Question about Brother MFC-8660DN 5-in-1 Laser Multifunctional Printer
How to solve scanner locked problem in brother machine MFC 8460n
4 Suggested Answers
SOURCE: document jam brother mfc 8460n
if the message refers to the scanner, open the cover of the feeding unit on top of the printer and clean it with compressed air. Most probably an insect got stuck somewhere
Posted on Nov 07, 2008
Jimsta01
  • 405 Answers
SOURCE: how to connect my brother mfc-8460N scanner can't
You will need to use a cable to use the scanner.
Either a USB cable to connect directly to computer or an ethernet cable directly to router, then you will need to install the driver software.
Posted on Mar 30, 2010
Jimsta01
  • 405 Answers
SOURCE: Brother MFC-8460N network printing, local scanning
Yes this is possible. Depending on the type of installation that has been done on the computer, you can even scan documents to your computer as a network scanner.
You can check and see if all the features have been installed on your computer. Click on start, all programs, and look for the folder called brother. If you can find brother you can look for the sub category for Conrtrol Center. From Control Center you can scan by clicking on one of the icons. Like file or image.
If none of this is installed, get your installation disk and install the software, you can do a network installation or a Local (USB) installation.
If you decide to do a Local installtion remember to only plug in the USB cable when promted to.
If you decide to do a network installation, the machine should already be installed on the network, which I assume it is since its being used as a network Printer.
Please let me know if any of this info was usefull, and if you require more info about this.
Posted on Apr 12, 2010
I need a manual
HI,you can download the manual from the below link..
http://www.manualowl.com/p/Brother%20International/MFC-8460n/Manual/42499
Click on the user's manual and download...
Jun 27, 2011 | Brother MFC-8460N All-In-One Printer
Apr 12, 2010 | Brother MFC-8460N All-In-One Printer
How to connect my brother mfc-8460N scanner can't
Nov 12, 2009 | Brother MFC-8460N All-In-One Printer
How to program brother mfc 8460n to print confirmation sheets for when a fax is sent.thanks
Press 'Menu', '2', '4', '1'. Report Setting is displayed. Press down arrow to select "on + image". Press 'OK'. Press 'Stop/Exit'. Reference page 70 in this link to MFC 8460n on the Brother site.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_8460N_8660DN_8670DN_8860DN_8870DW_EN_1586.PDF
Nov 04, 2009 | Canon LaserClass 9000L Plain Paper Fax
Brother MFC8460N was working great and now today the scanner won't work. Printer and fax work fine. When I try to scan I get the message "MFC-8460N cannot be found. Please make sure your device is ON and...
Try re-installing the scanner software - if you don't have the disc you can download it. The scanner is a very delicate mechanism so is easily damaged - if the software fix don't work maybe it is kaput
Oct 03, 2017 | Brother MFC-8460N All-In-One Printer
Hi , My 4 in one printer get message Paper jam. MFC-8460N MFC-8460N
hello! i need to know where the jam is so that i may help you. brother tech
Jan 21, 2009 | Brother MFC-8460N All-In-One Printer
Brother MFC 8460
Hi
There must still be a piece of paper in the machine check the fuser section at the rear of the machine maybe be piece there or check at the paper cassette area remove cassette and check that the paper hasn't got jammed as it feeds through.
Thanks
Dec 29, 2008 | Brother MFC-8460N All-In-One Printer
Document jam brother mfc 8460n
you cannot clear this unless there is still a presence of paper inside the machine.
or you can open and close your machine once you are cleared of any paper jammed, be sure not to leave and removed all residual paper in the paper path, the tiny sensor would recognize any sort of this and thus make your machine unoperable.
Jul 25, 2008 | Brother MFC-8460N All-In-One Printer
MFC 8460N giving Toner Life End message
I just solved my own problem. Try it for yours. I had been using several compatible toners for the MFC-8460N with no problems until today, as I posted earlier. On a hunch, I went to the local office supply store and purchased one original Brothers TN550 toner and put it into the printer and closed the cover. Everything clicked. Toner End Life message gone. I then took that Brother toner out and put the compatible one back in and still everything was fine. Am keeping the original Brother toner as a "kickstarter" if it happens again.
Mar 10, 2008 | Brother MFC-8460N Laser Printer
Brother MFC-8660DN 5-in-1 Laser Multifunctional Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
