Question about Cobra 29 LTD CB Radio
What is the talkback feature used for - Cobra 29 LTD CB Radio
    Genius:
  • Cobra Master
  • 1,795 Answers
It ids used to set your voice to any noise toy you may have installed you can hear the way its set so now there is no need to bother anyone with a radio check
Posted on Aug 23, 2014
How to get talkback turned off
Hi Michele
To turn off TalkBack, follow these steps:
  1. Navigate to Settings > Accessibility > TalkBack.
  2. Slide the TalkBack switch to the off position.
  3. In the Stop Talkback dialog, select OK.
Feb 29, 2016 | Cell Phones
How do I turn off the talk back feature on lg tribute
TalkBack won't turn off - Google Product Forums
productforums.google.com/d/topic/nexus/av7djMHBA14
Google
Oct 23, 2013 - 100+ posts - ‎100+ authors
Re: TalkBack won't turn off, Nexus 5 -curious user, 2/15/14 6:38 AM ... I don't blame Google for making this feature so difficult to shut off once ...
How to Disable Talk Back Mode? « Android Gadget Hacks
android.wonderhowto.com/forum/disable-talk-back-mode-0147617/
Jun 24, 2013 - If you just have the regular swipe to unlock feature for your lock screen, to unlock it ... Now, to disable TalkBack mode, you need to make your way to ... I only turned on because my lady friend has an LG Stylo G and she set her ...
How to Exit 0r Disable "TalkBack" Mode on LG Optimus F6 ...
? 3:11
https://www.youtube.com/watch?v=YDmcLi9kF8w
Dec 3, 2014 - Uploaded by Klavdio-Leadership
This Video will show you how to disable the TalkBack Mode on your phone.
LG L70 how to Turn off the talkback or voice over - YouTube
? 2:29
https://www.youtube.com/watch?v=FEei11i4OGg
Jan 13, 2016 | LG Tribute 4G No-Contract Cell Phone
I have the ROADPRO RPPS-550 4 Noise Cancelling CB Extension Speaker with Talkback, why is there 2 male plugs and where do they get plugged in at. One obviously to the CB radio. The other ???
Both should go to the CB radio. One would be for "audio out" from the radio, the other should be for "audio in" to the radio to handle the "Talkback" feature. I doubt that most CB radios will support this. Your best bet is to determine which plug provides output to the speaker (so you have better audio output from your CB - if that's actually possible) and disregard the 2nd plug if your radio doesn't support it. Hope this helps.
Jul 09, 2014 | RoadPro RPPS-550 CB Ext.spkr Noise...
HOW TO UNLOCK SCREEN
To Disable TalkBack mode
  1. 1 Go to the home screen of your Samsung Galaxy S3 S4 or Note2. Was this step helpful? Yes ' No ' I need help
  2. 2 Now, go to settings, menu option. There is an invisible button to the left of your home button. Press that button, and select Settings. While in TalkBack mode you will have to double tap to select menu items. So double tap settings. Was this step helpful? Yes ' No ' I need help
  3. 3 Now select accessibility. Share this Share this on FacebookTweetPlusPinShareRedditDigg settings-accesibility.png While in TalkBack mode you have to use two fingers to scroll / swipe to get down to the accessibility menu item. Again, you will need to double tap to select accessibility because you are in TalkBack mode. Was this step helpful? Yes ' No ' I need help
  4. 4 In accessibility you can now disable TalkBack mode. Share this Share this on FacebookTweetPlusPinShareRedditDigg accesibility_-_talkback.png There is also an option here to disable "Text To Speech," which you must also disable. You can disable it here or an alternate method is covered in the next section. You can use either method. If you have trouble with one method, try the other.
May 23, 2014 | Samsung SGH Cell Phones
I have a Connex 4600 Turbo mounted in the headliner of a W900L Kenworth using Wilson 2000 twin antennas and a RK56 mic. When trying to use the "talk-back" feature all I hear is constant...
Strange. You shouldn't have a squealing problem with an RK56 noise canceling mic.
Unfortunately there is no way to change the volume of the talkback. Its too loud. The only solution is to turn the mic gain down.
The only reason you need to have talkback on is to check your audio. Make sure the echo is good and what not. After that you really don't need it on. So turn down the mic gain, then check the echo, then turn off the Talkback and turn the gain back up.
The squeal is feedback from the talkback being to loud and being heard by the mic. So the only way to solve it is to lower the volume of the talkback, (Which is not possible in this radio) lowering the mic gain(which lowers your audio level) or turning it off.
Nov 08, 2010 | Connex 4600 Base CB Radio
Galaxy dx-66 squeals on talkback
timspur, hi. First off, using the talkback with a tuned Galaxy will give you problems, so you need to use a good noise cancelling mic like a RK 56, or Astatic 636. If your running an amp, that will only amplify the problem. Here is a mod if your comfortable working on your radio, to tone down the TB volume.
Talkback can become distorted if these radios have been "peaked," and there is no cure because the talkback just amplifies what goes to the RF section. Try adding a 470k ohm resistor from junction of C155/R207 to the junction of C187/R235 on the solder side of the board. This will also give you clean talkback on SSB and FM. Try different values of resistance to get the amount of volume you want. The less the resistance the louder the talkback will be.**
Hope this was what your looking for,, I know for a fact that the Astatic mics do help tone it down.
Let us know,,, Mechanic
Mar 12, 2008 | Galaxy Radios DX-66V Base CB Radio
Cobra 29 LTD CB Radio Logo
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
