Question about Arris Dch6416 Dual Tuner Hdtv Dvr Hdmi Cable Box W Remote Jun13
My dch6416 will only display a "0". You can change the channel with the remote. But only temporarily, then it goes back to zero. There's no sound or picture?
My dch6416 will only display a zero. You can change the channel with the remote but only momentarily, then it goes back to zero. There's no sound or picture? This happened during several quick power outages.
My dch6416 will only display a zero?
Sounds like the program may be hung up. First try a hard reset which means you need to unplug it from the power strip. Wait 15-20 seconds, then plug it back in and see if that resets the program. If that doesn't help, try the 800 number that you used when you first turned it on out of the box. Lastly call your cable provider.
Feb 13, 2014 | Arris Dch6416 Dual Tuner Hdtv Dvr Hdmi...
I have a Sony KV-27XBR55 TV, that wont display signal (Video nor sound) it only displays 0 0000 on the Channel input
It sounds like you are in the service menu---aside from the zeros what if anything else can be seen?
The set does have (all Sony sets do) a reset done only with the original Sony remote.
Dec 21, 2012 | Televison & Video
Have Aiwa TV MODEL No. TV-A209 The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control. Its stuck...
have Aiwa TV MODEL No. TV-A209
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
O6895H
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
000 001 1
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Nov 08, 2010 | Televison & Video
My TT was imported new from Japan....Has AMAZING video and sound system unfortunateley its all Japanese to me!! The manual that comes with it is about an inch think...Its got built in Navigation system...
I know you can that you can change this by simply hooking up a scan tool for specific year. There are language options accessible for situations like this. Here is a sample of what can be changed using VAG 5052 or equivalent scanners.
Coding
  • 0?xxxxx: Model
    • 1 = Lamborghini
    • 2 = Audi A3 (8P)
    • 3 = Audi A4 (8E)
    • 4 = Audi A4 Cabriolet (8H)
    • 5 = Audi A6 (4B)
    • 6 = Audi TT (8J)
    • 7 = Audi R8 (42)
  • 0x?xxxx: Treble Speaker Monitoring inactive
    • 0 = Front Treble Speaker Monitoring inactive active (NOT Audi A4 Cabriolet)
    • 1 = Front Treble Speaker Monitoring inactive inactive (ONLY Audi A4 Cabriolet)
  • 0xx?xxx: Sound Characteristic
    • 0 = Sound Characteristic linear
    • 1 = Audi A4 (8E)
    • 2 = Audi A6 (4B)
    • 3 = Audi A4 Cabriolet (8H)
    • 4 = Audi TT (8J)
    • 5 = Audi A3 (8P)
    • 9 = Sound System
  • 0xxx?xx: Telephone/Telematic
    • 1 = Telephone not installed (Remote Feed Voltage for Microphone active)
    • 2 = Base Plate (Temic - Remote Feed Voltage for Microphone inactive)
    • 3 = Base Plate (Cullmann - Remote Feed Voltage for Microphone inactive)
    • 4 = Base Plate (Nokia - Remote Feed Voltage for Microphone inactive)
    • 5 = Telematic Europa (Remote Feed Voltage for Microphone inactive)
    • 6 = Telematic US (Remote Feed Voltage for Microphone inactive)
    • 7 = Base Plate diagnostic capable with Comfort Control
  • 0xxxx?x: Equipment I
    • 1 = Tuner not installed
    • 2 = Digital-Radio installed
    • 3 = Satellite-Radio installed
    • 4 = Satellite and Digital-Radio installed
    • 5 = Analog Input (AUX) installed
    • 7 = Satellite-Radio & Analog Input (AUX) installed
  • 0xxxxx?: Equipment II
    • 1 = TV-Tuner/CD-Changer/Multi-Function Steering Wheel not installed
    • 2 = TV-Tuner installed
    • 3 = CD-Changer installed
    • 4 = TV-Tuner and CD-Changer installed
    • 5 = Multi-Function Steering Wheel installed
    • 6 = TV-Tuner and Multi-Function Steering Wheel installed
    • 7 = CD-Changer and Multi-Function Steering Wheel installed
    • 8 = TV-Tuner and CD-Changer and Multi-Function Steering Wheel installed
Adaptation Channel 001: Tire Circumference The tire circumference is beeing adapted in "mm".
Channel 002: Wheel Pulse The wheel pulse describes the amount of wheel pulses per revolution.
If value 0 is entered the system calibrates automatically itself after several kilometers and inputs a value.
  • 43 = Audi A3 (8P) / Audi TT (8J)
  • 45 = Audi A4 (8E)
Channel 003: Language (Screen)
  • 0 = German
  • 1 = English (UK)
  • 2 = French
  • 3 = Italian
  • 5 = Spanish
  • 6 = Portuguese
  • 7 = English (UK)
Channel 004: Back-Up Camera
  • 0 = Back-Up Camera not installed
  • 2 = Back-Up Camera installed
Channel 005: Speed Threshold (Video Input)
  • 0 = max. 0 kph or 0 mph
  • 1 = max 5 kph (Standard for Europe)
Channel 007: Options Channel 008: Volume Characteristic Channel 010: Region
  • 0 = Europe/North America
  • 1 = Australia/South America
  • 2 = South Africa
Channel 011: Language (Speech Recognition)
  • 0 = German
  • 1 = English
  • 2 = French
  • 3 = Italian
  • 5 = Spanish
Channel 018: Start Screen The start screen setting has to correspond with the control module coding, e.g. a S3 start screen doesn't work with an A4 coding.
  • 0 = Standard Start Screen
  • 1 = Audi S3 Start Screen
  • 2 = Audi S4 Start Screen
  • 3 = Audi RS4 Start Screen
  • 4 = Audi TT Start Screen
  • 5 = Audi R8 Start Screen
Channel 065: Read Test Channel 066: Self Test Channel 067: CD/DVD Drive
  • 000 - Normal/Eject-Button enabled
  • 001 = Eject CD/DVD (will not be saved)
  • 255 = Eject-Button disabled/locked (Anti-Theft-Protection)
Channel 068: Screen Test Values will not be saved, they only act as initiation for each Test Picture.
  • 0 = No Test Picture
  • 1 = Test Picture: Red
  • 2 = Test Picture: Green
  • 3 = Test Picture: Blue
  • 4 = Test Picture: White
  • 5 = Test Picture: Black
  • 6 = Test Picture: Checkerboard
  • 7 = Test Picture: Checkerboard (inverted)
  • 8 = Test Picture: 64 Gray Scales (vertical Bars)
  • 9 = Test Picture: Special
Channel 069: Display Mechanism
  • 000 = Display closed
  • 001 = Display open
  • 200 = Display half open (Obstacle)
  • 255 = Position undefined
Channel 070: Display Brightness
  • 0 = 0% Brightness (Display OFF)
  • 1 = 20% Brightness
  • 2 = 40% Brightness
  • 3 = 60% Brightness
  • 4 = 80% Brightness
  • 5 = 100% Brightness
Channel 099: Transport Mode Only applies to models without Gateway/Diagnostic Interface for Databus.
  • 0 = Transport Mode inactive
  • 1 = Transport Mode active
Channel 111: Reset
  • To perform a system reset/restart save 1 as new value.
Channel 114: FM Frequency
  • Range: 875...1080
Channel 117: Signal Test (Output)
  • 0 = Fader Center & Balance Center
  • 1 = Fader Front & Balance Left
  • 2 = Fader Front & Balance Right
  • 3 = Fader Rear & Balance Left
  • 4 = Fader Rear & Balance Right
Channel 136: Driver Position
  • RNS-E Basic
    • 03226 = Left-Hand-Drive (LHD)
    • 02632 = Right-Hand-Drive (RHD)
  • RNS-E High/US
    • 00005 = Left-Hand-Drive (LHD)
    • 00013 = Right-Hand-Drive (RHD)
Jul 04, 2010 | 2007 Audi TT
Aiwa TV MODEL No. TV-A149 AGING
I have Aiwa TV MODEL No. TV-A149
AGING
6EDEH
S123 K234 Y
100 000 0
Sep 14, 2009 | Aiwa TV-S2011 20"
Hitachi volume bar always on, remote doesn't work
you can start by opening the front panel and check if the control board (with channel ,volume ) is correctly fixed or need to be solded.
the service manual is here in 6 parts and for free...:
http://www.eserviceinfo.com/downloadsm/31328/Hitachi_43FDX10B.html
cheers
Dec 21, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Channel numbers scrolling
the tac switches have gone bad.this happens from age or sometimes from washing the screen of the set and moisture gets on the.. it is not a big job but it does involve soldering skills
Nov 28, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Arris Dch6416 Dual Tuner Hdtv Dvr Hdmi Cable Box W Remote Jun13 Logo
Top Arris Televison & Video Experts
Electro Med Services...
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
