Question about General Heating & Cooling
How do i get my air condition to be on warm
I have it working on cold, can not find instructions for the settings, to have it n warm as it seems to be cold all the time
RepairUSA
  • 50 Answers
SOURCE: on/off cooling
You will need to replace the outdoor fan and capacitor before it cause damage to the compressor. Thx RepairUSA
Posted on Aug 26, 2007
koolbreezes
  • 540 Answers
SOURCE: Air Conditioning settings
Sorry, but this is a world old problem for ages, ever since there were fat peoples and skinny peoples.. A large person answer is they has more insulation and needs more cooling and a small person has less insulations and needs less air,,,See where I'm going with this? Our answer is to add a dummy thermostat-----(disconnect the control wires to the original thermostat and add the control wires to a new thermostat, out of sight at the return duct close to the unit----or-------add an adjustable grill over each cubicle so they can adjust it them selves to suit each person, and YES itcan be done ...!
Posted on Sep 08, 2008
dgjtex
  • 405 Answers
SOURCE: Front air condition does not blow cold. Rear air condition does
sounds like a damper door in the front not working properly, these are actuated by the front temp control, the door is operated by either a manual cable, and electric actuator, or vacuum. I hope this helps you zero in on your problem. Merry Christmas
Posted on Dec 22, 2008
  • 290 Answers
SOURCE: ford ka heater blows hot air all the time
Taurus does not use a heater control valve. It runs coolant thru the heater core constantly. You may have a temp blend door actuator problem or a plugged up heater core is also very common. Feel the heater hoses, they should both be very hot, it one is much cooler; you can try to back flush the core.
Posted on Mar 26, 2009
SOURCE: Blueway split system wall air conditioning doesn't work properly.
Hi,I have had problems with my Blueway A/C it was very cheap but NASTY,anyway I might be able to help, I made a website with my manual that includes the error codes that I could not find on the net anywhere ,I have also sourced a company in sydney who has spares and have the contact details listed and started a forum that we can help each other out with
Posted on Apr 05, 2009
Passenger side blows cold air--what part could it be
2001 Chevy Tahoe Heat Problem - Tahoe Forum
www.tahoeforum.com > ... > Technical Discussions
Dec 5, 2008 - 10 posts - ‎7 authors 2001 Tahoe, the front heater blows a little hot air when the car warms up and then blows cold air. The rear heat seems to work fine. I changed ...
Rear AC blows hot air - Tahoe Forum - Chevy Tahoe Forum
Jul 14, 2008 - 10 posts - ‎5 authors
On my wifes 03' Yukon the rear air conditioning blows hot air no .... Pull the panel off and look at the hot/cold actuator shown in the picture.
Oct 30, 2015 | 2001 Chevrolet Tahoe
Air conditioner Blows warm air on drivers side but cold on passenger side
Make sure you have the settings to set both sides warm air, if not then you may need to find a tech person to help with the faults.
Sep 14, 2013 | Air Conditioning and Heat for Suzuki Aerio
Lg air condition doesn't work when it is cold outside
Sounds like the crankcase heater. This is likely hooked to a temp sensor that is activated when it gets below a certain temp. There is likely a short in the heater and it trips the breaker. The heater keeps the refrigerant warm inside the compressor when compressor not running. Find a different technician.
May 19, 2017 | LG Heating & Cooling
99 tahoe, rear air is cold, front air is warm, has
either a switch is bad or a electrical operated door failed within the duct work. . This vehicle has the abililty to set a code for this condition and only the dealer and some shops have the diagnostic equipment to diagnose this cortectly the first time.
May 16, 2010 | 1999 Chevrolet Tahoe
No water enters on rinse cycle
I was partially wrong on my diagnosis. No cold water enters on either the wash or the rinse cycles. I also heard odd noises from the inlet valves. I realized the cold water valve was not opening. I've ordered the mixing valve and plan to replace it as soon as it comes in.
May 20, 2009 | Kenmore Washing Machines
Fridgidare, freezer cold fridge warm
sounds like you may have gotten a refridgerant leak causing a low charge condition. some refridgerators have a evaporator fan if this quit working it will cause it to freeze up .thus the freezer does not use a fan and it will still get cold
Jan 05, 2009 | Frigidaire FRS26ZSG
Air Conditioning
Try changing the lower temp sensor in the air duct on the drivers side. I bought one and never replaced it. before the part arrived I took the lower sensor out and taped it up and put it back under the dash... not in the air duct housing were it belongs. believe it or not it works so well I did not even see a need to change the thing.
Jun 22, 2008 | 2001 Cadillac DeVille
Fan setting only works
Air Conditioners have a fan speed relay built in the unit, faster for cold air and slower for warm heated air. It is very possible that your relay is defective
Oct 20, 2007 | Ruud UAMB Air Conditioner
Heating & Cooling Logo
13 people viewed this question
Top General Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Bill Long
Are you a General Heating and Cooling Expert? Answer questions, earn points and help others
