Question about Canon PIXMA MP510 All-In-One InkJet Printer
Cyan ink tank not recognised
Upon switching my printer on today, the Cyann ink tank can not be recognised, error U150. The contacts do not appear dirty but I have not given them a real clean, the other tanks work perfectly, what could be the problem here?
  • 15 more comments
  • Anonymous Nov 11, 2007
    Our brand new MP510 reported it couldn't recognise the cyan cartridge, we took out the cyan cartride, then immediately clicked it back in...the light came on & it worked for a couple of days. Then it began being "not recognised " more & more frequently, but would work for a while if loosened then replaced, until it refused to be recognised AT ALL. If one tank can't be recognised the whole printer wont work which is VERY inconvenient. The shop we bought it from is a long drive away, but I managed to get a new cyan locally, & we've had no trouble for 2 weeks. BUT yesterday the yellow intermitently couldn't be recognised, and today refuses to be recognised at all...so my printer again wont function at all. It seems to be a design fault if one cartride malfunction negates the whole machine....most of my printing needs are black for documents.
  • Normsthename Nov 20, 2007
    I have a Canon MP510 and I keep getting the U150 error message.
    The fault shows when you first switch the printer on :-
    'The following ink tank cannot be recognized.'
    Removing and replacing the cyan cartridge has cured the fault a few times.
    But now the fault is permanent and it will not clear.
    This is the third fault that I have had with this printer in two months so potential buyers beware!
  • Gary in SC Dec 04, 2007
    I just received my new MP510 and having the same problem with the cyan cartridge. Canon just offered these through their estore at 1/2 price. Now I see why. Will call Canon this morning.
  • Anonymous Dec 05, 2007
    Same problem. The error message 150 continually comes up for the Cyan tank. I have clicked it back into place and it again shows same error. has done this on and off for a few weeks now. At present, it is anot working at all.
    Tez
  • Codezrus Dec 19, 2007
    Got the same Probem (U150) Cayan not recognized. Anyone found a solution to that? My Printer is 1 month old.
    If so, email me please.
    Touched_bi_an_angle at yahoo dot com
  • sirhar Jan 01, 2008
    It seems I am not alone with this problem of Canon MP510 cartridge recognition. Surprise, the CYAN cartridge seems to be the troublemaker. The problem also disappeared BUT only for awhile in the beginning by reinstalling the cartridge and now it is always unrecognizeable. I have been able to use that cartridge only few times. Now I am wondering that will this problem disappear by replacing the cyan cartridge by a new one or will it appear again. I guess there can be few root cause choices, either the cartridge is faulty, contact improper or MP510 has some strange bug. I believe and hope it is the first case but then it is question of how many of those faulty cartridges are in the market. Too bad I don't have any receipt left from these cartridges.
  • Navitas87 Jan 02, 2008
    i got the same problem. :-/
  • Anonymous Jan 04, 2008
    Same problem, with black ink tank.
  • funkee Jan 13, 2008
    I've the same problem too but with the magenta ink tank. Printer and ink tanks are only about 2 months old, with very little use. As with others, refitting the ink tank made this work again a few times, but now, nothing....Argh!
  • Anonymous Aug 08, 2008
    I have the exact same problem with the MP600 - obviously Canon have alot of probs with their inktanks. The only solution I have had so far is to replace the inktanks which is fiendishly expensive. I think I might actually replace the printer as it will be cheaper very soon.
  • Sinan Saday Sep 10, 2008
    Yea, I get the same problem with my MP510 and the Magenta Cartridge. Took the tank out, replaced it,then another tank would give the same problem, so i take them all out, replace, and then it works fine. That solution worked for approximately a month, until it stopped working altogether. The printer has been used intermittently since I got it for christmas, and all tanks are a little under half full.
    The shop it was bought from is out of my way, because I don't have a car, and the other nearest chain is about a 40 minute drive away.
    I will try phoning Canon support and see what happens.
  • algarvewest Oct 01, 2008
    Cyan ink tank is not recognise, although it is half full.
  • youdontride Oct 09, 2008
    same here. got this mp520 for 07 xmas. it suddenly showed the u150 error recently and now it says it wont recognize the black or cyan. ive only used the printer about 5 times since i got it. i called tech support and they are sending new cartridges but i feel this is just sterring around the problem rather than dealing with an obvious issue with these printers. besides, i need to print something NOW and i cant, all the while cannon has profited form selling me this piece of **** and i cant even use it. how lame.
  • Anonymous Nov 25, 2008
    is there a solution to this yet?
  • bowmore Dec 08, 2008
    I have a Canon PIXMA MP800R. I have the exact same problem at the moment with the Cyan Cartridge it’s about 95% full. This has happened before with all the other colors, In the past I have just installed a new ink cartridge and the problems solved. This has become very expensive throwing nearly full cartridges away. I have noticed they never fail when they are nearly empty. Why dose it lock out all the other functions of the printer i.e. scanning etc, very inconvenient.
    I went on canons web site and reported the error U150, not had a reply yet but will keep you all informed, As to what they say, And the final outcome.
  • chorn999 Jan 05, 2009
    U150 with my MP510 and I'm getting it with a fairly new black cartridge from Canon. I hate this printer!
  • Anonymous Mar 03, 2009
    I have the same problem but I cannot find the Canon number for the UK where I bought my printer. Does anyone have the telephone number wher you can speak to a human being?
    If so please post. Thanks
Did it fix it?
Posted on Oct 06, 2008
The same as my problem:
My brand new MP510 reported it couldn't recognise the cyan cartridge, we took out the cyan cartride, then immediately clicked it back in...the light came on & it worked for a couple of days. Then it began being "not recognised " more & more frequently, but would work for a while if loosened then replaced, until it refused to be recognised AT ALL. If one tank can't be recognised the whole printer wont work which is VERY inconvenient. The shop we bought it from is a long drive away, but I managed to get a new cyan locally, & we've had no trouble for 2 weeks. BUT yesterday the yellow intermitently couldn't be recognised, and today refuses to be recognised at all...so my printer again wont function at all. It seems to be a design fault if one cartride malfunction negates the whole machine....most of my printing needs are black for documents.
HELP ME
Posted on Dec 08, 2007
I phoned Canon Tech Support Center this morning. They had me replace the ink tank giving me the U150 error code and are sending me a replacement tank. HOPEFULLY this will solve the problem.
Posted on Dec 05, 2007
  • Gary in SC Oct 06, 2008
    I replaced the cartridge with one they sent me, now no problems for several months.
Error code U150 The following ink tank cannot be recognized
First, make sure you have the right ink cartridges. Here are the right codes: CLI-8BK and PGI-5BK for black, Yellow - CLI-8Y, Magenta - CLI-8M, Cyan - CLI-8C.
If the ink lamp is off then an ink tank error has occurred. Try to remove the ink tank and re-seat it. Make sure you removed the plastic cover on the ink tank. If nothing helped, you need to replace the faulty ink tank.
Dec 29, 2010 | Canon PIXMA MP600 all-In-One InkJet...
I have put in new cyan ink cartridge but printer does not recog
are you sure you got the right ink cartidge put in? Also check if you took that piece of plastic that coverred your ink cartridge contact
Mar 20, 2009 | Canon PIXMA MP530 All-In-One InkJet...
U150 Canon no cartridge recognised
Because these a refills inks the Chip things they are full so you must replace the cartridge with a new Canon one and the fault will go. If not just replace the chip with a new one!
Then your error u150 will go.
Sep 25, 2008 | Canon MP610 Photo All-In-One Printer
Error u150 Canon Pixma MP510
U150 error is a cartridge hardware error. Only thing you can do is replace the ink.
Sep 25, 2008 | Canon MP970 Photo All-In-One InkJet...
Error: U150 the following ink tank cannot be recognized
Only thing you can do with the U150 error is replace the tank.
Jun 27, 2008 | Canon MP970 Photo All-In-One InkJet...
U150 error message
There was plenty of ink left in my Cyan tank but just replacing it with a new Canon CLI-8C one, as suggested by techguru005, did the job. I suppose that the chip must have been faulty?
Let's see how long this one lasts!
Thanks, techguru005, it's fixed for now.
Jun 16, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Defective Ink Cartridges for Canon PIXMA MP830
1. Just open and close the cover a bid, this will initiate new checking of all ink cartridges
2. clean the contacts of the inkcartridge chip e.g. with spirit
3. Press the reset/stop-button for >10s to quit the error ... but be aware that the ink level will no longer shon correctly
Jan 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Error code: U150 The following ink tank cannon be recognized (Cyan)
U150 ink error fixed!
I too was getting the error for unrecognized ink cartridge. Then the little green circ board fell out of the end of the ink cartridge and it hit me that maybe if I put in the little green circ board from the old ink cartridge of the same color, then maybe the ink cartridge would be recognized. It worked! So don't throw out an ink cartridge that still has ink just because of that error and hold onto your empty cartridges in case you need the little green/gold circ boards.
This works!
Dec 26, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Alarm light on, Display indicates error message: Check Ink U150 M
I added my post today with the same problem, and thought I'd share what I since learned. Apparently this "Alarm light/U150" is common with several Canon models. The U150 indicates a faulty electronic chip (on the ink cartridge). Though I tried cleaning the sensor with isopropyl alcohol, and also tried removing all the cartridges, unplugging the printer for 45 seconds, then reconnecting,etc. as I had read might help, I still had the same frustrating problem. Contacting Canon was the solution that worked for me. First I emailed, but decided I didn't want to wait for their response. A call to Canon Tech Support (1-800-385-2155) was quick and painless. They will more than likely send you a new cartridge, but you'll need to have your serial # & date of purchase handy.
Oct 27, 2007 | Canon PIXMA MP530 All-In-One InkJet...
U150 error
Anyone game for a class action against Canon? I've called, E-Mailed, and faxed, all to no avail, not one answer, no return contact whatsoever!!! Please post this info about these piece of **** Canon printers on every website you can and anywhere else you can, the world needs to know what GARBAGE Canon is unloading onto the unsuspecting consumer. Hopefully, it will get Canon's attention and maybe those losers will take notice when their sales drop! What say everyone boycott anything that says Canon on it. Come on Canon, take care of this junk you have ripped us off on. I am even telling people IN the stores who are looking at printers to AVOID Canon completely.
Nov 07, 2006 | Canon Pixma MP800 All-In-One InkJet...
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
1,787 people viewed this question
old marine
old marine
