Question about Xerox Office Equipment & Supplies
Xerox 5845 sleep mode issue
Hangs and goes of line
3 Suggested Answers
SparkGap
  • 363 Answers
SOURCE: program copier not to sleep at work
I suspect it goes to sleep after a period of inactivity. To wake it up just use it. You dont want the heated rollers to be heated all the time, it wastes electricity. I'm not sure if this copier can be programmed to be awake as soon as you start work. The most environmentally friendly option would be to turn it off when you leave work and turn it on again just before it is next needed. If you think there is a better answer then PLEASE just rate me with 'Thanks for trying' Regards
Posted on Sep 27, 2007
  • 25 Answers
SOURCE: Xerox 8560 is very hot even in sleep mode
the fusers get about 300 degrees to melt the toner to the page. If you do not have the phaser clean regularly, the paper dust that is next to the fuser could smell like it is burning.
Posted on Jul 16, 2009
Xerox center printer is being shut off instead of going to sleep and wake on job
bad control board or might be settings to put in sleep mode then shutoff check settings go to menu
Jun 03, 2015 | Xerox Office Equipment & Supplies
Xerox Phaser 8560MFP: When in sleep mode, the printer still wakes up to do a warm up test and then goes back to sleep. How can I turn this off?
Look in the setups.
It might be a good idea to print out the setup sheets. Look under sleep mode and set the time accordingly to what you want.
Alternatly go to the WWW.xerox.com website for assistance.
Good luck.
Oct 03, 2010 | Xerox Phaser 8560MFP Laser Printer
I own a phaser-8550 and the problem is that the printer seems to wake up when it is in sleep mode. If I turn it off and back on the next day, jobs print OK until it goes to sleep and it forgets to wake up....
There are two stages to the sleep mode, One is a low power condition. That is the real sleep mode. There is also a time that will shut the machine off. You can go into the machine setups and shut that timer off.
Mar 09, 2010 | Xerox Phaser 8550/SDT Color Laser Printer
How do i shut off the energy saver compliant on xerox c20
For majority of the models Xerox entry in service mode holding [0], include the device.
Entry in service mode
Xerox 5845, 5855
Or include the device with simultaneously pressed button [Interruption] and [2], or on included device to press and hold these buttons more than 2 sec. If device faulty - an entry is realized button [Interruption] and [5], with restriction function (consecutively appearing reports on fault are thrown double keystroke [Foots]).
Hereinafter, the device calls четырQхзначный code of the access: this or 8765 (by default), or the last four numerals counter mines in inverse order (if counter mines shows 01234567 - a code of the input 7654).
Xerox N17, 24/32/40, 3225/4025
There is 3 diagnostic modes:
1 - are checked breakers, sensors and are removed parameters фьюзера, input: (2+6), after "IOT?" press "7" 2 - haves something published the test-sheet "net" in simplex or duplex, input: (2+6), after "IOT?" press "4" 3 - are changed parameters and adjusting the printer (NVRAM), input: (2+6), after "IOT?" press (4+7), "7" immediately release, "4" keep before appearance "3" on дисплее, then release.
XD102...155, XE60...84, XC800...1255
stop auto stop auto
sometimes write as C Density select C Density select (that same)
WC PE 16(e)
we type on keyboard [menu] - [#] - [1934] - [menu], after entering inscription "TECH" will appear in service menu
Oct 12, 2009 | Xerox CopyCentre C20 Black and White...
Xerox 8560 outputs Cleaning Pages several times a week. The unit is never turned off and only goes into "sleep" mode. Last time it woke up at 1:00 AM and went through the noisy cycle and output the...
There is nothing you can do about the cleaning page. And if its only using 20% of your ink, you're luck normally its 25% of the ink. This is simply how the machine works. Nothing can be done. The Xerox employee was simply trying to give you something to try, but it won't change anything!
Mar 27, 2009 | Xerox Phaser 8560MFP Laser Printer
My hp laptop hangs up when it goes into sleep mode
my laptop hang during working no any keyboard and mouse key working during hanging . what i do.
Sep 01, 2008 | HP Computers & Internet
Power spike
It sounds like you have some serious wiring issues within the building / house you are in, and voltage is being sent back through ground when the printers fuser goes into warm-up.
A line conditioner / stabilizer may help, but honestly, I would call an electrician before it completely shorts out the computer, or burns the house down.
Apr 08, 2008 | Brother HL 1440 Laser Printer
Program copier not to sleep at work
  1. Press the [Access A] (key symbol) button on the top, right corner of the Control Panel.
  2. Enter the system password using the numeric keypad, then select [Enter] on the Touch Screen. The default password is 1111.
    NOTE: The default password is 1111. The password will be displayed as an asterisk (*). If you make a mistake, press the [Clear (C)] button and re-enter the password. To cancel the operation, select [Cancel]. If you are experiencing problems with your password or have forgotten your password, contact your administrator.
  3. If the Internal Auditron is not enabled, select the [Go To Tools] button (does not apply to copier-only models). If the Internal Auditron is enabled, select the [Tools Pathway] button.
  4. Select the [More] button.
  5. Select the [Power Saver Administration] button.
  6. Select the [Set Duration Times] button.
  7. To adjust the 'From Standby Mode to Low Power Mode' time-out, select that box so it turns black then enter a new time using the numeric keypad on the Control Panel. The Standby to Low Power may be set between 1 - 120 minutes.
  8. To adjust the 'From Low Power Mode to Sleep Mode' time-out, select that box so it turns black then enter a new time using the numeric keypad on the Control Panel. The Low Power to Sleep may be set between 0 - 120 minutes.
    NOTE: There should be a minimum of one minute between the 'From Standby Mode to Low Power Mode' and 'From Low Power Mode to Sleep Mode' settings. For example, if the 'From Standby Mode to Low Power Mode' is set to 10 minutes, then the 'Low Power Mode to Standby Mode' should at least be set to 11 minutes.
  9. Select the [Save] button.
  10. Select the [Exit Tools] button.
Sep 27, 2007 | Xerox CopyCentre C128 Black and White...
XG-91D (Black) 19 in. Flat Panel LCD Monitor
Partition shows up as a MS-DOS partition This utility is designed save information you may be working on when it goes into sleep mode or when your battery becomes low on power.
Computer questions and answers listing 700 - 800 CH000735, How do I disable the power, sleep, or wake buttons in Windows?
Good Luck, please dont for get to Vote, Thank You.
Aug 03, 2007 | Xerox XG-91D 19" LCD Monitor
49 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
