Samsung syncmaster 2243lnx doesn't turn on
Hi, such a problem: Monitor doesn't turn on after push the on/off switch (diod don't light and the monitor is dark). I have checked F101 (OK), C105 (306V DC), C108 and C112 (both 13V DC). Where should i look for any cause of the problem? Michal
tantong
  • 138 Answers
SOURCE: Samsung LCD Monitor SyncMaster 203B
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen blacked out or stopped working, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 26, 2008
  • 34 Answers
SOURCE: samsung SyncMaster 510N Monitor is flickering and blinking
Does the monitor remain on does it switch off?
Problem seems to be hardware related ie monitor itself is defective.Try connecting to another known working system.If monitor is defective it could be a power/inverter related issue or panel could be defective.
Please provide feedback and rate the solution.
rahul
Posted on Feb 22, 2009
  • 225 Answers
SOURCE: monitor will not turn on and the green light just flashes
There's an internal hardware electronic part/s of your samsung syncmaster 930 that is cold soldered / defective. I suggest to bring the unit to an authorized service center to fix the problem. regards
Posted on May 30, 2009
Geekman
  • 32281 Answers
SOURCE: cannot set my SAMSUNG SYNCMASTER 710V MONITOR RESOLUTION
When you can't change the screen resolution then most likely only the default VGA driver has been installed. You need to install the graphics driver of the video card that is installed in your computer.
To check which graphics driver is installed, click on Control Panel - Display - Settings - Advance - Adapter tab. If the graphics adapter is set for Standard VGA then the graphics driver was not installed.
Posted on Aug 23, 2009
  • 788 Answers
SOURCE: Monitor not wrking
Sounds like you may have had a power surge.??
Disconnect power and signal input.
Turn the unit off for 20 minutes or so. Check the outlet against another device. ( Light )
Turn unit on without connection to PC video.
If you get a no signal, you good to go . Reconnect. If you continue to get a flashing light on power button,
Check warranty, get it back to Samsung for repair.
Hope this has helped
Posted on Sep 03, 2009
Samsung Syncmaster 205bw does not power up. Power button light comes on and cannot turn it off by pushing it.
The processor ic has malfunctioned and is the brains that controls various parts of the monitor, including on/off, picture settings and others to numerous to mention. The monitor is not cost effective for repair and is cheaper to replace.
Jan 13, 2011 | Samsung SyncMaster 205BW LCD Monitor
Power light was blinking took a long time to turn on, now power light does not blink or go solid and screen does not work
The Samsung SyncMaster 940MW monitor has an issue with the power supply going out. The flashing power light or not turning on are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com This model is on Monitor repair page #2 We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
NO Display
time to replace the monitor, u fried the board, been there done that
Jun 20, 2009 | Samsung SyncMaster 793MB 17" CRT Monitor
I cant unlock osd of my samsung monitor , sync master 551v
Please try again to turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu. regards
May 27, 2009 | Samsung SyncMaster 151 N 15" LCD Monitor
Monitor Problem
its a power prblem
u need to change the internal power conector
Sep 03, 2008 | Samsung SyncMaster 793DF 17" CRT Monitor
Monitor not working
The inverter board has probably failed. Mine turned out to be the clamping diodes on the inverter. It would act like it was firing up but shut down just as the screen would normally come up. I replaced the diodes and it fired right up and has been working great since.
Mar 11, 2008 | Samsung SyncMaster 17 in. LCD Television
Computers & Internet Logo
David Payne
David Payne
