Question about Siemens GIGASET-A58H GIGASET-A58H
Where do I find call divert - Siemens GIGASET-A58H GIGASET-A58H
I have BT line and have call divert but can't remember how to divert calls, HELP please
Check which services are active [System X] *#001#
Charge advice (before call) *40* (Number)
Charge advice (All calls) *411#
Charge advice (During call) "R"(to hold call) *40#(Call will be reconnected)
Cancel all calls charge advice #411#
Reminder call *55*(Time in 24 hour format)#
Cancel reminder call #55#
Call Divert - all calls - activate *21*(Number to divert to)#
Call Divert - all calls - to check *#21#
Call Divert - all calls - to cancel #21#
Call Divert - on busy - to activate *67*(Number to divert to)#
Call Divert - on busy - to check *#67#
Call Divert - on busy - to cancel #67#
Call Divert - on no reply - to activate *61*(Number to divert to)#
Call Divert - on no reply - to check *#61#
Call Divert - on no reply - to cancel #61#
Call waiting on *43#
Call waiting off #43#
Call waiting - to check condition *#43#
Call waiting - to answer 2nd caller Recall + 2
Call waiting - remove beeps during call Recall + 0
"Ring back" (Camp on busy) 5
Cancel ring back #37#
Caller display on *234#
Caller display off #234#
BT call minder (voice mail) 1571
Check called number 1471
Release CLI 1470 + dialled number
Withhold CLI 141 + dialled number
Access "Choose to refuse" 14258
Call barring on (outgoing) *341 + option number #
(options are 1 = allows 999 and operator, 2 = allows 999 & local, 3 = allows 999 & STD, 4 = bars all operator calls, 5 = bars *, 6 = bars premium adult lines, 7 = bars premium information lines)
Call barring off (outgoing) #341*(PIN code)#
Incoming calls barred off [System X] #261#
Incoming calls barred on *261#
Incoming calls barred off #261*(PIN code)#
Feb 19, 2015 | BT Lands Phones
Why won't phone ring on incoming call?
Has this always happened?
Does it happen every single time? are you in cellular coverage, or does it happen only when you are in certain areas?
Have you got your call diverts set up correctly?
1. Find "Keypad"
2. Choose option
  • Choose one of the following options:
    • Divert all calls, go to 2a.
    • Divert missed calls, go to 2b.
    • Divert if unavailable, go to 2c.
    • Divert if busy, go to 2d.
2a - Divert all calls
  • Key in **21*+61411000321#
  • Tap Call.
2b - Divert missed calls
  • To select how long you want your mobile phone to ring before the call is diverted:
    • Key in **61*+61411000321**the required number of seconds#
  • Eg.:
  • Tap Call.
2c - Divert if unavailable
  • Key in**62*+61411000321#
  • Tap Call.
2d - Divert if busy
  • Key in**67*+61411000321#
  • Tap Call.
3. Return to the home screen
Jun 07, 2014 | Apple iPhone 5c
Replace diverter in 2 handle aqua source kitchen faucet
For a dual-handle Aquasource kitchen faucet with spray hose, the following instructions will afford replacement of the diverter. These instructions specifically refer to the faucet illustrated at http://pdf.lowes.com/installationguides/6953123900358_install.pdf, and the diverter identified as part RP70007 (item 14). Note the position of notches at the top of the diverter and around the rim of the base of the diverter, either of which can be used to leverage a tool to rotate the diverter out of position. Caution: The diverters on older faucets may be exceptionally brittle and thus very difficult to remove.
1. Using a pipe wrench or similar large-mouth wrench, unscrew the base of the faucet. Wrap the base with a cloth or other protective material to prevent scratching during the process of unscrewing. The base unscrews in a counter-clockwise direction.
2. With the base removed, remove the faucet. Note that a small amount of water may drain from the faucet when removed.
3. Removal of the base reveals the top of the diverter, which is a white, plastic cylinder approximately two inches long with copper stopper in the bottom. Insert a wide, flat-blade screwdriver across the notches in the top of the diverter - but be *extremely* careful. A faucet that has been installed for some length of time may have an exceptionally brittle diverter. If the upper shaft of the diverter breaks, a pair of needle-nose pliers may be used in the notches around the *base* of the diverter. Carefully rotate the diverter counter-clockwise to remove it.
4. Insert the new diverter and screw it into place in a clockwise direction. Apply a wide, flat blade across the notches in the top of the diverter to apply slight additional pressure to tighten the diverter just beyond hand-tightness.
5. Re-insert the faucet.
6. Screw the base back into position, tightening as necessary.
7. Test the operation of the diverter by operating the cold and/or hot water faucets, then the spray handle.
Dec 24, 2012 | Plumbing
How to divert call 5530
Call - Divert.This feature allows you to divert an incoming call to a landline or to any cellular. This way you don't miss out on any important incoming calls. Calls can be diverted when you are busy, unavailable or travelling. The call can be diverted to any landline or cellular within the service provider's network area. Calls cannot be diverted to a cellular of another service provider.
From your Handset menu -
* go to call Divert/Forward.
* choose the option you want from the following.
* enter the number you want to forward the call to.
Options: You can choose from 4 types of Call Divert services:
1. Call Divert on "not reachable" : Diverts calls automatically to your chosen number when you cannot be reached - such as when your phone is out of network coverage, has a no battery charge or is turned off.
2. Call Divert on "busy" : Diverts calls automatically to your chosen number when your phone is engaged.
3. Call Divert on "all calls" : Diverts all calls to your chosen number. If this option is set, you will not receive any calls on your mobile phone till you have cancel Call Divert "all calls" facility.
4. Call Divert "if no reply' : Diverts calls to your chosen number when you do not answer the phone for a specified number of rings, (you can define the number of rings).
Hope it helped out.Please don't forget to rate me thanks alot..
Feb 01, 2011 | Nokia 1112 Cellular Phone
Nokia active incoming call diverts problem:
I hope you have activated your call divert function so your are not able to get the incoming calls.
To deactivate the diverts,
Menu > Settings > Call > Call divert > No Call Divert.
Select No Call Divert it will deactivate all the call diverts and now you can get the incoming calls.
Thanx
Aug 04, 2010 | Nokia 6300 Cellular Phone
What does fault code 51 mean?
Error code 51 usually means a faulty diverter valve. Try and run a wash cycle, and observe the drain hose. If water comes out, the diverter valve should be fine, if no water comes out you should take your diverter valve out and check for debris, or continue to read through the following possibilities of why your washing machine is acting up, and the actions to take.
1. Diverter valve
Action - Check diverter valve continuity. If open circuit, replace diverter valve.
2. Motor Controller Board (drive circuitry blown).
Action - Replace Motor Controller Board
3. Diverter valve harness/connectors.
Action - Replace wiring harness
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
How does one tgransfer an incoming call from one phone to another?
You don't need a "generic Compaq PC laptop" to do this.
Press the "transfer" button on the base-station,
and then dial the 3-digit or 4-digit "extension" for the person.
Your office PBX (Private Business eXchange) box will handle the rest.
Nov 20, 2009 | Computers & Internet
How do i use the call forward option?
Call forward or call divert, the same features just different names in some models of phones. Only the name of the service says that it is diverting calls. There is 4 situations for activation and can be activated via the mobile device or directly by entering codes on the display phone. The function codes and their ability to use depends on the network operator.
Codes:
** 21 * number that diverts calls with code of network operator # OK, yes or call it will divert all incoming calls unconditionally
##21# ok, yes or call it will deactivate this divert.
*#21# ok, yes or call it will check status.
** 61 * number that diverts calls with code of network operator # OK, yes or call it will divert incoming calls when you do not want or can not answer the call
##61# ok, yes or call it will deactivate this divert.
*#61# ok, yes or call it will check status.
** 67 * number that diverts calls with code of network operator # OK, yes or call it will divert incoming calls when your line is busy ##67# ok, yes or call it will deactivate this divert.
*#67# ok, yes or call it will check status.
** 62 * number that diverts calls with code of network operator # OK, yes or call it will divert incoming calls when you are unavailable ##62# ok, yes or call it will deactivate this divert.
*#62# ok, yes or call it will check status.
##002# ok, yes or call it will deactivate all divert.
If the codes not working you have that option in your phone, it is in call settings. You choose option and then insert a number for diverting calls.
This service is not free, and you must contact your network operator for prices.
By!!!
Nov 03, 2009 | LG VX5400 Cellular Phone
My n95 keeps making an engaged tone and saying 'diverts active'? how do i stop it?
Its showing Active diverts because your call diverts is active. May be you have set a call diverts where if you are unreachable your calls gets transfered to voice mail. To deactivate Active diverts. Go to Tools -> Settings -> Call Diverts -> Options -> Cancel all diverts
Hope this helps.
Oct 20, 2009 | Nokia N95 Cellular Phone
Tone And Message
Call Divert
The GSM standard knows two kinds of call divert:
  • Unconditional call divert
  • Conditional call divert
Conditional call divert occurs on any of three conditions:
  • Divert if no answer after 'x' seconds
  • Divert if unavailable (cellphone switched off or out of range)
  • Divert if line busy
Furthermore, the GSM standard knows three different types of call:
  • Voice call: normal communications when you pick up the phone to talk to someone.
  • Fax calls: the GSM terminal being called is a fax machine.
  • Data calls: your cellphone is acting as a modem hooked up to a computer accepting inbound data from elsewhere.
Each call type is assigned a number: 11 for voice calls, 13 for fax calls, 25 for data calls.
You can activate or cancel conditional call divert on your device. To do so:
##62# : Cancel divert for all call types
##62*11# : Cancel divert for voice calls
##62*13# : Cancel divert for fax calls
##62*25# : Cancel divert for data calls
This code does not hurt your device only helps it to tell it what to do in certain situation of a voice, data, or fax call.
This is a link to a site which goes a little more in depth with the meaning of conditional/unconditional call diverting is. Hope this helps!!!
Dec 17, 2008 | LG CE110 Cellular Phone
Siemens GIGASET-A58H GIGASET-A58H Logo
Top Siemens Lands Phones Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
