Ken wood sw-32ht powers up but doesn't play
My kenwood sw-32ht subwoofer will turn on and show the lights and everything but it will not produce any sound when i play music or movies. Not sure if I blew something on it or if the subwoofer cord is just at the end of it's life. Has anyone had this problem?
5 Suggested Answers
SOURCE: Sub-woofer output not working
"Sub-woofer output not working" problem, and notify you when a new solution is offered.
Press the setup key on the front of the receiver
Select the subw setting
Move the multicontrol knob until the sub woofer is on
Turn off the receiver and turn back on- the subwoofer should be on
The operator manual can be downloaded on the web site--- free
http://www.retrevo.com/support/Kenwood-VR-507-Receivers-manual/id/480ag219/t/2/
Posted on Mar 21, 2009
petraman7
  • 1175 Answers
SOURCE: actors voices
Hi....
If your system is set up for surround and you dont have a center speaker that will happen.
Check the manual for best setup
Posted on Mar 24, 2009
  • 16 Answers
SOURCE: Kenwood VR-6070 no sound?
you need to replace the amp i have worked on receivers for 8 years now and it is verry common for them to blow a amp but i will worn you the amp is a pricey peice
Posted on Dec 12, 2009
one5oneproof
SOURCE: Pioneer VSX-822-k Subwoofer problem
I had the same problem. Dont know why the receiver set it up this way but grab your remote, go down to the lower right and select ch setup. Keep on pressing it till your receiver says SW. Then press lev+ on your remote to change the db on your powered sub.
Posted on Oct 31, 2012
I have Kenwood SW 900 . need to know its out put. Kept for long period
Do you mean the Kenwood SW-200 subwoofer or the SW-200 power meter? The subwoofer can use 50W RMS at 4 Ohms. It's rated at 60W. The power meter reads in two ranges: 20W and 200W.
Kenwood has the manual for the subwoofer on their support site. The direct link to the manual is http://kenwoodusa.com/UserFiles/File/UnitedStates/Home/Manuals/sw200.pdf .
I hope this helps. If you are looking at a different Kenwood product, please clarify which product you have. I can't find a SW 200 receiver from Kenwood.
Mar 08, 2016 | Kenwood Car Audio & Video
Have a kenwood sw-32ht green light comes on but have no sound, please help on what it could be
Check the signal or rca's. Make sure the sub is turned on from the headunit. Sounds like you have power but no signal. Also, make sure your power wire has 12 volts. I've seen where the light turns on because remote wire has power, but no power from the battery wire.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
Oct 17, 2014 | Car Audio & Video
Kenwood sw-35ht Replace with a kicker sub
I suppose you could, but you are talking about a driver (speaker) that was not designed for that cabinet size and amplifier used in the Kenwood, There are differences in speaker design besides power rating and impedance.
Jun 10, 2014 | Kenwood SW-38HT Subwoofer
Kenwood SW-32HT Subwoofer Dropping sound Yamaha Reciever
Several possible answers. First - is that the Yamaha has a fault that is sending a signal with too much power on it. And the sub detects this and switches off.
Second - either the Receiver or Sub is switching off when no audio is present. A setting problem?
Third - the sub has a fault, possible overload, and goes to standby for safety.
Jul 01, 2017 | Audio Players & Recorders
Cannot get the subwoofer to play...all other speakers work fine...my Kenwood receiver is VR-309...the subwoofer model is Kenwood SW32-HT... I have also used the setup mode to make sure the Subwoofer is...
After making sure that your subwoofer is receiving power, as most models have their own amplifier, make sure that it actually is turning on. There is a possibility of a faulty power switch. Lets rule that out first.
Once the switch is on and the proper power connection is verified, turn your attention to the setup menu on your receiver. Navigate to the LFE/Sub output level. Adjust it up all the way. Then navigate to the crossover setting. Turn it up all the way. If the subwoofer also has it's own control panel including a crossover, turn that up all the way as well. Then with an input on the receiver that has a subwoofer output set up such as for DVD, play some audio. Or likewise you can also use the receivers' test tone capability that will pan each channel individually with a wide band pink noise signal that also includes a signal sent to the subwoofer output.
If this procedure does not produce results then send me a message including your subwoofer model and your observations of your systems' operation.
Jun 10, 2011 | Kenwood VR-309
I have receive from my brother kenwood
You will need to call Kenwood and they will have a master code that they can give you.
Jun 16, 2009 | Car Audio & Video
Sw-32ht kenwood subwoofer
Open the case and check the fuses and the speaker to see if it actualy still working and not blown.
Oct 26, 2008 | Kenwood SW36HT Subwoofer
Sep 22, 2007 | Kenwood VR-507 Receiver
15 people viewed this question
 Grubhead
Grubhead
