Question about Konica Minolta Office Equipment & Supplies
C0210 minolta di 450 - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,680 Answers
Directly below the drum section is an assemble called the transfer/separation assy. the purpose of this unit is twofold. (It houses to very thin gold plated wires) One wire is what helps the transfer of the image from the drum to the paper. Since the paper goes between this wire and the drum, the second wire prevents the paper from sticking to the drum during the transfer process. The code you have been getting means either wires might be broken, or has to cleaned (because of all the toner on it from the drum assy. which needs to be removed and cleaned. Or two white end blocks that hold the wires are getting old and allowing the High Voltage that is applied to the wire during the copy/print process to leak to ground. Open and close the front door to clear. If it comes back have a qualified tech look at it.
try this site for parts
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Posted on Jan 18, 2016
5 Suggested Answers
  • 1297 Answers
SOURCE: minolta copier di-450 code : c-143e
The correct error code is C 143E - EDH malfunctions.Please reset the malfunctuion code to open and closed the front door,or turn OFF wait 5 sec. and turn ON the power switch.If the problem persist change the image processing board.
Pick up motor malfunction
Whwn the document handling tray goes to up the pick up raised position sensor is not unblocked when the motor started turning forward.Whwn thw DHT goes down the pick up lower position sensor is not unblocked after the motors started turning backward.
During ascent motion check :
1.Foreign matter on pick up motor gear
2.Pick up motor operatio.The voltage across PJ11A 1 of main control board and GND is 0V when the motor is deenergized and 24 V when the motor is energized when the DHT is raised after the malfunction reset.
3.Pick up raised position sensor operation.
Change the motor,sensor or main control board.
During descent motion
1.Check the pick up motor gear.
2.Check the pick up motor operation
3Check the pick up lower position sensor operation.
Posted on Aug 28, 2009
  • 1739 Answers
SOURCE: i dont,ve driver but i
The drivers for your printer can be found here. Make sure to select the correct driver for your Operating System.
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productid=462&filetypeid=0
Posted on Jan 29, 2011
saxmansaxman
  • 177 Answers
SOURCE: i have a minolta CS
Hello this is going to be an issue with corona wires it could be the charge corna unit or the transfer seperation unit check the corna wires and springs that hold the corona wires in place if corona wire is bad replace also check for arching on the ends of the corona asseblys you can normally smell the arching or you can just replace the charge unit for the drum unit and the transfer seperation unit as well
Posted on Feb 03, 2011
  • 1297 Answers
SOURCE: code malfunctios c1441 minolta di 450
The copiers CPU is equipped with a self diagnostics function that on detecting a malfunction,gives the corresponding malfunction code on the touch panel.Resetting a malfunction:
- Press the trouble reset switch on the technical representative setting switches board to reset fusing and exposure lamp related malfunctions.(code: C400,410,420-expo;C500,510,520-fusing unit)
- For any other malfunctions,open and close the front door or turn OFF and ON the power switch.
C1441 CCD failure(clamp adjustment failure).
Reset the malfunction,check that the original glass is properly installed.Check for extraneous light and check to see if CCD Assy and mirrors are installed at the correct position.If the same malfunction is detected again,change image processing board.
Posted on Aug 15, 2012
Minolta Di 450 code 13 & 14
need additional numbers codes are c-xxxxx
Mar 03, 2014 | Konica Minolta Minolta Di450 Di470 Di550...
My konica monilta di 450 is giving error code c-13fa please help and give me its solvation?
The problem is the print head that is were the LASER is located open close the front door to reset if it comes back replace the print head
Feb 01, 2014 | Minolta DI-2010F Copier
Hw do i fix error code c0210 on my minolta dialta di 552
Directly below the drum section is assemble called the transfer/separation assy. the purpose of this unit is two fold. (It houses to very thin gold plated wires) One wire is what helps the transfer of the image from the drum to the paper. Since the paper goes between this wire and the drum, the second wire prevent the paper from sticking to the drum during the transfer process. The code you have been getting means either wire mite be broke, has to cleaned (because of all the toner on it from the drum assy. which need to removed and cleaned. Or The end blocks that hold the wires are getting old and allowing the High Voltage that is applied to the wire during the copy/print process are breaking down allowing the high voltage to ground. Open close the front door to clear. if it comes back have qualified tech look at it.
Mar 09, 2013 | Minolta Office Equipment & Supplies
What is c0120 error
error code C-0120 in konika minolta model no C-450
Feb 03, 2011 | Konica Minolta Minolta DI1610P Printer,...
Cannot close the M1 part of Minolta Di 450
M1 is a counter for maintenance need to get service mode access to clear the counter and clear the message.
Dec 30, 2010 | Minolta DiALTA Di183 Copier
We have an error - C0210
k Normal 0 false false false MicrosoftInternetExplorer4 Transfer roller voltage problem
Jun 08, 2010 | Konica Minolta Di1610 Copier
En Mi fotocopiadora aparece El error c0210
Change the transfer/separator corona unit,or clean the corona holder parts.
May 13, 2010 | Minolta DI-2010F Copier
DI 450 KONICA MINOLTA ERROR CODE C0070 AND C0F24
if it;s not the bottle home position it may be you toner happer motor...clean it and try to take the bottle our and close the door and than put bottle back in
hope that help
Feb 25, 2009 | Konica Minolta DiALTA Di200 Copier
20 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
