Question about Konica Minolta Office Equipment & Supplies
Defaulting to other tray when paper runs out - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,674 Answers
5 Suggested Answers
mdsaeed67
  • 849 Answers
SOURCE: My kyocera printer has two
go to installed printer location, right click on your installed printer, click on properties you will find the paper source there and change it accordingly.
Posted on Oct 21, 2008
  • 240 Answers
SOURCE: default paper tray selection for HP LaserJet 4200tn
1) When the printer receives a print job, it selects the tray by trying to match the requested paper type and size with what has been loaded in the trays. Using an “autoselect” process, it searches all available trays for the paper that satisfies the request, starting with the bottom tray and ending with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/size.
2) If paper is loaded in tray 1 and tray 1 is set "TRAY 1 TYPE=ANY" and "TRAY 1 SIZE=ANY" on the
Paper Handling menu, the printer will always pull paper from tray 1 first.
Posted on Dec 10, 2009
vinay229229
  • 1121 Answers
SOURCE: Changing Paper trays on HP2430dtn printer
Press menu button, scroll to tray behavior, in that select type of paper, default tray & paper size etc..
Posted on Feb 02, 2012
SOURCE: AR-M207 default paper tray for fax
tamashebi http://chemitamashebi.do.am/
Posted on Feb 09, 2012
Why when I select Glossy in the print settings, the print shifts?
Run this paper from the bypass tray located on the right hand side of the machine.
Try setting that paper type on the copier itself.
Load the paper. Go to the manual paper tray select screen. Select tray 1 and then change paper settings.
Glossy paper also tends to slip in these machines when the paper tray rollers are bad.
Oct 29, 2014 | Konica Minolta Office Equipment & Supplies
How do I change the default on my HP P30005dn to Tray 2?
Normal default on HP is tray 2, however if you do not have that tray set for plain paper letter size the printer will default to whichever tray has letter plain paper installed. You should also check your print driver default settings to ensure that tray 2 is set as default tray.
Aug 14, 2014 | HP LaserJet P3005dn Printer
Feb 02, 2012 | HP LaserJet 2430dtn Printer
Canon Imagerunner 3230 - The Default Settings for Paper Source are set to pull paper from the side feeder tray instead of Auto when printing EMAILS (only). Everything else prints fine (the paper is pulled...
If you go to the printer properties before you send it to print you should be able to choose which tray to print from. Or you can set the default tray in the print driver and then apply it to set it in as default.
Jan 29, 2018 | Canon Office Equipment & Supplies
Colour laserjet HP cp2025 keeps going into cleaning mode - why ?
Re: CP2025 cleaning at every possible moment Talked to HP support and fixed mine by changing Settings/Paper Handling/Tray 2 Type to "Heavy 111-130g"
All paper handling settings as follows:
Default Paper Size: Letter
Default Paper Type: Plain
Manual Feed: Off Duplex: Off Bind: Long Edge
Tray 1 Size: Any size Tray 1 Type: Any Type Tray 2 Size: Letter Tray 2 Type: Heavy 111-130g
Paper Out Handling
Specify Time and Action Paper Out Time: 0 Seconds
Paper Out Action:
Override
Apr 17, 2010 | HP Color LaserJet 2600n Printer
Default paper tray selection for HP LaserJet 4200tn
Dec 09, 2009 | HP LaserJet 4200 Printer
Want to print on legal size paper from Tray 1 (top) as default
print menu - config and verify paper is being sensed correctly. If paper size in tray is not set correctly printer will ask where to print from
Feb 12, 2009 | Lexmark T640 Laser Printer
push"special function" button, then select "key op prg", then "ok", then enter pin (default is 00000), then select "fax", then "ok", then select "rcv function", then "ok", then "tray selection", then "ok". The rest you should be able to follow your nose.
Feb 06, 2009 | Sharp AR-M207 All-In-One Laser Printer
Paper tray?
Two possible solutions;
1) Check the settings in the printer driver for the default tray. The other user could very well have changed them and set tray 1 as the default tray.
2) Check the paper size settings in the paper tray. Pull tray 2 out and check the paper guides. Make sure the paper guide in the front and left of the paper tray are set for the correct media type (letter, legal, etc.)
The printer reads the tabs in the back of the papertray to identify the paper size. If someone moved it while loading paper the printer identifies another paper size and defaults into the tray that has the size of paper required to print.
Hope this solves your problem.
Nov 19, 2008 | HP LaserJet 4100n Printer
My kyocera printer has two input trays with different stationary. The problem occurs when tray 1 runs out of paper, it defaults to tray 2, thus using the wrong stationary. How can i disable TRAY 1 from...
Oct 21, 2008 | Kyocera Office Equipment & Supplies
19 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
