Question about Emerson 40" Lc401em2 1080p 60hz Flat Panel Full Hd Tv Hdtv Free S&h
Replacement parts for lc401em2f glass screen (inner screen)
I am looking for the "INNER" glass from the door of a LEF6EGSS.
Hello Julie;
Contact the following website for your part.
Peter
Glen Burnie, Maryland, USA Appliance Spares Appliance Parts Spare Parts Stokes Appliance Parts
Jun 04, 2015 | Ovens
Please tell me if Electrolux EKG5547XN Cooker Main Oven Glass Door would fit my EOB6632U
Glass oven door is not compatible.
First of all, the oven door EKG5547XN has only two glasses, inner and outer, while the oven door EOB6632U has three glasses; inner, middle and outer.
EKG5547XN
Inner glass oven door, part number: 349 00 30-01/6, silkscreened; dimension: 456 x 323 mm, tempered glass.
Front glass oven door, part number: 349 10 45-14 / 6, stainless.
EOB6632U
Inner glass oven door, part number: 899661 92 68-78 / 3,
silkscreened; dimension: 479 x 391 mm, tempered glass.
Middle glass oven door: dimension: 447 x 380 mm.
Front glass oven door: dimension: 589,5 x 466 mm.
Dado
Mar 28, 2015 | Electrolux Ovens
Replacing oven door glass
You didn't say what brand or model but here is a link to a youtube video for a Frigidaire oven, Other brands and models on youtube too. You will probably be able to get a replacement kit from sears parts direct if you have the brand and model number. Or an appliance parts store or ebay.
Range Stove Oven Repair Replacing the Inner Oven Door Glass Frigidaire...
Aug 16, 2014 | Ovens
How can i replace an LCD Screen Display a verizon LG extravert VN271?
Here's a video showing you how to take the phone apart: How to take apart lg phone It's not very professional, but you can use it anyway. Here's a replacement outer screen: Original OEM Verizon LG Extravert VN271 Outer Glass Front Digitizer... Lastly, here is the inner screen: Verizon LG Extravert VN271 LCD Display Screen Replacement Part Parts... Good luck!
Jun 20, 2014 | LG Cell Phones
How much is the inside glass behind the screen
Hitachi has two screens (other than a clear screen protector some have) The two inner screens are only sold as a pair---over 400) If the mirror behind them is damaged look to see no glass has scratched the inner screen as it will show---Mirror can be available either from Hitachi or some after market places have them.
If the mirror--Google the model number with "replacement mirror"
Apr 17, 2012 | Hitachi 51F510 51" Rear Projection...
The top inner glass of my ovan shattered and i am struggling to find a replacement, does any one no where i can pick up a replacement glass?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 10, 2010 | Ovens
Finding replacement part # 4164235 for inner door glass
I am looking for a Kitchen Aid part # 4164235, a Window Pack for the inner door of my Kitchen Aid Oven door.
May 16, 2009 | Whirlpool RBS305PDS Electric Single Oven
How do I replace the inner glass on the oven door? I have taken the door off and it is apart, but the glass assembly looks to be one piece. How do I remove just the inner glass for replacement? JenW30400W
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
Part here: _.gif PS2087058
Mar 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
INNER GLASS REPLACEMENT FOR KITCHENAID KEM308GSS0
I took it apprt removing the door according to manufacturers in structions and I found out it only needs a peice of glass, so I put it back together and put the door back for now and I ordered the glass from a parts supplier on the interenet after I dentifying the part online from an exploded Isometric assembly drawing on the vendors site. When it gets here I will install it. very simple a teenager could do it. The big question is why did it crack inthe first place?
Dec 11, 2008 | KitchenAid Architect® KEMS308S Electric...
Inner 'glass' of door
The inner glass can and should be replaced. It protects the metal mesh screen from getting dirty, which can cause it to be damaged and allow microwave leakage. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Sep 17, 2007 | Whirlpool MH1150XMQ Microwave Oven
Emerson 40" Lc401em2 1080p 60hz Flat Panel Full Hd Tv Hdtv Free S&h Logo
71 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
