Question about HP Officejet Pro 8600
Fax connection failed - HP Officejet Pro 8600
"Failed to read the PC-FAX Phone Book"
Try this
Browse to Control Panel > Administrative tools > Computer management > Services and Applications > Services
Locate the following services:
1. Telephony
2. Network Connections
3. Remote Access Connection Manager
4. Remote Access Auto Connection Manager
Right click and select Properties. On the General tab, next to Start Up type, select Automatic followed by OK.
May 09, 2014 | Epson Artisan 810 AllInOne InkJet Printer
I am trying to receive a fax. The fax gets the call but it states "Fail to Connect" why?
check the phone line to ensure it is connected.
check manual for trouble shooting or Dell's printer web site.
check fax settings in printer/fax setup page
Apr 29, 2010 | Dell 968w Printer
Can not fax the paper say connection failed lexmarkx4270
Here's a link to the user guide, navigate to the "Fax Troubleshooting" section.
http://www.lexmark.com/publications/pdfs/2007/4200/ug/en/frameset.html
If you are still having problems please let me know and also provide information about how the fax is setup.
Jun 02, 2009 | Lexmark X4270 All-In-One InkJet Printer
Receiving error 388. Can receive faxes but won't connect with other fax machines when trying to send
The reason for the error code:
4e5e48b.jpg Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Solution
Please Click here and follow the instructions to resolve the issue.
May 21, 2009 | HP Officejet 6310 All-In-One InkJet...
Fax problems
I think you just not plugged with the phone/fax cord.
Please check the cord is connect or not.
Mar 16, 2009 | Brother MFC-7340 All-In-One Laser Printer
Fax will fax or receive fax
If it is a Officejet 6110 All-In-One first run a fax test:
Press Menu/Setup> Press the right arrow key to locate Tools> Press OK> Now press the right arrow key to locate Run Fax Test> and press Ok.
Check to see what has failed and correct what ever has failed in the fax test.
And follow the below mentioned steps to connect the All-In-One according to your setup:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu50333&cc=us&lc=en&dlc=en&product=79477
Good Luck
Oct 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
I have trouble faxing over my voip line
SOUNDS AS IF YOUR PHONE LINE IS THE PROBLEM. LAWRENCE
Sep 25, 2007 | Brother FAX-8360P Plain Paper Laser
HP Officejet Pro 8600 Logo
13 people viewed this question
Seeker5211
Seeker5211
