Sony 3 cd changer model no . is MHC-GNZ88D when i on the dvd player please wait come for around 1- 1.2 minutes and then the code c 31 00 comes, please give me the solution ?
Sony MHC-GNZ88D SHOWING CODE C 31 00 , WHEN IT ON THE DVD PLEASE WAIT COMES ON THE SCRENN FOR ABOUT 2 MIN. THEN THE CODE COME C 31 00 PLEASE PROVIDE A SOLUTION.
SOURCE: LG DR-4810 DVD Displays " PLEASE WAIT"
C113 10v 1000uF cap off an XFRMR in power supply board. Cooked and gone high esr. Replace with a 16v.
Posted on Nov 26, 2007
  • 4 Answers
SOURCE: disc tray 1 is blinking with 2 ovals around it, tray not in right Panasonic SA-HT680
I had a jammed disc that was causing this same error message. To remove the jammed disc, remove the top by removing the screws and then you can remove the stuck/jammed discs. For the Panasonic SC-PT750 there are 7 screws, three small silver ones on the back, then 4 black ones, two on each side, all philips head. Once you have that off, gently pry it off starting from the back, the cover is actually hinged into the front plastic piece of the player.
Posted on Dec 31, 2007
SOURCE: Panasonic SA-HT692
Thanks for your help, but I couldn't wait any longer and took care of the problem. This is what I did to fix it: With the dvd player unplugged, I removed all the screws and opened up the dvd player to make sure that there was no dvd stuck inside. Once I confirmed that there were no obstructions, I then proceeded to plug in the dvd player so I can see how the player reacted to the error messages. I noticed that every time I pressed the eject button, the section where the sensor reads the disc was slightly moving but not fully reacting. So right above the laser sensor apparatus, there's a white plastic circular piece and I moved that around a few times and it did the trick. Problem solve, the dvd player is working like a champ. Hope this helps if someone out there that has the same problem.
Posted on Feb 13, 2008
  • 1019 Answers
SOURCE: region code
I have a region Code For A Philips HTS-3544 which is 1 model Down. You can try it, it may work or it May Not.
Heres How:- power on the TV/DVD without any disk in the player.Press open/close eject.
Press Stop 7.3.4.4.6.6 ( on the Remote )
The menu code appears On The Screen.
Press 0 for region Free, or the region Code Required.
Power Off and then on Again, if the codes have worked, your dvd player is now region free.
If this works please rate as Fixya.
many thanks mike @ Compurepair.
Posted on Aug 28, 2008
SOURCE: SONY DAV-DZ720
you are stupid for asking me how i did it, did you give me solution, nonsense.
i hate you all.
Posted on Sep 05, 2008
What are the available subwoofers for sony mhc-gnz88d
you need 'line level input .. left and right'
front speaker to subwoofer input = subwoofer works + speaker outputs Use The ( Wharfedale SPC-8 Active Sub)
Sep 02, 2017 | Sony Audio Players & Recorders
Mini hifi sony MHC-GZR5D the disk port is not opening and USB not responding.. A message saying (please wait) always shown on the screen , what I must do?
Try unpluging the power then wait thirty seconds then plug it back in. I have a feeling there is a disk stuck in it.
Terry
Mar 29, 2014 | Sony MHC-GZR5D MINI HI-FI SYSTEM FOR...
I have Sony mhc-gzr5d tuner is working normally but DVD and USB not responding, I have a (please wait) message always on the screen..
Why are you posting this so many times?
Terry
http://www.fixya.com/answer/answerpageslideview.aspx?ctg=186&fml=0&brd=0&p=3&thid=23934199
MHC-GN1300D Video
I need to unlock a Sony mhc 1300D mini hi fi component , make it to play all the region
Oct 24, 2012 | Sony Mhc-gn1300d 3 Dvd/vcd/cd Changer...
I have sony mini hi-fi mhc-gnz88d now it's displaying DEST ERROR and can't open disk tray or run a CD. how to solve this?
i hv also this problem from yestrday.. all function are ok. bt when playing dvd ... there is 'please wait'error long time. and also tray not open after pressing open or exchange cd also... whats problem.. please help me.. waiting
Dec 25, 2010 | Sony Televison & Video
the dest fault is telling you that the motor drive that opens the door is burned out or the power supply circuits to the motor is faulted the unit will have to go to a service tech to have the motor of power sorce to it repaired should cost you around $60
merry christmas
please take time to rate this advice
thank you
Dec 25, 2010 | Televison & Video
Sony dvd player mhc-gn1200d is the model. placed cd inside then a message appears "please wait" but nothing is happening. umplugged and plugged it, same message appears and cd tray won't open. what will I...
Sounds like you'll have to use the manual release to open the tray.
Turn the unit off.
There should be a small hole just under the tray, unbend a paper clip and push it in the hole, the tray will come out part way, it can then be pulled out by hand to retreive your cd.
Reclose the tray and turn on the unit. If it now functions normally, the problem was most likely the cd, but I would still use a laser cleaning disc just to make sure the lens is clean.
Oct 03, 2010 | Sony Televison & Video
I have a Dvd stuck in the CD changer in disc 1. It won't eject. How can I get it out.
on the front face of the dvd is a tiny hole which you slide in a rod or pin which releases the locking catch
Jul 05, 2010 | Bose Wave music system Multi-CD Changer...
24 people viewed this question
 Grubhead
Grubhead
