Question about Tally Matrix T2280 Printer
T2280+ Printer head
Wrong board error message lipi 2280+
problem with head cable
head cable may be cut
Oct 18, 2013 | Tally Matrix T2280 Printer
Can't find driver for tally t2280 sprintpro
Have a look an the manufacturers web site (Dascom)
http://www.dascom.co.uk/Support/Default.aspx?type_id=3&info_id=3&itemid=15&name=T2280%&act=4
Jan 08, 2013 | TallyGenicom 2280 Matrix Printer
I am getting a hardware error...
pls remove the top cover and check whether head is moving properly or not
Dec 23, 2010 | Tally Matrix T2280 Printer
Driver Tally T2280
You can download the drivers for the T2280 Dascom web site, please visit the following page;
http://www.dascom.co.uk/printer-drivers/serial-matrix/223-t2280.html
Dec 15, 2009 | Tally Matrix T2280 Printer
Describe your Tally Matrix T2280 Prion power up
Calibrating the temperature resolves the THS error in most cases.
The ‘Temp Cal’ functions can be carried out in the following way;
· Start with the printer powered OFF and at normal room temperature
· Hold down the ONLINE and SETUP button and power the printer back on
· Keep the ONLINE and SETUP button held down until the display reads ‘PRINT TEMP. CAL’ along the top line
· Press the button under ‘TEMP CAL’ (button 3)
· Using buttons 2 or 3 change the Temp Setting to match the temperature of the room the printer is used in (change this value by at least 1 degree even if it is correct to force the printer into recalibrating.
· Then press SET to save the settings.
If the printer continues to display the THS error, the problem can be caused by;
Incorrectly seated print head
Damaged or incorrectly seated head cable
Fault with Main Board, Interconnect Board or the print head.
Jul 09, 2009 | Tally Matrix T2280 Printer
Tally Printer setup
tally packager how to change print area in page set up
Jun 01, 2009 | Tally Matrix T2280 Printer
Talley t2280 sprintpro giving error " Hardware Alarm +0253 094--- 114032+0377+0268
Hai
This is parhtiban
Contact NO : 09663390004
I faced same problem & I solved the issue
Solution : Replace the AGA sensor and AGA flag
Jan 17, 2008 | Tally Matrix T2280 Printer
Tally t2280 does not recognise the page breaks.
self test not printing & printer is offline mode
May 30, 2007 | Tally Matrix T2280 Printer
Labels not centered
Set your paper setting properly. Check the topper form.
Apr 11, 2007 | Tally Matrix T2280 Printer
Tally T2280 SprintPro Matrix Printer
sortcut to setting normal condition
Aug 02, 2006 | Tally Matrix T2280 Printer
Tally Matrix T2280 Printer Logo
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
