Question about Gaggia Titanium Espresso Machine
Steam knob faulty
Steam knob will turn, but no steam comes from machine.
2 Suggested Answers
SOURCE: steam valve wont turn off - need new steam valve
Go to http://www.partsguru.com/GaggiaHomeEspressoMakers.html and order it from them. They have great service and you have the parts in days.
Posted on Jun 25, 2009
How do I get steam from my new bar 32?
It may take a few moments to come through.. if you can't hear the pump operating, it may indicate the unit is faulty..
May 10, 2014 | DeLonghi Coffee Makers & Espresso Machines
The axis connecting the steam knob and the machine seems snapped
If you get the machine upside down (switched off) you will find a hole near the steam knob which allows access to a screw. Turn this screw with a flat bladed screwdriver and the knob will come off. this may allow you to see what's wrong. The machine is stongly built so it seems unlikely that it has snapped.
Nov 25, 2013 | FrancisFrancis! X1 - Stainless Steel...
Gaggia classic steam knob
Have you turned the steam valve off tightly and cracked the knob inside allowing it to turn on the brass spindle.Try pulling the knob off and turning the spindle with a pair of pliers or a small adjustable spanner.If the spindle keeps turning you may have sheared the spindle off inside.If this is the case you will need a new steam valve complete as they are not repairable.Steam valve cost about 35
Tools required 5 mm alan key and 17 mm spanner for steam pipe
Jun 16, 2012 | Gaggia Classic Espresso Machine
My Titanium leaking water. Under it
The steam valve assembly that the steam knob on the right hand side connects into is probably faulty. When you're steaming if you hear hissing coming from behind the knob then this indicates the connections into this assembly are leaking steam, and also hot water, which is why you're getting puddles under the machine. You can get a replacement steam valve assembly that fixes some issues with the original (part code SVM-17, available from www.partsguru.com) and will prevent the leakage, or you could simply try opening the top of the coffee machine and removing the tube that runs from the boiler into the steam valve. It has two o-rings that provide the seal where it connects into the steam valve assembly, and if you lubricate these with a food grade silicon lubricant it may fix the problem. My Gaggia is 7 years old so I decided to replace the whole assembly which costs about $50 and that solved the problem completely.
Apr 04, 2011 | Gaggia Titanium Espresso Machine
With the steam spout turned on, no steam is ejected, alarm light
Does water comes out when turn on the knob? If it is, try making steam, it should come out also. Make sure the knob is turned fully.Probably the seals in the valve is jamming and preventing the knob to turn fully.
Apr 14, 2010 | Saeco Odea Go
Gaggia syncrony compact is leaking. Removed top and it appears it is leaking from the area that the line goes into the steam knob. Doesn't leak when using the steam knob, just when brew coffee
Hi What color is the steam manifold? It is located under the black cover with the trough in back under the whit tube. If its whit or black it probably needs to be replaced. If you cool down the manifold after steaming you can prevent this from happening. Just turn off the steam and then open the knob again to run water. It comes out steam at first but then will turn to a water stream. Then you can close the knob and go about brewing or just let it stand.
Jun 14, 2009 | Gaggia Syncrony Compact Coffee...
Installed new ulka vibrating pump in my Rocket E61 (Giotto) but the pump won't prime.
If when you installed the new pump and turned it on and made loud vibrating sound but not pumping any water through what you need to do is when you turn the pump on open up your steam valve turning the steam knob. Usually it is just an air lock and this should allow the air out and water to flow through. When water comes out of the steam arm, close it off and water should then come out the group head as normal. If you try this and nothing happens you either have a build up of scale which you just need to try to flush a good descaler (Puly Baby Powder) through your machine or the pump you got is faulty.
All the best
LaPavoniBoy
Jun 10, 2009 | ECM Giotto Espresso Machine
Saeco Magic Comfort Plus still producing steam in "off" position.
This may be something you can fix. It depends on your comfort level with mechanical repairs. You probably need to replace some o-rings in the steam valve. Don't keep trying to brew or steam because leaking water or steam inside may cause an electrical short. Decide if you want to delve into the repair, or locate a repair center near you. I could put you in touch with some.
Mar 18, 2009 | Saeco Magic Comfort Plus Espresso Machine
Just bought the Saecco Incanto s-class de luxe machine
lol there is a water button on it. Press that first and than turn the steam knob
Mar 19, 2008 | Saeco Incanto Classic Espresso Machine
Pavoni, no steam from steam wand
i havent heard of this issue , it could posibly be the bent steam wand , but the nozle is made to be that way, because the pavoni eurpicola doesnt produce enough steam pressure , it enables you to create better froth
Oct 25, 2007 | La Pavoni PC-16 Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
13 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
