Question about Brookstone Home
Towel Warmer does not turn on
I tried the reset button; I know the outlet is live. Warmer has worked well for more than a year. The power button seems to be depressed, thus making it unable to turn on.
SYSTEMWORM
  • 6 Answers
SOURCE: Satellite R10 Wont turn on
clean off the heatsink and CPU fan.
Posted on Feb 25, 2008
SOURCE: PDA would not turn on...
hard reset the pda (poke the little hole on the back with a ball pen or something), it should boot up, on the bootup screen, it prompts if you want to reset to factory setting, answer no. lastly reset time when you get in.
Posted on Mar 19, 2008
SOURCE: Magellan Maestro 4250 GPS Power Failure
Hi guys. No need to panic. I thought I had the same problem when I got mine but actually there is no problem. Somehow, the off-on switch on the system is kind of funny. U really have to have small finger and depress the switch as far as u can until the system comes on. Might not be the fix you're looking for but give it a try anyway. Nothing to lose. Good luck.
Posted on Aug 20, 2008
  • 2712 Answers
SOURCE: Towel Warmer Troubleshooting
The towel warmers are designed to stay on at a relatively constant temperature to keep your bathrobes and towels fresh, warm and dry. However, should you need to turn the unit off for any reason, usually every towel warmer have an on/off button.
Posted on Aug 27, 2008
  • 10865 Answers
SOURCE: New Warmrails Towel Warmer Stopped heating
call the company directly at 877-927-6724. Explain the problem and they will assist you or replace your unit.
Posted on Feb 19, 2009
No power, when I turn the switch on, the power lights do not display
Look on the back for a reset button, it could be a small red button the size of pencil lead protruding slightly, push in on it. It could also be located in side a small hole the same size use a tooth pick or something none metallic to push with...
Jan 09, 2014 | Precor EFX 556 Elliptical
I have a canon pixma 160 printer where it continually says "no ink" for both colour & black ink with either new original and or new compatible cartridges. the printer keeps showing 5...
Folow this procedure, let me know if there are any questions.
1. Turn off the printer (but make sure power cable is plugged in wall outlet).
2. Press and hold down the Stop/Reset button
3. While holding the Stop/Reset button, press and hold down Power button.
4. While holding down the Power button, release the Stop/Reset button.
5. While still holding the Power button, press the Stop/Reset button twice.
6. Now release the Power button.. (wait until it display "service mode")
7. Press the Stop/Reset button (4 times to clear waste ink; 8times to reset ink level)
8. Turn off the printer
When you turn on the printer, it will work again.
Jan 15, 2011 | Computers & Internet
Stuck on menu screen
Try connecting the TV directly to a different wall outlet and check. Try resetting the TV to the factory settings. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 26, 2010 | Philips 42PF9431D/37 TV
We have a Haier HWfo5xc7-2 air conditioner. Today, when I went to turn it on, there's no power. The outlet works fine. What could be wrong? It worked fine yesterday. I pressed the reset button? Does that...
You can download your product manual by going to this web-site and typing in your model number:
http://haieramerica.com/en/support/modelsearch
I checked the troubleshooting guide in the manual but it only lists the obvious such as is the unit properly plugged in, is the power button in the "on" position and etc. Are you sure there is power to the outlet? Try the outlet by plugging in a lamp or small appliance to check there is power to it. Let us know how it goes and maybe we can figure out something.
Jun 25, 2009 | Heating & Cooling
NO POWER?
HI, try a new wall outlet in the home or business. if the wall outlets are live, try replacing the power cord. if this doesn't yield results, replace the internal power unit(inverter board)
Jun 21, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
No power in the two bathroom electric outlets.
What do you mean protected, if they where ground fault they have a test button,or the breaker
can be a ground fault, but it is a lot cheaper to buy the outlets. Call someone that knows electric,
because you need to check to see which outlet has power coming from the breaker,because this one
is probably bad, which will not allow any power continue on to the next outlet. Just say you were
going to do this yourself , you need a tester to make sure power is coming to the outlet.
You could buy a ground fault outlet and a regular outlet, but you have to make sure that the ground fault
is wired from the breaker, the power from the breaker, then the wire that Leeds from the ground fault
to the other outlet will also be protected, one ground fault can protect two other outlets that are connected to it in what is called a series. Unless you have a multimeter to test what needs to be tested
you should ask someone that knows electric. If you have any more questions please post back as everyone is more than happy to help. I don't feel comfortable trying to explain to you how to replace
the outlets, it can be dangerous and I would not want you to get hurt just to save a few dollars.
Mar 25, 2009 | Electrical Supplies
WRT54GS router stopped working
try holding down the reset button which should be behind or under the router for 30 seconds, still holding down the reset button turn the power off for 30 seconds, still hoding the reset button wait more 30 seconds. After that your router should be in the way it came.
Feb 24, 2009 | Linksys : WRT54GS Wireless-G Router W/...
Jan 10, 2009 | Warmrails & Satin Nickel Towel Warmer &...
Aug 27, 2008 | Moen Sienna Paper Holders Matte Black...
Sony Cyber-shot DSC-W30-control buttons stuck
One button of the camera is stuck, try pressing hard all buttons various times with the camera turned off and try using it again.
Mar 05, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Home Logo
817 people viewed this question
Top Brookstone Home Experts
john h
Tom Chichester
Are you a Brookstone Home Expert? Answer questions, earn points and help others
