 32
When you are using a laptop you have to press and hold down the function key and hold down the dual monitor key (either F5 of F8) for about 15 full seconds. The screen of your laptop should darken and the image should come up on the tv screen.
Posted on May 06, 2010
Can any1 help with my ikasu tv remote code
http://www.rockabilly.net/files/manuals/URC-7740.pdf
Download the manual and if your model is not listed follow the section called search method and the set will do it for you.
Let me know if this helps.
May 02, 2014 | Supersonic Televison & Video
Jvc 32
What is the exact model of your TV?
Apr 19, 2008 | Televison & Video
Ikasu tv, replacement remote control
Go to http://www.ebay.com
type Ikasu Remote Control and click the search button
Mar 05, 2014 | Computers & Internet
Our toshiba rezga 47lz196 colour is off. There doesn't seem to be any red. All the skin tones are green. Blue shows up but all the other primary's are green. We have green, blue, yellowish, black and...
There are only two possibilities for this problems for this tv.One: the tv incomming broadcasting signal cable wire that is plugging into ur tv Tuner signal board could be bad.U can test this out the incomming broadcasting signal cable wire is good or bad pretty easily by just plug it into another tv to find out the incomming signal cable wire is bad or good.Two: If the tv incomming broadcasting signal cable wire is good by plug it into a another tv.Than ur tv the tv Tuner signal board is the causes and the problems.The tv Tuner signal board CPU chip is bad.U can do some mechanical work like take things aparts and putting it back together again?Yes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Apr 27, 2011 | Toshiba 47LZ196 47 in. HDTV LCD Television
We have a LG42lx6500. when you turn it on after being off for a few hours the picture colour is distorted for a couple of minutes before correcting. At times you can see the individual pixels. Sometimes...
Hello
Make sure TV is on the correct channel or input. Check the cables for correct routing from TV to any other devices. Check cables to ensure they are tight and secure.
An analog signal converted to high defintion resolution will cause lines, blurriness or fuzziness in the picture. Change the resolution to a lower or native setting using the media device (cable box, DVD,). This may be an issue that requires a service call to cable provider.
A problem on one channel may just be a error on that channel. If using an antenna, it might need to be adjusted in order to ensure good signal strength. For digtal channels, go into TV Menu. Check the DTV signal. Weak signal can cause picture distortion.
If another device is being used such as a cable box, DVD player or VCR switch between devices and test picture. Check routing of cables that are used to control the image. This should be a series of red, white and yellow cables.
If a VCR with a cable box, make sure the VCR and TV are set to the correct channels for video signal to pass through. If problem is still occuring, try another set of cables. bad cables can cause picture distortion.
Bad cables can cause picture distortion as well. Try another set of cables. If picture is better than when using the cables replaced, this was the issue. If cables are not an issue TV may require service.
Apr 26, 2011 | LG Televison & Video
Need pin no. to reset Ikasu KVT910A factory settings
Try default PIN of 136852 - good luck!!!
Jan 30, 2010 | Televison & Video
I have just brought a Ikasu f8l 904 but it has come without a manual does anyone know where I can get one so I can set up my tv.
If you just go to google and put in, manual for a Ikasu f8l 904, it gives you various options a few of then are so you can download the manual.
Dec 29, 2009 | Televison & Video
Mar 13, 2009 | Computers & Internet
Drivers for ikasu webcam
I had this problem, I found the drivers to my webcam at http://www.fascin8.co.uk
Apr 10, 2008 | Microsoft Office Outlook 2003 for PC
Computers & Internet Logo
David Payne
David Payne
