Gw711 fault code 00100111
Brought my Fisher & Paykel Washing machine out of storage and turned it on. Washer fills to top no matter what level setting and hunts before beeping continualy with the fault code 00100111. Diagnostic paperwork not in console so if anyone has a copy of this it would be appreciated to attain. There is a slight leak by the looks but can't find where from at this stage as well but may be from the over filling.
  • 12 Answers
SOURCE: Fisher & Paykel GW711 Washer
If you brought this machine new, then you should find a service manual under the display panel
You will need to remove the panel, Next to inlet valves you should find a maual in a plastic cover...
Posted on Jul 18, 2008
  • 22 Answers
SOURCE: Fisher and Paykel Washer Leaking
For those with water on floor after wash, check my post on "eco smart won't drain, smells hot". It could be something clogging drainage area at very bottom of the tub. I couldn't see the sock that was stuck in my FP's drain when I looked from the top between the white outer tub and the wash tub--everything looked fine. Then I removed the black motor/white plastic housing piece--Tip back washer and you should see this black electric motor/white housing on bottom. see my post for how to remove and check for plugged drain. it's really pretty easy.
don't know about outer tub holes, but glad i don't have that problem.
i hate my fisher paykel washer/dryer. i can't wait to sell this house--i will leave them here and get a new front load Duette for my next house!
Posted on Oct 21, 2008
SOURCE: Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Posted on Jul 20, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
PSITECHNICAL
  • 71 Answers
SOURCE: my fisher and paykel top loader washing
Disconnect the washer for few minutes (5min) then connect it again and press cancel, before you start any cycle, good luck
Posted on Jan 06, 2010
Fisher & Paykel gw711 excellence keeps filling and overflowing
the clear pressure tube is blocked,
you need to blow air down the clear pressure tube hose.
Jan 30, 2013 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel GW711 stops and starts when filling then beeps continuosly
43. (00101011) Phase 1 to 6 - OOB Switch Fault
The Motor Controller module has found that the signal returning from the out of
balance switch indicates that the switch is permanently on or the harness to it is
disconnected.
Primary Source: Mechanical.
Action:
1) Check that the out of balance switch is free to move.
2) Check that no harnesses are blocking switch movement.
3) Check that the switch operates correctly when activated. Replace the switch
if suspect.
4) If the out of balance micro switch shows signs of corrosion, replace the
switch and switch harness, and fit a condensation kit to the console area if
not incorporated in the top deck.
5) Check the level of the machine and also the bias spring.
Secondary Source: Wiring.
Action:
Check the harness to the switch is connected correctly. The terminals should be
connected to the normally closed position. If the harness terminals show signs of
corrosion, then fit a new harness.
Tertiary Source: Motor Controller module.
Action:
Replace Motor Controller module.
Jan 14, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel washer won't fill - tap keeps turning off
if you mean the inlet valve turns the incoming water of before it fills then you have a fault with one of 2 things. - the water level hose is (blocked) or more so the lower p.c.b board is broken and needs to be replaced as its water level sensor is faulty.
Jul 22, 2010 | Fisher and Paykel GWL11 Top Load Washer
We have a fisher and paykel gw711 washing machine that continues to fill with water while it is in the rinse and spin cycle
Hi Robbie just read your posting.Now just a couple of questions.Does the machine keep filling and flood?Can you manually select the amount of water for the wash --eg-- low, medium,or high?Or does the machine drain and fill at the same time?Please reply with additional information on the questions and I am sure I can rectify this fault for you.
Jul 16, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel mw411 fills but wont wash error code in lights is 00100111
this is faultcode 39 idicates blocked or kinked pressure tube,if this is not th case secondary is fault motor control module >>>
Feb 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
