Question about Harman Kardon Harman HK 990 Amplifier
Hk990 left channel dead
I see on the internet that there has been a number of problems with the harman cardon HK990 - Left channel dead. - Currently I have the same problem with my HK990. - Any ideas of the problem?
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 64 Answers
Return to factory setting may not be mentioned in the owner manual but this is how it's done. Put the amp in st.by mode, push "Speaker 1" & "Level settings" simultaniously for about five sec. The dispaly will than blink and after a minute or so it will say "default param.recalled". Than pull out the cord from the outlet and leave it out for 30 sec. before reconnect. Than turn on the amp and your back to factory settings.
Posted on Apr 02, 2016
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Harman Kardon Master
  • 924 Answers
It is unlikely that your have a damaged amplifier. You may have something switched wrong. In your owner's manual, you will find a procedure that says' "Return to factory defaults, or just reset". If that doesn't resolve your issue, or you need more assistance, or would like to inquire about a repair, please visit my website at audioserviceclinic.com. You may contact me there. BTW, I worked at HK. Thank you.
Posted on Nov 30, 2014
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: How are you? For HK990,How to do bi-wiring
Sabve your money - it's BUY-wiring.
http://www.harmankardon.com/EN-US/Products/Pages/ProductDetails.aspx?PID=HK+990
http://www.harmankardon.com/resources/Brands/harmankardon/Products/ProductRelatedDocuments/en-US/OwnersManual/HK%20990_OM.pdf
Bi-wiring does nothing but make you use twice as much speaker wire for the same electrical effect. Bi-amping assumes there are deficiencies in your electronics that must be worked around, again by using more speaker wire and separate amps.
Do some reading on the web about "bi-wiring".
Posted on Jul 16, 2011
I have a Harman Kardon HK990 which throws an error #005 if I switch it on with a digital input connected. If digital input is not connected, it turns on without any error and all buttons work as expec
If you had a bad amplifier, as suggested, the unit would most likely have a condition known as DC Offset. In this case, the amp would immediately shut off. As you said, the amp stays on, but you have no sound. First thing I suggest, turn the unit off. Listen carefully to the top of the amp. When you first push the power button, you should immediately hear one click, followed by a second click, within 5-20 seconds. If you hear that second click, you amp is likely not bad. If you don't, then you do most likely have a blown amp, with engages the DC Protection circuit to the microprocessor(computer within your unit).
Next step is to open your owner's manual. In there, you will find a procedure called, "Return to factory reset, or default". Follow that procedure, to reset the unit back to the factory settings. Those inputs are assignable, meaning that you can make certain inputs, analog or digital. You may have set one wrong by mistake. The reset will fix that. If you need more assistance, or would like to inquire about a repair, please visit my website at, Audioserviceclinic.com. By the way, I worked for HK, JBL and Infinity. Thank you.
Nov 28, 2014 | Harman Kardon Harman HK 990 Amplifier
I have a Harman Kardon HK990 which throws an error #005 if I switch it on with a digital input connected. If digital input is not connected, it turns on without any error and all buttons work as expected -...
1.Is the fault caused by an optical or coaxial input or both?
2. Have you tried a Firmware Reset? (press "Level Settings" button & "Speaker 1" together.
3.Do you have a Service Manual (I have pdf!)
Amplifier protection mode
use speakers withwith higher impedance, the sound is low but protected
Nov 03, 2012 | Harmon Kardon Harman Kardon HK990 2x150...
Left channel don't work
The IC in it is fied for the left channel.
Oct 29, 2012 | Harman Kardon HK 3370 Receiver
How are you? For HK990,How to do bi-wiring connection of the speakers? thanks
Jul 16, 2011 | Harman Kardon Harman HK 990 Amplifier
It runs so hot why?
Possibly lack of ventilation or excessive volume through difficult speaker loads.
http://media.onecall.com/Image_Products/Harman%20Kardon/harman-kardon-hk990.pdf
See page 6.
IMPORTANT: When connecting two pairs of speakers, determine the impedance of each pair
by looking on the back of the speakers, in your owner's manual, or by contacting your dealer or manufacturer.
You can listen to two pairs of speakers at the same time ONLY if the impedance of EACH speaker is NOT LESS THAN 8 Ohms.
WARNING: Do not play sets of speakers simultaneously except as recommended above.
Amplifier may overheat.
Jul 09, 2011 | Harman Kardon Harman HK 990 Amplifier
Average cost for a cv joint on honda accord 1998
there are tow types, with ABS and W/O ABS, they come as a half shaft assmebly, this is a axle and CV joint together. here are the 2 part numbers for left and right axle with CV joint. Price and Part s are from www.rockauto.com, the lowest price on the internet I could find, very fast shipping.
THESE ARE FOR THE RIGHT SIDE AXLE AND CV JOINT ASSEMBLY.
A-1 CARDONE Part # 604153 {[CV Half-Shaft Assembly] Reman.}
Front Right; w/ABS
$42.99
A-1 CARDONE Part # 604152 {[CV Half-Shaft Assembly] Reman.}
Front Right; w/o ABS
$42,99
THESE ARE LEFT SIDE AXLE AND CV JOINT ASSEMBLY.
A-1 CARDONE Part # 604155 {[CV Half-Shaft Assembly] Reman.}
Front Left; w/M.T. w/ABS
$53.79
A-1 CARDONE Part # 604150 {[CV Half-Shaft Assembly] Reman.}
Front Left; w/A.T. w/o ABS
$51.79
Oct 25, 2009 | 1998 Honda Accord
I need the cvjoint number for 1991 mitsubishi galant 4g37 engine?
you can't just buy the joint it comes as a joint and half half shaft assmeby very cheap, the right and left are a different part number u don't give that info. also all wheel drive is different part # as well
THE MAKER OF THESE PARTS AND (ALL ARE STILL AVIL) IS "A-1 CARDONE"
CARDONE SELECT Part # 663092 moreinfo.gif {[CV Half-Shaft Assembly] New}
Front Left; AWD w/A.T. or FWD 663092-01.jpg $50.79 $0.00 $50.79 addtocart.gif CARDONE SELECT Part # 663375 moreinfo.gif {[CV Half-Shaft Assembly] New}
Front Left; AWD w/M.T. 663375-01.jpg $50.79 $0.00 $50.79 addtocart.gif CARDONE SELECT Part # 663102 moreinfo.gif {[CV Half-Shaft Assembly] New}
Front Right 663102-01.jpg $50.79 $0.00 $50.79 addtocart.gif A-1 CARDONE Part # 603102 moreinfo.gif {[CV Half-Shaft Assembly] Reman. #603288}
Front Right 603102-01.jpg $42.99 $45.00 $87.99 addtocart.gif A-1 CARDONE Part # 603121 moreinfo.gif {[CV Half-Shaft Assembly] Reman.}
Front Left; AWD w/M.T. 603121-01.jpg $45.79 $45.00 $90.79 addtocart.gif A-1 CARDONE Part # 603092 moreinfo.gif {[CV Half-Shaft Assembly] Reman.}
Front Left; AWD w/A.T. or FWD 603092-01.jpg
Oct 16, 2009 | 1991 Mitsubishi Galant
NO LEFT, RIGHT, AND CENTER SURROUND
hi there
have u tried connecting the centre speaker to another amplifier to see if the speaker actually works....
if it does then it cud be the output transistors blown or the actual OP-Amp for that channel
Feb 23, 2009 | Harman Kardon AVR 130 Receiver
Left channel won't play.
There could be a number of causes for this from as simple as a dirty switch to a power supply feed to the left channel being open. Without looking at the unit, it is had for me to say. Is it worth it? In my opinioon, yes. Figure on $5-$25 for parts.
Dan
Sep 27, 2008 | Harman Kardon Audio Players & Recorders
Harman Kardon Harman HK 990 Amplifier Logo
361 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
