Canon ir 2200 printer
I am printing on to A5 flyers so the paper is glossy and the printer keeps saying it is jammed when it is not, any ideas how to fix this?
SOURCE: paper jamming and can't print
Check if there is a piece of paper stuck in the feeder rollers, sometimes the smallest piece makes the bigger mess.
Hope That Helps!
Posted on Dec 11, 2007
  • 153 Answers
SOURCE: Canon Pixma MP830 printing red/orange hue on glossy photo paper
are you using geniune canon glossy paper??? it is designed for the printers and really is the best for the machines
Posted on Apr 14, 2009
Suricatta
  • 92 Answers
SOURCE: paper jammed but no paper is jammed.
I guess there is a small piece of paper near A4 sensor...
Try carefully to dismantle and clean...
Good luck
Best Regards
Posted on Jun 26, 2009
anjana03
  • 361 Answers
SOURCE: Brother DCP 185C cannot print to a glossy paper
in brother printer there. we can choose many types paper. we are pinting now photo in same. choose paper option while giving print command
Posted on Jul 11, 2009
virtualhost
  • 2185 Answers
SOURCE: Epson stylus DX3800 All in one printer, scanner Unable to print
Open the printer cover and look closely for tiny paper shreds that might got stuck between the rollers. If you have a canned air, try blowing out the paper path as those tiny piece of paper might be blocking the paper sensor.
Posted on Sep 20, 2009
Testimonial: "tried blowing and dusting with a brush Now it comes on as normal - no flashing light but will only take paper about 2 cms then flashes paperjam"
How to clean rollers so it picks up a 4x6 glossy paper to print, without saying it has a paper jam.
glossy paper is difficult at best. only 1 pickup roller. if you look in the paper tray area you will see it. open the pack you will also see it.
Book says mild soap and water. try some Alcohol and a swab.
Jul 25, 2014 | Canon PIXMA MP990 All-In-One InkJet...
How do I print color photos on glossy paper with Canon Pixma MP 6
printer supports it. just you have to goto printing preferences or printer properties and set rear tray to accept glossy paper. it will accept size of paper ur using. so give the actual size.
Apr 23, 2009 | Office Equipment & Supplies
Problem with printing on canon ir 2200
go to run prompt on client end and typ \\ip add of main pc where ur printer actually connected nd then u will get shared printer on display, u will get shared icon of ur network printer right click there nd connect it .... if it doesnt show any problem to connect it will work nicely ...........
Apr 16, 2010 | Canon (6981A002AA) for imagerunner 2200,...
I have a canon ir2200 that is saying paper jam on front left. I can find no paper jam anywhere and have checked to see that the dials on the paper trays are set correctly. Also I have turned copier on and...
I am Sunil choudhary resident in Junnardeo dist. Chhindwara, My machine canon ir 2200 b&w machine -Miner problem paper jam-some move paper & right side jam paper & jam indicator show
Jan 11, 2010 | Canon imageRUNNER 2200
Paper jammed but no paper is jammed.
Sounds like something has fallen into the paper path. Use a flashlight and small mirror to look down the slot where the paper goes. You may have to use a straightened paper clip or the like to help remove the obstruction.
Jun 26, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Glossy paper jams
hello! most printers will only print on regular , you can not use glossy paper. the paper pick up rollers will not grab the paper, they tend to skid on the paper, good luck. brother tech
Jan 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
Imagerunner 1023if printing on glossy paper
Hello boriquajake,
We are looking at inherent limitations of the copier. The reason the paper appears "glossy" is that it is coated with a type of plastic that does not like going Thru whats called the fuser. This fuser does what its name implies as it "fuses" the toner to the paper by way of extreme heat and pressure. Thru decades of trial and error copier manufactures have found a way to make carbon black and plastique( like the EURO NAME?) along with other confidential compounds into a mixture (called toner) that can survive the extreme heat (370' F and above) and pressure (the sky is the limit here) bond to the paper and successfully exit. However, the nifty glossy paper was designed for an inkjet printer which uses sprayed ink and neither heat or pressure. My final most helpful statement would be that glossy paper was never designed for a copier. And I can promise you that at some point the glossy paper will cause a paper jam in the fusing area that will be very expensive . Since the "gloss " is merely a plastic shine that was never meant to be "re-melted" by the rubber coated rollers......... need I say more. One day you will have a paper jam from hell that will destroy the fuser. I wish I had better news but if you think about it I just saved you a service call, and a significant bill. You are are the working guys/ gals like me that I like to help before you get screwed. Take care.
Jul 19, 2008 | Canon imageRUNNER 1023iF Black and White...
Canon Pixma mp510
The top-loading sheet feeder accommodates approximately 150 sheets (depending on weight), and the front feeder is good for around 100 sheets. Actual media sizes supported by the main feeder (top-loading) include A4, B5, A5, Letter, Legal, Envelopes (DL size or Commercial 10), 10x15cm(4" x 6"), 10x18cm, 13x18cm, 20x25cm, and Credit Card (54x86mm), while the front feeder is less accommodating with just A4, Letter, and B5.
Jan 27, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma ip 2200
send me printer driver canon ip 2200
Nov 12, 2007 | Canon PIXMA iP2200 InkJet Photo Printer
Card making
This machine will only print certain sizes as borderless. A5 is not one of them. You can use the following media with this feature: Matte Paper - Heavyweight: A4, Letter Premium Glossy Photo Paper:A4, Letter, 5 x 7", 10 x 15 cm/4 x 6", 8 x 10" Photo Paper:A4 Premium Semigloss Photo Paper:A4, Letter, 10 x 15 cm/4 x 6" Glossy Photo Paper:Letter, 10 x 15 cm/4 x 6" As you can see A5 is not in the list, therefor you will not be able to print A5 borderless via the normal means.
Aug 21, 2007 | Epson RX620 All-In-One InkJet Photo...
10 people viewed this question
jasbo
jasbo
