Question about Motorola Talkabout T5720 (7 Channels) 2-Way Radio
Doesn't transmit radio receives but does not transmit
  • Motorola Master
  • 1,654 Answers
Check your battery. Transmitting takes more energy than receiving. Also, check your frequency and code settings. The radio you are using this one with might have a different code setting than yours. http://shop.giantintl.com/Manuals.asp
Posted on Jan 08, 2015
3 Suggested Answers
  • 43 Answers
SOURCE: T5100 : One radio receive but not transmit back.
check batteries, maybe they are on the way out. otherwise its in the lever connection. old?
Posted on May 07, 2012
SOURCE: One of my walkie talkie's transmits but doesn't receive...WHY?
Your speaker is blown. The microphone still works but you can't hear any audio. Take it back if there not to old.
Posted on Nov 01, 2012
Problem no squelch noise or speaker like its muted, but can hear weather ok shows receiving and ant ok
Since the radio cannot transmit on Weather bands, there is no need for the radio to detect if it is transmitting when receiving weather.
In CB mode (on CB channels) the radio will mute when transmitting. So... a guess is that it is muting, or transmitting all the time in CB mode. Check for a mic problem by removing the Mic from the radio ... if it receives CB with no mic connected, then there is an issue with the mic. Otherwise, unless the unit is in PA mode (public address mode) it is likely something internal and beyond the scope of this service.
Sep 08, 2015 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
What are some of the reasons my radio transmits but doesn,t receive
One possibility is the other radios in your group are operating open squelch (aka without a tone code, private line, PL, interference eliminator). If your radio has a CODE turned on, your radio will block receiving radios without the same exact code.
Best regards.
Aug 23, 2014 | Radio Communications
Radio will not send
It is possible your Code for transmit is different than your Code for receive. Cobra makes so many models, you are not giving enough information. Also, Transmit takes a LOT of power, so even if everything is setup, if your batts are weak or old, the radio will receive, but not transmit. Also check your antenna, make sure it is tight and NEVER transmit without an antenna. Yes, all lights will work even with old batteries.
Nov 10, 2013 | Cobra Radio Communications
Flashing red light on radio where it thinks its recieving. Transmits fine but does not recieve.
Three things come to mind:
1) The radio is receiving, hence the light, but you may have a different PL code than the other radio and it is muting the transmission. Check your programming to be certain both radios are programmed alike. The red light indicates activity on your frequency.
2) Your radio may have a problem with the receive side of the radio or a bad speaker.
3) The transmitting radio may have a problem with transmit. This can be a sign of a bad battery. Swap batteries and see if the problem moves to the other radio. If so, replace the battery. (It takes more energy to transmit than to receive, so loss of transmit is common with a bad battery.)
Best regards.
Apr 15, 2013 | Motorola CP200 Two Way Radio
Nov 01, 2012 | Motorola TalkAbout T6530R (14 Channels)...
I have an almost new Midland 75-822 that the WX works fine on, but the CB doesn't seem to receive, or transmit. It operates normally, but no reception, and no evidence of transmissions.
you'll need a schematic and some knowledge. there a two diodes that control the rx and two that control the dx.Check them to make sure they are producing the correct power out put if they are not you should replace all 4
May 10, 2012 | Midland 75-822 40-Channels Handheld CB...
May 07, 2012 | Motorola Talkabout T5100 (14 Channels)...
Hisses/squeals when transmitting
Check the input voltage into the radio while in transmit. The voltage maybe dropping as you go into transmit which causes it to drop into receive. That in turn allows the voltage to come back up. With your finger still on the PTT it tries to transmit again, etc. This could cause a feedback squeal and other symptoms.
May 30, 2009 | Uniden PRO538W (40 Channels) 2-Way Radio
Motorola Talkabout T5720 (7 Channels) 2-Way Radio Logo
279 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
