Question about Sony Office Equipment & Supplies
Why the sony data projector connected to laptop displays yellowish on the screen
SOURCE: Toshiba laptop does not display on projector
now my problem is solved.
Posted on Feb 18, 2009
  • 10 Answers
SOURCE: projector cannot detect my connection to my laptop
try hitting function 8, had the same problem giving a presentation and that took care of it.
Posted on Feb 20, 2009
SOURCE: Probem with connecting projector with laptop in vista OS
You need to change your graphics card settings from extended desktop to cloned desktop.
You will find that if you use your mouse currently to drag a window or icon across to the projected screen, it will move the window there. This is the extended desktop.
I assume that what you want is to have the exact same screen on your laptop and your projector - this is called the clone screen.
These setting can be by right clicking your desktop, select properties. Click on the display settings tab. click on the advanced settings button, and the the graphics card tab. There should be another button to launch the graphics card settings there.
Hope this helps.
Posted on Apr 19, 2009
timothypeacy
  • 23 Answers
SOURCE: Projector displaying yellow tint in center of screen.
The yellow tint is probably coming from the lens. It could be that the glass is tempered or possibly just needs to be cleaned.
Posted on Jul 24, 2009
MNfisherman
  • 11896 Answers
SOURCE: I have the Optoma Model
right click on main screen, then go to properties, then you can adjust resolution, color, contrast, hue, and much more. You can also do this from control panel and under display.
Posted on Oct 08, 2009
I cannot get my projector screen working on my eee pc 1005 HAB. Ideas?
Connect the data projector to the laptop's video port, power up the data projector first and thelaptop. The video information will automatically switch to the data projector.
Sep 06, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Hi We have a HP compaq 6710b laptop which we try to connect to a LG XGA Projector.We can not get them to communicate and get the information can not find the source. As I understand it doesnt have to do...
Hello Anneli,
You can simply do this by pressing the "Function" (or "Fn") key, followed by one of the numbered "F" buttons along the top of your keyboard. In most cases there will be a graphic of what looks like a television screen on the correct "F" key (e.g. "F4"), but if you aren't sure consult the manual that came with your specific model.
If that doesn't work in some cases doing a manually configuring multiple displays will often vary from laptop to laptop, depending on the graphics chip and software installed. In most cases, you can navigate to the Control Panel, then click on Displays, and then on Settings.
f0f219158e118e83--61c9b675-11b08cb53ea--4d1c-364156565-w580h580.jpgOn this screen you should see two numbered boxes, labeled 1 and 2. Clicking "Identify" should flash a number on the screen to indicate which monitor is which. Below this is a slider that set's the resolution and color depth of the output. The way this works, click the monitor (1 or 2) then make changes to the resolution and color depth (Don't forget to hit the Apply button after changes are made)
If there's no picture on the projector, most likely the VGA output to that projector is disabled. Click on the number that did not flash on the notebook screen. Right click this number, and select "Enable Display." In the resolution slider (in ksharp's case), slide it to 1024x768, and select 32 or 24 bit color depth. Hit Apply.
Hope this helps.
Mar 16, 2011 | HP Computers & Internet
How do I connect the laptop to the projector using Power Point.
Connect the data projector to the video port on the laptop. Then power up the data projector and then the laptop, the video data will automatically be diverted to the data projector.
If you want to see the Windows image on your laptop screen as well you need to press and hold down the FN key plus one of the function keys on you laptop which has a screen symbol. Pressing this key will toggle between the laptop screen, data projector or both laptop screen plus data projector.
You can open Power Point and select your presentation as you would normally.
Nov 14, 2010 | Computers & Internet
TravelMate 3270-6569 (LX.TH706.051) PC Notebook: My acer travelmate 3270 is connected to a sony dat...
Try holding down the Function key (Fn), then pressing F5. Wait a few seconds. On most laptop, each press of the F5 key will toggle between laptop display only, projector only and Dual (same image on both - my favorite).
You'll probably see a little Monitor-shaped icon on the F5 key. It's possible it's another function key - on Dells it's usually F8.
Aug 02, 2017 | Acer TravelMate 3270-6569 Notebook
My Epson EMP-S4 LCD projector does not display images from my Averatec C3500 laptop. It displays "No signal".. Do i have to press any keys before it would display? I suppose it would automatically project...
When you connect a data projector or external monitor to the external video port on the laptop, power up the data projector or external monitor first then the laptop. The video info will automatically divert to the data projector/external monitor automatically.
If you have already had powered up the laptop first, most laptops will allow you to toggle between the LCD screen and the external video port by pressing the Fn key plus one of the Function keys, this key will have a screen/laptop symbol.
Sep 08, 2009 | Averatec C3500 Tablet PC
Jul 24, 2009 | Sanyo PLV 60HT Multimedia Projector
I can't get the display from my laptop to project to a screen.
If you connect the data projector to your laptop and power it up first then your laptop, the video will switch to the data projector automatically.
If you had powered up the laptop first then you can divert the video information to the external video port/data projector by holding the Fn key and then press F4 key.
You can toggle between the LCD screen, the data projector or both LCD and data project together using the Fn & F4 keys.
May 25, 2009 | Compaq Computers & Internet
Need to see display on both laptop and projector
On most laptops pressing the Fn key plus the F5 key (in your model laptop) several times will cause the video to switch to different options
In the various laptops I've used with data projectors it is the same.
If you plug in the data projector and power it up then the laptop then the Windows image will be on the data projector (provided the laptop's screen resolution matches the data projector).
To toggle between the data projector only, the LCD screen, then LCD screen plus data projector, and or back through this sequence, just press the Fn key and the F5 key to get the displays you want .
May 20, 2009 | Toshiba Tecra M10 Notebook
I con't connect with lcd projector, xp windows
The video output will automatically switch to the data projector first when you power up the data projector first and then boot up the laptop.
When you power up the laptop first you can toggle the Windows image between the LCD screen and the video port/data projector by pressing the Fn key plus the F4 key. Pressing these keys each time will switch the display from LCD screen to video port only, to both LCD screen and video port, and back to LCD screen only.
May 14, 2009 | HP Compaq Presario V6000T Notebook
How to connect laptop to projector?
Data projectors have a video cable and you connect it to the 15pin blue video connector on the laptop. Then you power up the projector and then power up the laptop. The laptop should automatically dirvert the video information to the data projector.
If the image produced from the projector is not clear, then you will need to reduce the screen resolution on your laptop using Control Panel - Display - Settings.
Mar 30, 2009 | Fujitsu LifeBook A6110 Notebook
20 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
