Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Side door will not shut properly
After a paper jam the side door will not shut properly as if something is caught or not inserted correctly. The green tabs on top - one will push down the other one will not, as appears to be stuck in the upward position
  • Konica Minolta Master
  • 6,168 Answers
Then replace the fuser unit
Posted on Jan 18, 2016
3 Suggested Answers
  • 118 Answers
SOURCE: my magicolor 2530 dl printer keeps jamming
It is very difficult to remove the fusers. I did this once, and it was enough. Essentially, you must take the machine apart enough to release the metal sides enough to lift it out. Your best bet is a samll pair of medical hemostats and the green tabs up to release pressure. Dont use tweezers, because if you nick the red roller (it is soft) you will have blemishes from that fuser forevermore. I can mail you the manual if you wish to try. My mail is dhudson at Gmail, mprivate message me and I can send it as an attachment.
Posted on Apr 20, 2009
xeerie
  • 347 Answers
SOURCE: Konica Minolta 2400w paper jam at top back side.
yes there is a way, but if you do it yourself there are more chances that you will break it.so dont try it yourself.call concerning technical service rep.
Posted on Jun 19, 2010
Hpc6280 paper caught internally
This information comes from the User Manual on pages 111-112:
http://h10032.www1.hp.com/ctg/Manual/c01150745.pdf
Internal paper jams on this machine tend to be in the two-sided printing accessory.
To clear a paper jam from the two-sided printing accessory:
1. Turn off the printer
2. Press in the tabs on the left and right side of the two-sided printing accessory, and remove it by pulling out from the center of the printer.
3. Gently pull the paper out of the rollers. If the paper has torn, check the rollers and wheels for small, torn pieces of paper
4. If it's still not clear, open the two-sided printing accessory by pulling up on the tabs, and remove any paper stuck inside it, then close the accessory by pressing down on the tabs until they lock into place
5. Replace the two-sided printing accessory by pushing it forward until it snaps back into place
6. Turn on the printer, and verify that it works by pushing OK to continue the job it jammed on.
Feb 27, 2014 | HP Office Equipment & Supplies
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
Printer can't receive 250gram photo paper. I get
If you put your hand inside there will be a paper picking Roller (rubber) clean them with the spirit ..
or with the wet Towel ..
which will solve your issue
if still not then follow the paper Jam steps - cleaning the rubbers when you open the rear
1. Turn off the product and unplug the power cord.
2. Turn the product around to access the back of the product.
3. Open the rear access door:
1. Locate the tab on the left side of the door and press it toward the right. The door will shift slightly to the right.
2. As the door shifts to the right, pull the door out slightly to release.
3. When the door is released, gently remove the door by sliding the door out and to the left.
4. From the rear access opening, gently pull the jammed paper out of the rollers.
NOTE: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the product. If all the pieces of paper are not removed from the product, more paper jams are likely to occur.
5. Replace the rear access door:
1. Insert the two posts on the right of the door into the holes on the right side of the opening.
2. Press the tab on the left side of the door toward the right. The door will shift slightly to the right.
3. As the door shifts to the right, push in the left side of the door to lock it into position.
6. Reconnect the power cord and turn the product on.
Jan 03, 2010 | HP PSC 2355 All-In-One InkJet Printer
I had a paper jam and I took the back off and this
Step one: Remove any loose paper
Remove all loose paper from the input and output trays.
1. Turn off the product.
2. Unplug the power cord from the back of the product.
3. Push the button on either side of the rear-access panel or the duplexer (two-sided printing accessory) and then remove the panel or duplexer.
4. Find any jammed paper inside the product, grasp it with both hands, and then pull it out of the product, toward you.
5. If the product has a duplexer, push the latch on the top of the duplexer and lower its cover.
6. Carefully remove any jammed paper.
7. Close the cover.
8. Reinsert the rear-access panel or the duplexer into the product.
9. Plug the power cord back into the product.
10. Turn on the product.
Step three: Open the top cover and clear the jam
3. Open the carriage access door. The carriage moves to the right side of the product.
4. Gently pull the paper out of the rollers.
5. After clearing the jam, close the carriage door.
6. Plug the power cord back into the product.
7. Try printing a document.
· If the issue is resolved, do not continue troubleshooting.
· If the issue continues, proceed to the next step.
Step four: Clear the jam from paper tray 1
1. Remove all paper from the output tray.
2. Turn off the product.
3. Unplug the power cord from the back of the product.
4. Lift the output tray and then check for jammed paper in input tray 1.
Use these steps to remove any jammed paper.
a. Raise the output tray.
b. Grasp the jammed paper and pull it out of the product, toward you.
c. Lower the output tray.
5. Plug the power cord back into the product.
6. Try printing a document.
· If the issue continues, and if paper tray 2 is not installed on the product, proceed to 'Step six: Clear the jam from the automatic document feeder (ADF).'
· If the issue continues, and if paper tray 2 is installed on the product, proceed to the next step.
Step five: Clear the jam from paper tray 2
4. Lift the product off tray 2.
5. Remove the jammed paper from the bottom of the product or from tray 2.
6. Reposition the product on top of tray 2.
7. Plug the power cord back into the product.
8. Try printing a document.
3. Remove the ADF input tray and open the ADF cover.
4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside.
5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open.
6. Check the ADF paper path for jammed paper.
7. Check for jammed paper where paper enters the ADF paper cleanout.
o If the paper comes out with gentle pulling, proceed to step 9.
o If the paper does not come out with gentle pulling, follow these instructions.
1. Open the ADF, and then use both hands to gently loosen the paper.
2. When the paper is free, gently pull it out.
3. Close the ADF.
8. Lower the green lever.
Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
9. Replace the ADF input tray.
10. Check the following to make sure that the ADF frame and parts are secure and correctly set up.
o Make sure that the ADF frame is secure and attached correctly.
o Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
o Make sure that the ADF pick mechanism is secure. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open.
Make sure that the two-catch is holding the roller mechanism securely in place and that the stack stopper is in the correct position.
1 - Stack stopper
2 - Two-catch
11. Plug the power cord back into the product.
12. Turn on the product.
13. Try printing a document.
Jan 01, 2010 | HP Officejet Pro L7680 All-In-One Printer
Hp LaserJet 4100 printer says its out of paper which is not the case, could someone assist me and figure what may be causes this problem? Thanks in Advance
Paper jams can occur in the following areas
1 Top cover and toner cartridge area
2 Optional envelope feeder
3 Input tray areas
4 Optional duplexer
5 Output areas (top and rear)
6 Fuser area
Solving repeated paper jams
* Check all the paper jam locations. A piece of paper might be stuck somewhere in the printer. Even a small torn piece of paper in the printer path can cause repeated jams.
* If using a duplexer, check all areas (including under the duplexer).
* Check that paper is correctly loaded in the trays, that all three adjustments have been made, and that the trays are not overfilled. Make sure paper is under the front and back tabs.
* Check that all trays and paper handling accessories are completely inserted into the printer. (If a tray is opened during a print job, this might cause a paper jam.)
* Check that all covers and doors are closed. (If a cover or door is opened during a print job, this might cause a paper jam.)
* Try printing to a different output bin.
* The sheets might be sticking together. Try bending the stack to separate each sheet. Do not fan the stack.
* If you are printing from tray 1, try reducing the size of the stack.
* If printing from the envelope feeder, make sure it is loaded correctly, pushing the bottom envelopes in slightly farther than the top envelopes.
* If you are printing small sizes, feed paper short edge first.
* Turn over the stack of paper in the tray. Also try rotating the paper 180°.
* Check the characteristics of the media you are using. Use only paper that meets HP specifications (see the online user guide for paper specifications). Try using different paper to see if the problem goes away. Do not use curled, deformed, damaged, or
irregular paper.
* Avoid using paper that has already been used in a printer or copier.
* Do not print on both sides of envelopes or transparencies.
* Print only on full sheets of labels and do not print on both sides of label sheets.
* Check that the power supplied to the printer is steady and meets printer specifications (see the online user guide for printer specifications).
* Clean the printer (see the online user guide procedures).
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 09, 2009 | HP LaserJet 4100 Printer
I have xerox workcentre xd105f, can't make copies, paper jamed and letter P on display
to remedy the P display error remove the paper tray and take any paper from under the tray and between the rollers, clean the rollers with alcohol or an acetone solution to remove paper dust and paper debris, refit the paper tray with the paper pushed below the tabs on the tray ensuring that the correct paper size is shown, IE: ltr ltr-r etc.
power the unit off and on and you should be back in business.
If this remedies the problem please rate the solution accordingly
thanks
Derek
Jun 19, 2009 | Xerox WorkCentre XD105F Laser Printer
My NEC 870 laser printer has paper jam. How can I fix it?
Open the top printer door by pressing the round release button on the left side of the printer. Remove the toner cartridge (numbered 2) and the photoconductor cartridge (numbered 1) from the printer. This will give you full access to the paper path and you should be able to remove the jammed paper. If you pull on it and it begins to tear or is feels like it is caught on something, remove the paper and paper tray from the front of the printer and try to reach and remove the jammed paper pulling it back out the direction it went in.
With the jam removed, replace the paper tray and paper, re-install the photoconductor (#1) and the toner cartridge (#2) into the printer and close the top door. Make sure you get the door closed firmly and that it catches otherwise you will still have an error light and not be able to print.
That should fix your problem... good luck! :-)
Jan 31, 2009 | NEC SuperScript 870 Laser Printer
Paper jam
This video explains how to resolve a recurring paper jam on your product. It sounds like the rollers on the rear access door may not be working properly and are making jamming the paper as it starts to feed up into the printer? Check the rollers on your rear access door and see if they have some give in them and roll freely.
Sep 27, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP PSC 2355 All-in-One Operating Problem
Introduction When the all-in-one detects a paper jam, the display will read, " Paper jam: Press OK to continue ." The computer might display the following message: " There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. " This document will assist in correcting paper feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. Clearing paper jams CAUTION: All paper jams must be removed from the back of the all-in-one through the rear access door. Pulling the paper from the front of the unit rotates the paper feed roller in the wrong direction and can cause damage to the all-in-one.
  1. Turn off the all-in-one and unplug the power cord.
  2. Turn the all-in-one around so the back of the unit is facing out.
    Figure 1: Removing the rear access door c00212276.jpg
  4. Inspect the pressure rollers on the access door. They should be clean and rotate easily. If needed, clean the rollers with a soft lint-free cloth lightly moistened with water (distilled water preferred). If the rollers do not rotate easily, they may need to be replaced.
  5. From the access door opening, gently remove the jammed paper.
  6. Remove the paper stack from the paper supply tray. Discard any paper damaged or bent.
  7. Re-stack the reload the paper into the paper supply tray. Push the stack into the tray until it stops.
  8. Re-seat the rear access door:
    1. Insert the two posts on the right of the door into the holes on the right side of the opening (as shown in the figure below).
    Figure 2: Rear access door posts c00212277.jpg
  9. Reconnect the power cord and turn on the unit.
Causes of recurring paper feed problems If paper feed problems occur repeatedly, one of the following might be the cause:
  • Something is obstructing the paper or print cartridge path. Open the cover of the all-in-one and check for obstructions.
  • The rear access door is unlocked or improperly seated. Follow the steps above to remove and re-seat the access door.
  • The paper width guide is not positioned against the paper. Adjust the paper width guide against the edge of the paper.
  • The paper is not supported. Paper should be flat and smooth with no folded, torn, or rough edges. Some glossy and/or coated papers, or reused paper (already printed on one side) can experience a higher incident of paper feed issues.
  • The paper tray is not fully extended.
  • The paper feed rollers need cleaning. Over time paper fibers and dust will stick to the rollers and should be removed. See instructions for cleaning the rollers below.
Paper jam message displays but no paper is jammed The print carriage might be jammed. Follow these steps to correct the problem:
  1. With the power on, lift the print cartridge access door. The print carriage should move to the access area located on the right. If the print carriage stays all the way left, reset the unit by unplugging the then plugging in the power cord. If the carriage still does not move to the right, continue with the steps below.
  2. Disconnect the power cord from the all-in-one.
  3. Remove both print cartridges.
  4. Push the print carriage slightly to the left and then to the right to verify that the print carriage is not jammed. If the print carriage will not move, check for obstructions under and around the carriage.
  5. Close the print cartridge access door.
  6. Plug in the power cord.
  7. When the " Insert Print Cartridges " message displays, open the print cartridge access door and insert the print cartridges. Verify that both cartridges are seated correctly and lock into position.
  8. If the error recurs, contact HP for assistance.
Envelopes The envelope flap can move with the grip of the rollers and cause paper feed problems. Use envelopes with a rectangular flap and/or tuck the flap inside the envelope when printing. The print is skewed or crooked A small amount of skewing is not unusual with printers. When there is too much skewing, the following steps can help reduce the amount.
  1. Adjust the paper width guide to fit against the edges of the paper stack.
  2. Verify that the rear access door is properly seated and locked into position.
  3. Remove the rear access door and clean the paper feed rollers (see the instructions at the bottom of this document).
More than one sheet of paper feeds in at the same time Several paper caused problems can result in more than one page feeding into the unit. Check the list below:
  • Reused paper (paper already printed on one side)
  • Torn or folded paper
  • Textured or coated paper
  • Unsupported specialty paper
To determine if the paper is causing problems, try using clean, undamaged sheets of plain white 70 - 90 g/m2 (20 - 24 pound) inkjet paper, such as HP Multipurpose or Bright White paper. If this paper feeds correctly, the problem is probably with the other paper. Cleaning the paper feed rollers Over time dust and paper fibers will accumulate on the paper feed rollers. This can cause paper feed problems. Follow the steps below to clean the rollers: Figure 3: Paper feed rollers c00212278.jpg
  2. Remove the rear access door (as describe above in this document).
  3. Clean each roller using a clean lint-free cloth lightly moistened with water (distilled water preferred). Rotate the rollers to clean the entire surface.
  4. Verify that the paper feed rollers on the rear access door are clean and rotate easily.
  5. Re-seat the rear access door.
  6. Plug in the power cord and turn on the all-in-one.
Jun 29, 2008 | HP PSC 2355 All-In-One InkJet Printer
Laserjet 1100 printing from wrong location
there is a tab I believe on the left front that you can flip up for the paper to exit on top or down so the paper exits down
thanks for rating
Jan 15, 2008 | HP LaserJet 1100 Printer
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
27 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
