Question about JVC RX-318 Receiver
So my receiver keeps displaying "overload" and has no sound output like when ever i put it on and try to turn the volume up it just makes a click sound and displays"overload"
simplemitch
  • 752 Answers
SOURCE: overload
No, one of your speakers is damaged (could be an amp channel went bad, but speaker is more likely). Unplug all spkrs, then plug one in and see if it acts normal when turned up. Repeat this until all speakers are hooked up or the culprit spkr is found.
Posted on Sep 25, 2007
  • 979 Answers
SOURCE: "OVERLOAD" APPEARS
Have a service shop check out your protection IC and related network...accordianman
Posted on Oct 25, 2007
SOURCE: overloading when volume is turned up
I have the same prob.
Posted on Nov 01, 2008
  • 5 Answers
SOURCE: The receiver shuts off after two minutes and
Your speakers are not properly connected. Be sure that red is with red, black is with black.
Posted on Dec 08, 2009
mlapres
  • 757 Answers
SOURCE: Overload keeps flashing
Remove anything that may be sitting on top of it, and give it at least 6" of clearance all the way around it to help dissipate heat and leave it that way
permanently.
Next check that the speakers you are using have a compatible Ohm rating for the receiver.
Posted on Dec 19, 2009
My technics receiver stop playing, and display an overload message. what do you believe the is the problem ?
If you are getting an overload problem, it indicates an output load issue. Turn receiver off! remove speaker wires from the back of the unit, this will reset the protection circuit. Now power up and turn your volume right down, If the word overload stays off it means there is a short in the wire or speaker. But! if the word overload comes on "even with the wires and speakers dis-connected" it indicates a short in one or more of the audio output ic's or transistors.
Mar 17, 2011 | Technics Audio Players & Recorders
Have recently had an "overload" displayed. Have
HI:
Usually receivers go into overload due to a bad speaker make sure you disconnect the speakers also to make sure its overloading from a bad speaker. If the unit still shows overload even with all speakers disconnected, then your main amplifier output has a short usually a shorted output transistor is the cause. Unplug the speakers one at a time to and turn the unit on after disconnecting one of the speakers , to determine which speaker is at fault.
Jan 23, 2011 | Panasonic SA-HE200 Receiver
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
It turns off when the volume is turned up over one third of the volume knob, but is the speakers don't interfere in any way
sounds like the protection circuit is the problem here which is a good thing because its stopping you from permantly damaging the unit first thing to check would be the impedance of your speakers and then check what your impedance selector is set to on the back assuming you have one be warned that you should never move this switch while the unit is on.My advice would be to unplug it first because that switch plays a direct role in the systems power supply..Hope this works for you
Oct 31, 2009 | Technics SA-AX540 Receiver
Overload issue
There is a problem in the front end that is allowing some DC curent to flow to the output section. This is detected and the amp goes into protect mode to prevent further damage to either the output section or the speakers. This is likely to be defective coupling capacitors and not an expensive repair. Figure on less than $20 for parts for this repair.
Dan
Oct 14, 2009 | Optimus STAV-3770 Receiver
VSX-D608 Overload and shutdown
Overload is displayed when the amp draw is excessive, and can be caused by different faults.
when Overload is detected, the protection circuit will shut down the unit to prevent further damage.
The first thing to try is hard reset. Shut down the unit for about one hour to drain power completely.
This can fix minor problems that can cause overload, for example electrostatic charge accumulation on internal capacitors.
If that does not fix the problem, then you must find the fault.
Overload can be caused by shorted speakers, wrong impedance speakers, or by a contact on speakers wiring.
Check speakers connection and test different speakers with 6, or better 8 Ohms impedance.
Another test can be done by unplugging all speakers, and reconnecting and testing them one at a time, at a very low volume.
No more than two 4 Ohms speakers can be connected to the unit, or you will get overload.
If the speakers are OK, then preamp, shorted input/output connectors, main power supply or faulty output transistors can draw too much amps causing overloading.
In that case it is recommendable contacting Pioneer at the number listed on the owners manual.
Jun 22, 2009 | Pioneer VSX-D608 Receiver
Technics SA-DA10 jumps into overload after 10 minutes
Have you tried connecting speakers? What was the result?
Yes, when you turn the volume up on these amps (or when the output gets past a certain level) the cooling fan should automatically come on.
Oct 14, 2008 | Technics SA-DA10 Receiver
Power on but no display on Denon AVR 3705
By now the folks who asked this have certainly solved their problem, but in case anyone else has this same question:
If the color change from red to green on the Power button indicator light and stays that way, the receiver is most likely working fine, it's just that your front-panel display is OFF.
1. Check the DIMMER mode by pusing the buttom on the front panel -- it may be set to OFF.
2. Push the PURE DIRECT button on the front panel (or remote control) -- it may be ON, which turns off almost all of the front-panel display. (Alternately, change the AV source, which turns Pure Direct OFF.)
HOWEVER if the power light flashes rapidly, the amp's overload protection circuit may have been triggered by a feedback loop or other problem, such as a shorted or bad cable connection. Turn off the power and unplug the receiver. Look for problems starting with shorted speaker wires or cables. Then make sure the receiver's not still hot (wait 5-10 minutes to let it cool), and remove obstructions or anything blocking the top vents. Plug it back in and power up again. Immediately change the Source selector to something unconnected, and turn the Volume DOWN just in case there's a feedback loop (hum/squeal/noise that can overload things and cause the protection circuit to trip again). If you can see the display, go to a low level (around -50dB should be fine) before the delayed speaker amp output clicks on. Then carefully switch back to the problem source -- if that's the problem, switch off again immediately and re-check all of the cable connections at both ends, the receiver and the source component, and make sure you don't have a feedback loop due to a recording device feeding back a signal. All VCRs and CD/DVD-recorders should be hooked up to the VCR, DVR or TAPE/CD-R "IN/OUT" jacks with IN being connected to the cables marked OUT on the deck and vice versa. (That confuses even us experienced guys sometimes!) Also, no MONITOR video or audio outputs should be connected to the recording decks, nor should the TV outputs be fed back to the recorders. The same goes for the digital IN/OUT jacks for CD recorders; use only the same number IN as OUT for each component (Optical IN/OUT #4 and #5 are the two digital IN/OUT pairs on the AVR-3803).
Jan 22, 2008 | Audio Players & Recorders
JVC RX-7000V
As per the instruction manual the overload is there because of high volume condidtions and your over heating the unit. They recomend to turn down the volume shut off the reciver wait a few minutes and turn back on the unit with lower volumes. Second it states that the peaker wires or speakers could be shorted so make sure the speakers are good and the wires when you connected them to the reciver are not shorted. If all is hooked up properly then you have a problem in the output stage of the amp and its gonna need service unless you know how to replace the defective output devices? If not Go online at the addy I give you to find about service parts or service manuals.. Good Luck http://www.jvcservice.com
Apr 23, 2006 | JVC RX-7000V Receiver
Sound stops
HHHMMM lets see kinow what could cause that??? Oh I know have you checked the B+ connections going to the stanby power as well as your always on wires?? Could also be a defective speaker or a wire touching in the car becaiuse as the volume rises the more voltage going to the speakers so the more of an overload on the out-put IC. The output IC could also bee defective. My money would be on a bad output ic or a bad speaker or wireing.
Apr 18, 2006 | Pioneer MEH-P5000 MiniDisc Player
JVC RX-318 Receiver Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
