Question about Siemens Washing Machines
Siemens siwamat xs 432
Hi my washing machine doesn't like to complete the program. After rinsing water remain inside an spinning is not starting. I tried different programs but is same story. Any ideea? Thanks.
  • 183 Answers
SOURCE: Flashing Lights on Ariston A1636 & Won't progress to rinse either
Suggest checking for a faulty heater. Regards Engineer
Posted on Jul 29, 2007
jyackle5
  • 8197 Answers
SOURCE: my siemens washer will not pump the water out or spin
Sounds like your pump went out on the machine. They are not ease to replace though. You might want to kall some one out to fix.
Posted on Dec 16, 2008
michiganfan9
  • 179 Answers
SOURCE: Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
Posted on Dec 29, 2008
barkencoa
  • 3463 Answers
SOURCE: Creda Simplicity 1000 Washing Machine not heating water
Make sure that you have not got the energy save button in operation, as this by-passes the heater, and will wash at the incoming water temp. It should not be showing green
If this is not the case, then the heater has probably failed.
To access the heater, you need to remove the top cover, remove the soap dispenser drawer, and undo the 4 screws securing the console panel to the top of the washer.
Pull off the timer knob, noting the position of it, and slide the console panel to the right, support it with something.
Remove wire cllip holding door seal to front of panel, and pull off the seal at the front.
Undo the screws securing the front panel at the top.
Undo 3 screws at bottom of front panel.
Lift front panel clear,and stand it at the right of washer, be careful of the wires still attached to the door lock.
At the bottom, in the center, you should find a black cover, remove that, and you will see the heater element.
You eally need a meter to test it for continuity, and or an earth fault.
Replace if faulty.
Please leave a fixya rating for my suggeted solution.
Thankyou.
Posted on Feb 10, 2009
  • 3 Answers
SOURCE: hoover optima hnf6167 7kg washing
My washing machine completes its cycle but is leaking water from the left hand side on to the floor, Why is this???
Posted on Apr 25, 2010
How do I use the washer and dryer on Siemens siwamat xs 1047
put clothes in,put soap in,choose hot or cold,choose what cycle,press start
Jul 29, 2015 | Siemens Washing Machines
Siemens E14-16 Washing machine is not taking the softener when rinsing and posibly not rinsing completely. the dispenser drawer is clean and flows correctly when filled with water. I have checked the...
Same problem with same Siemens E14-16
Cleaned soap drawer inside out (no more black gunge) but still full of conditioner after full cycle and rinse despite 2 internal valves completely cleared and connected
What could be wrong ?
Feb 13, 2012 | Siemens Washing Machines
Siemens siwamat 6142 loops in cycle 1. my machine stays in cycle 1 (washing). after the timer goes down to 1 minute, the program restarts and it still stays in cycle 1. thanks!
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Aug 09, 2011 | Washing Machines
Hi there does the siemens siwamat 6102 washing machine have an hot water inlet valve, Regards Robert
Yes - mine has just frozen in the garage and cracked whilst defrosting. Water everywhere. Does anyone know if I can bypass it and run the M/C on cold only?
Nov 25, 2010 | Washing Machines
My siemens WD1252 doesn't change from wash to rinse
Hallo,
I have the same problem since yesterday. I've seen that probably it doesn't warm up the water. If I change washing temperature to "cold" everything works normally. I think that heater is broken.
Have You resolved your problem? Have You called service?
Best regards.
Bartosz
May 01, 2010 | Siemens WDi1640 Front Load Washer / Dryer
My siemens washer will not pump the water out or spin
Dec 16, 2008 | Frigidaire ATF6000ES Front Load Washer
SIWAMAT 6102 (GB) Code 3 Flashing. What does this error mean
The pump was working but not pumping. The rubber hose from the bottom of the drum to the pump was removed and found to be partially blocked. The debris inside the rubber hose was cleaned out and reassembled with no further problems.
Sep 07, 2008 | Siemens Washing Machines
Siemens Siwamat XL1480
there is a large possibility that the water is not able to be pumped out in between the rinse cycles therefore I would get a friend to blow down the water outlet pipe to check if its clear you should be able to tell if its so, or the water pump is jammed or brocken hope this helps a little eric
Dec 09, 2017 | Siemens Washing Machines
Washing Machines Logo
85 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
