Question about Dewalt Saws
Dewalt portaband blade will not stay on saw
I have a dewalt deep cut portaband .the blade will only stay on for about 30 seconds before it tracks off the saw. I put new tires on it w little to no help.
stug_57u
  • 99 Answers
SOURCE: dewalt 708 sliding compound mitre saw
Probably a worn bearing. The only other thing that I have seen cause this is a bent spindle. This would usually occour if the machine has had an impact or if the blade has been suddenly jammed against a nail or something in the work that has caused it to jam and/or jump up.
A good indicator for bearing wear is to see how much play is in the blade in an up/down and side to side movement (unplug saw, safety first).
To check spindle, remove blade and run machine without the flanges etc on. Rest a scredriver gently on the shaft as it spins and see if you notice any (uniform) vibration.
Posted on Nov 01, 2008
the recycler
  • 22 Answers
SOURCE: Porta Band saw blade jumps off
I had this problem on a used model 725 that I bought. Apparently the rubber tires on the drive wheels develop a bit of a memory after sitting for a while with tension on the blade. I tried cleaning the tires to no avail. Then I removed both tires, flipped them over and re-installed. Still not fixed. Then I put only one back to the original position and the problem was solved. Other than the frustration of trying several times, I was out nothing and I got quite proficient at taking the blade in and out. The saw has worked fine ever since. I hope this simple (and free) solution works for you.
Posted on Jan 12, 2009
  • 205 Answers
SOURCE: Blade is walking off the tire.
There should be a tilt adjustment on the TOP wheel, this is what adjusts the tracking (centering of the blade) on the wheels. Watch the tension adjustment too, not enough will allow the blade to walk off
Posted on Apr 04, 2009
rowdy45176
  • 2176 Answers
SOURCE: Dewalt DW733 Bench top thickness planer How to change blades ?
OK you need to go to Dewaltservicenet.com and in the middle of the page at the bottom type in your model number it will take you to another page and then find your type number and click on the instruction manual section on the right side, I clicked on type 2. This manual is about 30 pages long. Let me know if you still need help and if I have helped could you please rate the answer accordingly. Good luck
Posted on Apr 16, 2009
Bati99
  • 88 Answers
SOURCE: Help i need to change my Dewalt DW733 Planer Blades i lost manual
try dewaltservicenet.com They have manuals as well as parts breakdowns.
How do I adjust the tracking on a dewalt portable band saw
TAKE THE PULLEY OFF THE LEFT SIDE AND THE ADJUSTMENT SHOULD BE UNDER THERE
Feb 19, 2015 | Dewalt DWM120 Heavy Duty Variable Speed...
Elu manual
Elu is taken over by Dewalt. I can't find manual online but try to check on Dewalt band saws. ; you can use Dewalt manuals for reference. Are you cutting metal? I use Haltbar 601 series bi metal blade for cutting steels.
Jun 20, 2014 | Saws
Blade walks off the drive wheels
If the blade is walking off the wheels, the wheels are out of alignment with each other. This can be caused by loose screws that hold wheels on their pulley shaft, a worn or lose pulley shaft, worn or broken bearings, ect. Anything that holds or supports the wheels can be lose or worn to the point the wheels are out of alignment which affects the tracking of the blade.
Jan 24, 2013 | Dewalt D28770 Hd Deep Cut Variable Speed...
Bandsaw blades keep popping off,could it be heat related?
Blades slip off the wheels on these saws is because one or both wheels are not turning true to the blade. This can be caused by:
- Missing or worn tires on the wheels. The rubber tires have to be on the wheels and they have to be in good condition.
- Occasionally the screws holding the sprocket on the driven wheel come loose and the wheel will wobble causing the blade to come off.
- Both wheels ride on bearings and shafts that, if seized, worn or broken, will let the wheel wobble enough that the blade won't stay on.
- If the blade is stretched or twisted from use it won't stay on very well.
Aug 06, 2012 | Dewalt DWM120 Heavy Duty Variable Speed...
I have dewalt 18 v circular saw i cut vinyl lattice once and used it on a 2x4 but it wouldnt cut it, started to cut then just stopped. is blade dull already? new saw.
a couple things to look at. Did the saw stop operating or was the blade not wanting to cut. Remove the battery and CAREFULLY feel the blade for dull or broken segments. If the blalde stopped check to make sure not a loose bolt holding it on. Did you reverse the blade for cutting the vinyl. Let me know more information and I will try and help
Feb 02, 2012 | Dewalt 18 V Cordless Circular Saw Model...
I replaced the blade in the dewalt DW716 mitre, now the blade spins slow and trips my breaker??
Hello, W/D here.
Remove your new blade. With the hardware, bolt, washer,blade and cups off, try the saw. If it operates correctly, re-examine how the blade is installed One blade cup goes on, followed by the blade, then the other cup, followed by the washer and bolt assembly. If the cups were in the wrong order, the blade can drag against the frame of the saw, pulling too many amps, and tripping the breaker.
Here is a link to DeWalt. Enter your model # for manual download and exploded diagrams.
http://servicenet.dewalt.com/
Best regards, --W/D--
Feb 07, 2011 | Dewalt DW716 15 Amp 12Inch DoubleBevel...
Dewalt serial number 70170423what year is it manufactured and info about it
Dewalt 790 3.5hp
12" Carbide Tipped Blade
Miter and Compound cutting
12 1/2" Saw Travel
Serial #: 70170423
3450 RPM
Furnacs starter and reset
Steel Table with oak top
Dust Collector sheetmetal thing
120/220 volt
17/8amp
unsure year
Jan 17, 2010 | Dewalt Saws
Blade won't stay in
That the reason we been using clamping collar for all these years.
Sep 09, 2009 | Dewalt DC330K XRP 18v cordless Jig Saw Kit...
Cutting 19mm oak veneered mdf with my new 28v
check to see if u can increase the speed, or try on a thinner piece of wood. or even try a new blade with more teeth.
Aug 13, 2009 | Dewalt DWS520SK Track Saw Kit with Short...
Saws Logo
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
