Question about Hardware & Accessories
Westinghouse sist1970 Clock not working no lights on at all do I to set it or does this have a fuse
2 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Setting clock on Westinghouse WST3501 microwave oven
Normally you would press Clock, enter the desired numbers, then hit Clock or Start. Try it with door open and with door closed.
Otherwise, contact Westinghouse Small Kitchen Appliances at 800-947-3745 or see http://www.saltoninc.com/contact/contact.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 13, 2007
How do i set the clock on my westinghouse 627 oven?
Press clock button use the + - buttons to change it then press clock again
Jan 25, 2016 | Ovens
Westinghouse WST3501, how to setup it's clock?
push clock button set time with numbers then press clock button again .
Dec 03, 2014 | Westinghouse Microwave Ovens
I have just moved into a new house with but i can't get the westinghouse PHL768U oven to work. I need help in setting controls like time etc. I havent got any manual. Please help
Chances are, its been turned off and you have had the power turned back on... I found this out as well, that you need to 'acknowledge' the stove... press the centre button by the clock display, and this should beep.. you should then be able to have the elements turn on, and if you want, set the clock.. See the display, and there will be a small red light, that bounces round from corner to corner when you press the Mode button. ie, if the red light is next to Clock, then you can adjust the clock time etc etc.. hope this helps.. otherwise, we also had to find the Range Power switch going to the stovetop...
Jan 28, 2011 | Ovens
I have a Heavy Duty Westinghouse 3-Outlet Outdoor Digital Photocell Timer and the time keeps running slow. Does the unit need sunlight to run the clock or do I need to change the internal battery? I have...
1) No the timer has internal rechargeable battery.
Battery is not replaceable.
2) I test timers, 4-6% arrive defective. Most go bad within few years. Some last long time.
3) If you set timer to turn ON at dusk, and turn OFF 2 hours later, then reflected light or car lights can give photoeye feedback so timer thinks it's light. Timer turns off and resets. I don't know if this information applies to you.
4) Link shows timer and manual for Westinghouse
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-week
5) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any
do-it-yourself project.
Jan 13, 2011 | Heavy Duty Westinghouse 3-Outlet Outdoor ...
Westinghouse oven GWH 476 SLP Multifunction. The pilot cones on but not igniting ? no gas getting through
Hi RMSINN,
Believe it or not, the clock has to be set before the oven will light.
To set the clock, instead of using function names for buttons, we'll just call them buttons 1 through 6 going from left to right.
Push buttons 1 and 2 at the same time. You're now in clock setting mode. Push buttons 5 and 6 to make the clock go minus and plus.
Cheers
SG
Sep 21, 2010 | Ovens
Westinghouse microwave WST3502..... Problem:
Press "Clock", type in the time on the keypad and then press "Start". The clock runs a little slow (at least on mine) and I have to reset it about once a month. It gets about 10 - 15 minutes behind after awhile.
Sep 06, 2008 | Westinghouse WST3501 Microwave Oven
Dec 10, 2007 | Westinghouse WST3504 Microwave Oven
Westinghouse self cleaning oven manual or owners manual
Many White-Westinghouse manuals can be found here: http://www.frigidaire.com/support/manuals.asp I had the same problem and was able to solve it. They didn't have the exact manual for mine (a KF450G), but they had one that was similar enough (KF580H) to solve this issue. Setting the knobs to clean is only part of the process, to get it to run you need to set the timer. Read the key information below transcribed from the manual: --- To set the controls for the cleaning cycle: 1) Close the oven door. 2) Be sure the clock shows the correct time of day. 3) Be sure the Start Time knob is set for the same time as the clock. If not, turn the knob to the time on the clock. The knob will then pop out. 4) Push in and set the Stop Time knob for 2 to 3 hours past the Start Time. Example: If the Start Time and Clock read 1:00, set the Stop Time for 3:00 or 4:00. 5) Turn the Temperature Control to CLEAN. 6) Turn the Selector to CLEAN. If all controls are set correctly, the oven signal light will come on and stay on until the oven reaches its cleaning temperature. It will then cycle on and off. --- There is more information in the manual, but it's much too much information to manually transcribe - I've only typed enough for you to get it working. Note that the LOCKED light won't light initially, it only lights once the oven exceeds 550 degrees. Once that light is on, the oven will not reopen until the temperature drops below that point, even if you stop the clean cycle. Be sure to empty out the storage drawer under the oven before cleaning.
Dec 08, 2007 | Kitchen Ranges
Clock
Nov 21, 2007 | Westinghouse WST3501 Microwave Oven
Hardware & Accessories Logo
19 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
