Question about Duo Fast DuoFast DF350S 20? Round Head Framing Nailer
How to fix stuck drive pin? - Duo Fast DuoFast DF350S 20? Round Head Framing Nailer
Cd drawers won't open, may have cd stuck in #1 slot
How to Fix a stuck CD Tray - YouTube
? 6:24
https://www.youtube.com/watch?v=gpvjqATX3Rs
Mar 24, 2010 - Uploaded by Guy Techie
Pin won't open my tray :( Help please?. Read more ... I was lucky to find a rubber band in my junk drawer and it ...
When a CD or DVD is stuck or the drive won't open ' PCWorld
Dec 09, 2015 | Audio Players & Recorders
Tip
Cdrom drive can not eject / Cdrom is stuck
How To Eject CD from CD-ROM drive if it is Stuck :
If you have a CD into CD-ROM drive and it is stuck and you are trying to eject tray of CDROM by pressing the eject button or windows eject command but CD won't eject as there is no command to eject a stuck compact disc from the CDROM drive then this article is for you.
Step 1: Switch off the computer.
5573fa0.jpgStep 2. On the front of the CD-ROM drive you may find a small hole called Emergency Eject hole below the tray of CD-ROM drive . Take a long pin around 3 inch, (also known as CD ejector) it must be hard enough, insert this pin inside the hole and push a little. The CD tray will slightly move to out.
Step 3: Now you may manually pull the tray and you are done. You have successfully ejected the stucked CD.
Step 4: Switch on the computer and you may work as usual.
Thanks
Proton
on May 12, 2010 | Computers & Internet
A disc is stuck in my dell laptop
Please provide the model number. Also, assuming you're talking about a CD stuck in the drive. There should be a tiny pin hole on the CD/DVD drive bezel. Unplug laptop and remove battery. Then stick a tiny pin in that hole -- should release the catch that keeps the optical drive bay closed. You can then open the drive and remove the disc.
Nov 08, 2014 | Dell Inspiron Computers & Internet
After changing the ignition in my 1991 chevy 1500 truck i started the car and put it into drive and all the sudden its stuck in drive. The shifter moves freely but had to put on parking break do to the...
colum shifter rod is under the hood at the firewall.. look and see if the rod popped off of the shift arm.. gms do this when the rubber grommet wears out there..the shift arm rod.. pin and all will pop off..find a washer that will fit over the rod once it gets put back in place and put a new pin in it....floor shifter is under the cab.. look for the linkage rod hanging down..reconnect it to the shifter same fix..different location..
Dec 09, 2013 | Cars & Trucks
Eject button stuck
Near the eject button (on the same face as the eject button) there should be a pin hole. Use a straigtened paper clip to force the ejection of a stuck disk. It may also work even without a disk stuck. ( I just tried it on the drive of the laptop.)
Oct 14, 2013 | ASUS Computers & Internet
How to fix a pushed in eject button on a cd drive?- Dell Inspiron 1545 Laptop
Might have a stuck disc. Use a straightened paper clip in small pin hole of the CD drive to manually eject.
Nov 21, 2012 | Dell Inspiron 1545 Notebook
Disc did not come back out on disc player
Do you mean your disc is stuck in the drive?
If so Look at the drive there should be a tiny pin hole near the eject button, insert a needle (safety pin, sewing, etc.) into the pin hole and push this opens the drive.
You can also try opening my computer and right clicking the DVD drive and select eject.
Jan 19, 2010 | Dell SideBay/Fixed Bay DVD+CDRW Combo...
The tray does not open
Hello
Do you know if there might be a cd stuck in the trey, if so, here is hoe you fix this.
Take a pin and push it into the small hole near the eject button. Push it in until you feel a resistance to movement of the pin, while doing this, gently pull out the try.
If there is no cd stuck in the player, the problem is the little rubber band which drives out the trey. If this is the problem, you should hear a noise if you press the eject button. It is really cheap to fix. Hope this can help you.
Best regards
Andrea
Nov 03, 2009 | Philips MX6050D System
I have a CD stuck inside of a CD drive. (vertical)
What you should do is get a pin that will fit in the small hole of the of the CD drive of your computer and insert it until it seems to push out the tray and then pull it out. Hope this could help.. Thanks..
Oct 23, 2009 | Computers & Internet
Emachines w3609
It was better if you have specified the brand of the cd drive. However the following would fix your problem.
1. If you have noticed earlier , check for a small hole ( the size of a pin ) on the front of the cd drive just below the tray which opens. depending upon the brand of the cd the whole might be located anywhere ( below or above, right or left corner ).
2. Having located the hole. Get yourself a Pin or a Safety Pin or a copper wire. Insert the pin or the wire inside the hole which will release the clamp inside and now manually try to pull the Cd drive with your finger nails..
You are done.
Hope to get rated as fixed.
Regards
Bzoy...
Dec 31, 2007 | Computers & Internet
Duo Fast DuoFast DF350S 20? Round Head Framing Nailer Logo
37 people viewed this question
Top Duo Fast Air Tools & Compressors Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
yoopertech
Are you a Duo Fast Air Tool and Compressor Expert? Answer questions, earn points and help others
