When you plug it in it shows e4.
SOURCE: E4 error
I tore my hair out for most of the morning trying to fix the same problem, but what worked in the end was just pressing the start print button on the printer itself. The next time I turned the printer on the error message was gone.
SOURCE: E4 ERROR
i have had the same problem,saw this add and got to it straight away,excellent info worked a treat,thankyou very much
SOURCE: error 4
E4 is room temperature sensor malfuction. Replace or call customer service. Very esy to replace yourself. Rus
Good Afternoon friend, I appreciate your inquiry!
Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
