Question about Toshiba E-Studio167 Copier
It doesnt print , it give me this message : ' a print job in the printer queue is preventing other print jobs printing
  • 46 Answers
SOURCE: i'm giving a print of a pdf file but printer not
go into you printers folder look for the toshiba printer right click on that go to properties and change the paper seting on that property menu
Posted on Oct 12, 2009
  • 643 Answers
SOURCE: toshiba 255 not printing from computer but works as
Did u installed the printer kit?
What kind of interface u're using, RJ45/network or USB ?
Posted on Dec 21, 2009
  • 55 Answers
SOURCE: Trying to print from windows XP. Installed driver
unplug everything go to google type in the exact model and number of the printer and put driver after it and down load the driver then connect everything after the driver has been installed
have a nice day post nice things
Posted on Mar 06, 2011
matandacosma
  • 66 Answers
SOURCE: can not clear the print jobs on estudio 282, how do I reset the memory?
if you can not clear the print job from the computer. and you used the computer to send commands then you must change the software for the printer, i mean remove the drivers and re-install them.
Posted on Apr 28, 2012
riyadhabhoss
  • 62 Answers
SOURCE: latest firmware version for toshiba 2040c
change system board with hdd
Posted on Apr 12, 2013
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
A print job queue is preventing other print jobs from printing
a print job in the print queue is preventing other print jobs from fixed printing
Dec 30, 2010 | Costar DYMO DiscPainter Printer
Hello guys, i´ll be very
Issue Print jobs are stuck in the print queue (spooler) on a computer running Microsoft Windows connected to the print server. Nothing prints, and the print job in the printer's queue shows a status of Printing . These print jobs cannot be deleted even on the server, and it will not disappear or print until the Print Spooler service is restarted. Solution For Microsoft Windows Server 2003 and Microsoft Windows XP Professional x64 Edition, a fix is available in Microsoft Knowledge Base Article, The Print Spooler service may stop sending print jobs to a printer that uses the standard port monitor on a Windows Server 2003-based computer . Click here to view Microsoft Knowledge Base Article 934885 (http://support.microsoft.com/kb/934885) . To prevent this issue from occurring, disable the bidirectional printing support for each HP printer driver installed. To do this, perform the following steps:
  1. Click Start , point to Settings , click Printers , right-click the icon representing the printer to be modified, and then click Properties .
  2. Click Ports , click to clear the Enable Bidirectional Support check box, and then click OK .
NOTE: Sharing a printer over a network is a feature of Microsoft Windows and not HP printer specific.
Nov 01, 2010 | Office Equipment & Supplies
The print job in the print queue is preventing other print jobs from printing im receiving this error message i have a hp c 4580 printer
If one job isn't printing, cancel it, and let the other one's print. I read somewhere there is a 2GB limit on print spool jobs...and if you reach that limit, everything locks up. I am not sure on it...but if you have a realy large document, either print it alone, well, just print it alone. Try to spool your print jobs from the smallest ones first, and don't overload it. The is especially true of printing pictures...because if you don't resize them, they can be especially large files (and large pictures) sometimes you don't realize that what you are viewing on screen is only 26% of the actual picture size...especially if you have say, a 8MP or higher camera pixel size capability.
Jan 13, 2010 | HP Photosmart C4580 All-in-One InkJet...
HP P1005 PRINT JOB SITS IN QUE, WO'T PRINT
Does it show "Printing" or "Spooling" in the job queue window?
Open the Job queue window, then highlight and cancel the print job. Send a small print job to the printer and make sure that the PC and the printer are communicating.
If the failure re-occurs, then clear the queue again and close it and restart i=the queue.
Don
Dec 14, 2009 | HP Hewlett Packard LaserJet P1005 Printer
I am trying to print from my netbook using an hp printer. i am getting an error message saying that the print queue is full.
Yes, printer won't print if print queue is full. The fact is you are lucky your printer is giving you this message. Most printers, when queue is full, will just remain silent and leave you wandering what in the world has gone wrong.
Solution is to clear the print queue. See, when you send to print and you send another when the previous hasn't printed, they queue up. Now if for any reason the first fails to print, all others will just remain queued up but will not print until you clear the print jobs queued up.
To do, this go to start/control panel/printers. Right click on printer icon and select open. The respective print queue box appears. It should have all of the print jobs listed there in the box. On the menu bar click on printer and select "Cancel all documents." A box appears asking you to confirm if you want to cancel, answer yes. Then try to print again. If it still fails to print restart your PC and try to print again.
Dec 06, 2009 | Office Equipment & Supplies
How to cancel a print job that has multiple copies selected for the print job
Click Start
Click Control Panel
Click Classic View
Click Printers
Double-click the active printer to open the "job-queue" window
Select the file to be cancelled
Right-mouse click on the selected file, and choose cancel.
Nov 17, 2009 | Microsoft Windows XP Professional for PC
I want to print new page of printing printer keeps churning out prvious printing instrctions i am 78yrs old still learning
What you need to do is clear out the printing "QUEUE".
Clearing the Print Queue in Windows
The printer is one of the slowest devices in a computer system. If you had to wait for it to print your document before you could resume writing, you would quickly go back to using a typewriter. To eliminate the delay, Windows reserves a portion of memory for something called a “print queue” (or spooler). The queue works on a first-in first-out basis. You can continue to use the computer and send jobs to the spooler as it feeds a steady stream of data to the printer.
Print queues are nice, except when something happens in the printer to cause it to stop functioning. Sometimes it is just a paper jam and sometimes it is a bit more serious. If you need to cancel the jobs in the print queue, you can simply double-click the printer icon (in the system tray down by the clock) and open the print queue. Depending upon the length of your document and how many documents are waiting to print, the printer icon may appear briefly or for a sustained period. (Note: This would be a good time to remove the paper from the printer before continuing.) If the icon is not there, you can manually open the queue.
Open the Print Queue
  • Windows 98 - click Start, Settings, Printers
  • Windows XP - click Start, Printers and Faxes
    or click Start, Control Panel, Printers and Faxes
  • Windows Vista - Start, Control Panel, Hardware and Sound, Printers
Double-click to open the appropriate printer's queue. The Print dialog box will open. Here you will see a list of all of the jobs waiting to print, along with the status of each job. The first print job is at the top of the list.
To cancel a document in the list, right-click it and select Cancel Printing. Most often, it is better to cancel all of the jobs and then resend the documents to the printer.
Cancel All Documents
  • Windows 98 - click Printer on the menu, select “Purge Print Documents”
  • Windows XP - click Printer on the menu, select “Cancel All Documents”
  • Windows Vista - click Printer on the menu, select “Cancel All Documents”
Please note that you must have Administrative rights in Windows XP and Vista to cancel print jobs. If you are the only user, you automatically have administrative rights. If you are on a multi-user computer, you must be an administrator. If are on a network and get a message saying that you do not have Administrative rights, find someone who does.
Under normal circumstances, printing documents are cancelled and will disappear from the queue. If one or more do not disappear, shutdown the computer and restart. When shutting down, you may get a message warning you that your print jobs will be lost if you continue. Tell Windows to shutdown anyway. When you restart, Windows may tell you that you have print jobs waiting. Tell Windows to delete them.
Before you resume work, open the Print Queue from the Start menu. You should find the queue empty. If you are using Windows XP or Windows Vista and the queue is not empty, you will be unable to print. Before trashing your computer, you can try to clear the queue using a secret Windows command.
Click Start, Run, and type “Net Stop Spooler” (without the quotes). Then press Enter. Shutdown the computer and restart. The print jobs should be removed. If they are not, shut down the computer again, take a deep breath, and then go for a long walk. The queue should be clear when you return. Note that you must restart the computer for your printers to resume normal operation.
This should solve your problem, Let me know how it works for you..
~~Jastababe~~
Nov 19, 2008 | Lexmark Office Equipment & Supplies
Can not clear the print que
Follow these steps to resolve the issue. Step one: Delete the print queue Open Print Setup Utility located in the Application/Utilities folder. Double-click your printer in the printer list to open the print queue. Click the Stop Jobs icon. Click to select the document, and then click the Delete icon. Repeat the steps for all the jobs in the print queue. When the print queue is empty, click the Start Jobs icon. A message appears: No Jobs Printing . This indicates that the queue is clear. When you have cleared the queue, retry your print job. If the procedure has not resolved the issue, repeat steps 3 and 4. If the issue still persists, continue to the next step. Step two: Remove the printer from the list Open Print Setup Utility , located in the Application/Utilities folder. Click to select the Photosmart icon. Click the red X to delete the printer from your system. Close all open windows, and restart your computer. Step three: Add the printer to the list Open Print Setup Utility located in the Application/Utilities folder. Click Add . Select the printer that you want to add, and click the Add button. After a few seconds, your printer appears in the printer list, and your printer is ready to print.
Sep 13, 2007 | HP PSC 1410v All-in-One Printer
Toshiba E-Studio167 Copier Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
