Question about Bose Remote Control RC48S2-27 p/n:RC48S227
Remote control reset rc48s2
I want to reset myremote control
My RC48S2-27 won't turn on? Any thoughts?
Could be a battery problem or possiby total failure of the remote.
Jul 02, 2014 | Bose Remote Control RC48S2-27 p/n:RC48S227
Bose rc48s2 remote not receiving signal
make sure the lens on the remote and the one on the Bose are clean. If that does not work, replace the remote. Buy a used on on ebay.
Dec 21, 2013 | Bose RC-48S Remote
Myremote will not change the channel of my TV
you need to completely unplug your satelite box and pull the card out of the box. once you do that, plug it all back in. Then reinsert the card. Give it a moment to reset. once it does, be sure to push the sat button and try your remote again. If your batteries are low this will also prevent the control from working. other problems could be someone reset your controler. use the user guide and look for your tv in it, it has a code you have to put in. The best way to handle the problem is call your cable/sat customer service and they can walk you thru it. if all else failed buy another controler.
Mar 19, 2013 | Televison & Video
I somehow stretched the picture on my LG FLATRON TV model 29FX5BLE-TG-UFBLLBK using myremote. How do I get it back to original size?
press ok on the tv panel& press ok on remote same time to enter service mode, then adust hs (horizontal size) eu, ev to get the perfect size
Apr 07, 2010 | Televison & Video
Myremote is not working properly.
Must be a hard ware problem, needs servicing
Nov 06, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Gettng my RC28T1 40 to connect with my LS28 system
i have a bose control, model RC48S2-40 and start the system but does not have control for volumen and change only from fm to cd dvd, is conected to other system bose from other rooms
Apr 10, 2009 | Bose RC-18S Remote Control
No Code For MyRemote
www.scytek.net all manuals listed on website go under products to your model
Nov 14, 2008 | Scytek 2000RS Remote Control
Codes
Find the codes here
It's in pdf format, so you'll need the adobe reader to view it.
Mar 14, 2008 | One For All URC-7200 Remote Control
Dvd player
i need remote codes for philips 734 dvd player
Feb 02, 2008 | Philips DVDR 3355 DVD Recorder
Bose Remote Control RC48S2-27 p/n:RC48S227 Logo
104 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
