Canon ir 6570 error code 840 - Office Equipment & Supplies
  • 6 Answers
SOURCE: COPIER GIVES THIS ERROR E0000-840-0001
this err belongs to sensor problem.
chech thermostat sensor
Posted on Dec 01, 2008
petez12
SOURCE: canon ir 6570 error
Im new to this forum. I have an IR6570 giving me an error code E808-001, please help,
Posted on Jul 18, 2009
SOURCE: i have canon ir 6570 continueing error code
E000004-010
Posted on Sep 09, 2010
muleskinner2
  • 270 Answers
SOURCE: I have canon ir 6570 continueing errod code e0013 solution
This is the standard Canon code for waste toner feed screw is locked. Most likely someone reset the waste toner counter and the waste toner has backed up in the auger screw. You should first empy the waste toner bottle located on the right side lower right. Remove the two screws and empty the bottle you find. You may even have to remove all the associated covers motors and circuit boards to get to the waste toner system. You will have to either clear out the auger tube, or replace the whole assembly. Check for broken parts, bound up screw, fused toner, etc. I've done this a couple of times and it's not fun. I try to make sure that I empty the bottle at every 1 million copy mark just so this doesn't happen again. Good Luck.
Posted on Sep 17, 2012
arianto739
SOURCE: how to remove this error e000840-0001 in ir 6570
bagaimana caranya perbaiki kade 000840-0001
Posted on Mar 11, 2013
E821 error code in canon IR 6570 ?
error code relative to the clogging of toner inside the waste toner auger tube. this will require a technician.
Feb 17, 2015 | Canon Office Equipment & Supplies
Error code E000005-0001 cannon ir-adv 6055
I have a problem with my machine,
Canon IR 6570 with error code E000005-0001
beg for a solution
Nov 09, 2011 | Office Equipment & Supplies
How to remove error code (E000004-0010)from canon iR-6570 photocopier?
gmana ya cara benerin error e000004-0010 pada mesin canon ir6570
Jul 07, 2011 | Canon Office Equipment & Supplies
Error 840 in 6570
check machines heater section (unit 1) is proper inserted,
or clean the shutter home position sensor.
the sensor find in front side of heater section.
ok
Jul 01, 2011 | Canon IMAGERUNNER 6570 Copier
6570 - e804-0001
E824 There is a primary charging cooling fan error.
0001 The primary charging cooling fan stop signal has
been detected for 5 sec or more even when the
primary charging cooling fan is on.
Service manual says:
- Check the connection of the connector.
- Replace the fan.
Why did you changed power supply? Did you try with new dc controller?
Jun 29, 2010 | Canon imageRUNNER 5570 Copier
Nov 24, 2008 | Canon IMAGERUNNER 6570 Copier
CanonPC6RE
I don't know if this addresses your problem, but check this link. If Canon has not already repaired your unit (since September 2006), they may help you out.
May 15, 2008 | Canon IMAGERUNNER 6570 Copier
14 people viewed this question
jasbo
jasbo
