Question about Crafts & Hobbies
Chime diesel horn
How do you hook up the diesel chime whistle?
What is a whistling noise behind the dashboard?
Many controls are activated by a vacuum line from the engine. My wild guess there is a slit or bad connection somewhere on the way to the control system. Good ears or "hearing horn" should help you find the sound source.
Mar 09, 2015 | 2004 Toyota 4Runner
Lionel train problems
Make sure the A or D terminal is connected to the center rail. U terminal to the outer rail. First do this without the sound activation button. Horn should sound this way. Once this works correctly, add the sound button in on the center rail lead (A or D) If the sound activation button activates the horn, reverse the connections to the sound activation button.
This should solve your difficulties
Dec 04, 2013 | Crafts & Hobbies
Where is the horn located on a Ford 450 Diesel Truck
The horn wire for a 2003 ford 450 diesel truck is in a cluster of wires it is yellow with a green stripe
Jan 15, 2012 | Ford F450 Cars & Trucks
Radio just makes whistle sound doesnt matter if mic hooked up or not same with antenna,worked great when bought lasted 2 days had fixed 2 days again had fixed again worked 1 day as soon as you turn on...
What type of power source is it hooked to? straight to car battery or some other power source? Sometimes cart alternator noise is picked up by radios. Try hooking the power source up differently
Mar 19, 2011 | Connex Radio Communications
Drivers side door chime and light go off intermittently
The switch in the door is shorting out. I would have the door adjar switch changed.
Jul 16, 2009 | 2001 Volkswagen Jetta TDI
The location for a 1996 oldsmobile horn relay? What relay is it?
The horn relay is accessible when you remove the glove box. It's to the right of the glove box, and has a large chime box with two relays to the side. The one towards the rear of the car (first one you see) is the horn relay. It's a little difficult to get out, but just plugs in. That large chime box is in the way somewhat, but with a little patience you can get the horn relay out. They're about 9 bucks.
Apr 08, 2009 | 1996 Oldsmobile Cutlass Ciera
Why is a ''D'' battery needed for my Lionel Diesel engine?
This is just a guess but it may have powered headlights or other lights on the train at one time, some of then even had a smoke producing device on them.
Mar 19, 2009 | Lionel New Haven Freight Train Set
Crafts & Hobbies Logo
29 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
