Question about Dishwashers
Whirlpool washing machine awo\d 4405 drains but wont go into high spin
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
SOURCE: Whirlpool washing machine AWO/D 4305 does not spin
its probably an inbalanced load or its to light.it MUST have a good full mixed load to spin
Posted on Jan 28, 2010
  • 942 Answers
SOURCE: washing machine drains, wont spin, making clicking
If your washer won't spin, check these: It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Jan 30, 2010
SOURCE: Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Posted on Feb 17, 2010
  • 69 Answers
SOURCE: Whirlpool AWO/D 4605 Clean Pump light on, how do I
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
Posted on May 11, 2010
My whirlpool awo/d 4506 washing machine is not spinning
When a washer will not spin there are a few common problems and I'll go over the most I see. One, the drain pump is either clogged or the drain pump has failed. If the control senses water in the tub, the control will not allow the unit to spin. Two, worn out tub suspension springs or tub shocks. When the washer goes into spin, there is a lot of force involved and the springs and shocks absorbs these forces. Three, bad pressure sensor. This sensor tells the control how much water is in the tub and if the sensor is bad, the control thinks water is still in tub. Hopefully this can help solve your issue. Good Luck!
May 25, 2016 | Whirlpool Washing Machines
AWO/D 4505 not spinning
does it pump out all the water when it spins the first time? when they spin slow sometimes the pump is not pumping out all the water causing it to spin slow.
May 15, 2014 | Whirlpool Washing Machines
Whirlpool AWO/D 8708
F07 is a fault with the motor control, probably the triac has failed.
Jun 16, 2017 | Washing Machines
Whirlpool awo/5556 programme knob displays wrong timing for wash cycle
Answered earlier , suspect this error can be due to internal clocking of the program controller unit.
Mar 12, 2012 | Whirlpool Washing Machines
Washing machine spills detergent out of its ''drawer'' (Whirlpool
Did you ever find a solution? My Kenmore washer has the same issue.
Jan 22, 2010 | Whirlpool Washing Machines
Whirlpool 6th sense washing machine doesn't go into high spin
sounds like you have a blocked hose/pump vent hole.......if its holding water in the bottom of the tub it wont spin it will try but the pcb wont let it do the spin .due to pressure switch telling its got water left... pull pipe off pressure switch check holes not blocked check all hoses......
Dec 30, 2009 | Washing Machines
Whirlpool AWO 3761/S
Faulty pump (most likely clogged).Remove the pump hoses and clean out the pump.Please leave a rating.
May 16, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
