Question about Craftsman Arnold Mtd Snow Thrower Blower Light Easy Mount
Craftsman Snow Thrower engine spews balck smoke
    Master:
  • Craftsman Master
  • 428 Answers
The choke is stuck so remove the cover and look for the choke to see why it,s not movin
Posted on Oct 16, 2014
3 Suggested Answers
  • 417 Answers
SOURCE: craftsman 32" 10 hp snow thrower
Around the back of the engine, just below the cylinder cooling fins. The shut off should face you if standing in front of the recoil starter, for the fuel tank. The fuel line should wrap around I the side of the carb and be protected by the metal cover surrounding it.
Posted on Nov 22, 2013
  • 451 Answers
SOURCE: Craftmans Snow Thrower 247887001 Tire Flat. How to Refill.
The tires are probably tubeless type. If the bead is broken ( not sealed to the rim) the tire will not inflate. Taking the weight off the tire will some times allow the bead to seal against the rim and allow tire to be inflated. You can also put a small ratchet strap around the tread of the tire and tighten it up. This will squash the tire and make the bead seal up. MAKE SURE to loosen strap as soon as bead seals and tire begins to inflate. Hope this helps.
Posted on Jan 01, 2014
Can I use 0w 20 Mobil 1 oil in my snow blower
It can be used, although the manufacturer recommends;
Super S 5W-30 Snow Thrower Engine Oil - Sears
www.sears.com/explorer-5w...snow-thrower...oil/p-07188298000P
Sears Rating: 4.5 - ‎5 votes
Oct 21, 2010 - Explorer 5W-30 snow thrower engine oil is a premium formulation for use in all four cycle engines when temperatures are below 32 deg. F. Explorer 5W-30 snow thrower engine oil protects the engine by lubrication, cooling, cleaning and sealing internal moving parts.
Aug 23, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Manual for sears snow thrower 536.886621
They are basic what do you need to Find in the Manual?
Feb 12, 2014 | Craftsman Sears Snow Thrower Manual Model...
Carberater for my snow thrower isn't getting gas
The carburetor could be clogged. Try spraying some carb cleaner into the engine to see if it starts. If it does, then some part of the carb may have varnish clogging some of the ports.
Jan 30, 2014 | Craftsman 24" 208cc Dual-Stage Snow...
How to take a carburetor off an MTD Snow Thrower
Get user manuals for craftsman snowblowers to train yourself in clearing the pathways that are fully covered with snow.
Dec 15, 2013 | Mtd Yard-Man 26" 208cc Two Stage Gas...
Where is the throttle on a craftsman 536.881800 snow thrower?
Manual is available at http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Snow-removal-equipment-Parts/user-manuals/manual-downloads/Model-536881800/0247/1507200?modelNumber=536881800&diagramPageId=&documentId=
Dec 14, 2013 | Craftsman Sears Snow Thrower Manual Model...
Craftsman 32" 10 hp snow thrower
Nov 20, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
I am replacing the engine on a Craftsman Snow Blower. What is the engine to chassis mounting bolt torque amount?
Do not have a true answer other than to say it's probably a 5/16" bolt. 40 ft lbs would be about right for that
Jan 08, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Snow thrower is self propelled. was working fine then stalled
check the bearings in the auger sounds like the froze up and now they need to be replaced (the smoking you saw was from the belts slipping on the pullies)..good luck
Feb 26, 2010 | Craftsman 16" High Garden Tractor Snow and...
Craftsman Arnold Mtd Snow Thrower Blower Light Easy Mount Logo
143 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
