Question about Ingersoll Rand Air Tools & Compressors
Ingersoll Rand UP 5 18 7 Screw Comp check motor rotation problem
  • 44 Answers
Check transducer from the inlet side
Posted on Nov 26, 2014
hdpanama
  • 65 Answers
SOURCE: ingersoll rand air compressor 185
How old is the compressor ? This trouble shooting is directed to the vane and screw types of air compressors.
Caution,
For exact information on the equipment you are working on, go to the manufacturer’s maintenance and repair manual.
Here are some possibilities.
Compressor does not reach design pressure or capacity:
Air Pressure safety valve is leaking
Receiver air valve is open
Unloader valve is leaking
Loose Piping or fittings
Compressor will not load or unload:
Unloader valve defective
Air control valve is sticking or dirty
Unloader pressure is improperly set too high or too low
Water in the control lines
Plugged control lines
The air compressor CFPM is low:
Dirty air compressor air filter
Defective air intake control valve
High idle on power source improperly set
Damaged or worn rotor blades
Posted on Nov 25, 2008
  • 1383 Answers
SOURCE: Honda 5.5 hp air comp. no spark wont run
Most honda engines have an oil sensor that prevents the engine from starting if the oil level is low or oil is dirty. Test coil by disconnecting oil sensor wire. With sensor disconnected coil should fire. If still no fire, check kill wire for short. If still no spark, coil may need to be replaced. enjoy
Posted on Nov 29, 2008
  • 5 Answers
SOURCE: I wish to rewire a single phase electric motor
The motor itself should have a sticker which describes the wiring for 115. It is a small change involving a single wire moving from one pole to another inside the motor starter cap (the bump on the motor itself).
Posted on Aug 29, 2009
SOURCE: ingersoll Rand SSR compressor shuts down loaded or
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Posted on Sep 25, 2009
  • 243 Answers
SOURCE: i have an ingersoll rand P185WJD Compressor that
possible that one of the protections switch it off check oil levels motor and screw can also be a sensor, can check these by briging them one by one. first indication is control lamp. or possible fuel problem check filters and tank. also check wiring complete. is weak point for ir machines. good luck.
Posted on Feb 10, 2010
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
Ck mtr rotation fault Ingersoll rand EP60
Check and release internal pressure that's what gives rotation fault on startup
Mar 12, 2015 | Ingersoll Rand Air Tools & Compressors
WHY DOES A SM75 INGERSOLL RAND COMPRESSOR CUT OUT ON LOW PRESSURE OIL
Low oil pressure. Are you adding a lot of oil. Have you check the oil level. Switch could also be bad.
Dec 08, 2014 | Ingersoll Rand Air Tools & Compressors
Does it have any arrow located on the compressor showing its roation
motor rotation is ok but any other options for check this reason ?
Mar 22, 2013 | Ingersoll Rand Tools & Hardware - Others
I have a Ingersoll Rand en6f75 compressor. Does it have to run in a particular direction as I cannot see any direction arrows on it.
We provide tech manuals for all of our products at www.irtechpubs.com. We also supply technical information on our website www.ingersollrandproducts.com. Hope this is helpful.
Ingersoll Rand Employee
May 13, 2011 | Ingersoll Rand - Rand Type - 30...
I have an ingersoll-rand upright compressor model 2545k10-p, 10 hp, 120 gal, 175psi compressor, and the electric motor will run for about 15-20 seconds and then automatically shut off, and be really hot....
Does the motor rotate the compressor or just set there and hum? How old is this unit? Overload heaters may be to small or unit may be single phaseing. Is there air pressure in the tank when this happens.
Oct 15, 2010 | Ingersoll Rand Stationary Air Cooled...
I have an ingersoll rand P185WJD Compressor that
Feb 10, 2010 | Air Tools & Compressors
Air Tools & Compressors Logo
159 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
