Ce002 error code on bizhub c552
Konica
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
jqsababa967
  • 145 Answers
SOURCE: KONICA MINOLTA
CD231 at power up.
Solution:
CAUSE: Complete fax kit was not installed.
SOLUTION: These three items make up the complete fax kit, FK502, MK706 and MK704. If not installed together, the C250/C252 will display code CD231.
hope that helps
Posted on Nov 04, 2008
firecontrol7
  • 6161 Answers
SOURCE: KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Posted on Jul 25, 2009
Bizhubman
  • 108 Answers
SOURCE: how to clear error code c 3421 on konica bizhub
C-3421 = Fusing heaters trouble
To Reset:
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If error code returns a technician is needed to replace fuser section. Call local dealer with error code and tell them to make sure a tech brings a fuser assembly.
Posted on May 19, 2010
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
ERROR CODE C3B02 KONICA MINOLTA C552
Have you changed the fusing unit? If try that first, then relace the IH Power supply or the (coil unit) is what the fuser attaches to when you install one. power supply is located right side under the control panel, .
Sep 23, 2015 | Konica Minolta Bizhub C552 Copier
I have konica minolta c552 has an error C3b02
Hey jrf, the manual says to check, in this order; proper fuser installation, proper closure ( door latch ) of the right hand door, check around-all around-for wiring connection issues, change fuser, then coil, then IHPU, then PRCB, then REDB. If you have a trade-in, or lease return, at the shop; it might pay to do some parts borrowing.
Konica Minolta C552 error code C-B02
Replace the IH Power supply, it will solve your problem... Page 71 Item 5 from the parts manual.
Jul 17, 2015 | Konica Minolta Bizhub C552 Copier
Bizhub c552 error c3b02
In all likelihood this is the IH power supply board. Not a difficult procedure but the board may be expensive. Can send through details if required.Cheers
Jul 06, 2014 | Konica Minolta Computers & Internet
What is bizhub C552 p-14 error?
p codes are warnings that a consumable is reaching the end of its life you can go into service mode and it will give you a list of error codes including p codes
Jul 04, 2014 | Konica Minolta bizhub C552 Waste Toner Box...
C163 on b52izhub c5
3B02,3B03,3B04 - IH malfunction.Try reset the error code:
Turn OFF the copier,press and keep pressing the Function key and turn ON the copier.Keep pressed the Function key until appaire the Trouble reset message on the display.Release the Function key ,touch the message and turn OFF the copier.Wait 1 minutes and turn ON.
Dec 23, 2013 | Konica Minolta Bizhub C452 Copier
What does Error Code C2564 Konica Minolta Bizhub 552 mean
Black drum ATDC replace the black developer unit, also check to make sure the black toner is getting into the black developer unit. Open close the front door to reset the code (Not the Toner door)
Apr 24, 2012 | Konica Minolta Bizhub C552 Copier
48 people viewed this question
jasbo
jasbo
