Question about Pacific Image ImageBox 9Mp Standalone Scanner
Imagebox 9mp standalone scanner has bright spot in the middle of picture
When scanning pictures, there is a bright spot in the middle of the picture. This device worked fine for awhile, but not has a bright spot in the middle on all the pictures.
I cannot get the scanner to turn on
is the green led light on in the front panel?
Jan 29, 2014 | Pacific Image ImageBox 9Mp Standalone...
Photos I take with this phone have weird garbled spots in the corners and sometimes in the middle, and pictures also are very bright (not just the phones I take with the phone but those too)
In the camera options of your phone find the one that says ISO. ISO, in short words, is the sensitivity to light. When set to a higher value, pictures may appear too bright or show weird specs or artifacts. Ideally you should dial this up when in dark conditions and leave it at 100 (or the middle in the gauge of your phone) when light is optimal.
Cheers.
Nov 14, 2013 | Motorola Mobility Moto X
Bright Spot
A fixed blue area on screen may be a display panel (main screen unit)
Here is a link for the boards etc this set uses--take your pick:
http://www.shopjimmy.com/sceptre-x460bv-f120
May 17, 2012 | Sceptre 46 X460BVF120 LCD TV
When I am scanning negatives, and try to save my scan to a file on my computer, it sounds like something is stuck and when the picture is finally saved, the middle of it is blank or shows rainbow-like wavy...
There is usually a locking lever on the bottom of the scanner to lock the mechanism during shipping or transport. Make sure that lever is fully in the unlocked position!
Oct 22, 2010 | HP ScanJet 3970 Flatbed Scanner
Hen I scan a picture on my brookstone iconvert scanner there are white lines through the middle of the picture. Already tried recalibrating and cleaning.
Jun 12, 2010 | Office Equipment & Supplies
White spots on scanned pictures. how to fix?
better change the glass of your scanner to avoid this problem in thw future and one more thing when ever you are not using the scanner put a soft cloth over glass and cover it or put a A4 size paper it will avoid dust and scratch try this
Jun 05, 2010 | HP Photosmart C5180 All-In-One InkJet...
Hi I can scan documents when I click on control panel/scanner...all documents scan to picasso. When I press the scan button on printer I want to be able to have documents scanned to word. Please advise
You need to get the HP Scangear manager. or use Scan to word or scantoPDF software download from 'net, if you have installed it correctly, you go to Word go to INSERT, go to INSERT Picture, Image, and select scanner and scan. OR scan to clipboard and paste into Word.
First make sure you have installed ALL the HP software.
Get Vuescan, it's a great standalone program, that doesn't require a driver, and just works. There are other scanning softwares too Google for them
Apr 01, 2010 | HP PSC 1350 All-In-One Thermal Printer
Bad contrast with scanner
Last things first: NO USER SERVICEABLE PARTS INSIDE.
That's the way HP does things. There are no rheostats or pots to adjust. It's all done electronically now, with chips and things.
You never said how it does with color or greyscale photos or drawings.
As for the RGB=(64,64,64), that's about right for the scan picture settings and the mixed (text and graphics) setting, and is particularly true for color picture settings. Have you tried using the setting for drawings (or line art), specifically greyscale drawings? Usually the greyscale lineart or drawing setting will render black text. You might also try scanning with the settings set for Text. If the greyscale drawing settings or greyscale text settings do not produce black text, try reinstalling your software and drivers.
If the contrast stays the same for all settings after reinstalling the software and drivers, and if it doesn't scan color and greyscale pictures correctly, then it sounds like your scanner is going bad.
As for the scans you've already done, you can darken the text by taking it into a photo editor, such as Paint Shop Pro or Photo Shop, and adjust the contrast and brightness to get the effect you desire.
Apr 18, 2009 | HP Scanjet 8250 Flatbed Scanner
Yellow Scanning--Trying to scan a color picture
first thing is to make sure the glass and the white backing on the lid is VERY clean.
then go to this link to trouble shoot --
http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&dlc=en&cc=us&product=2512008&lang=en&
Dec 25, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
FIne art scanning - uneven color across scans especially at edge of bed
The problem is going to be with the bulb itself. The scaner you are using is not made to do such precise work. The bulb itself is undersized for such a large scale job. You can look into upgrading the bulb of your scanner but I would not sudgest it unless you go to an authorized dealer/maint contractor for your Microtek to find the proper upgrade.
Apr 28, 2008 | Microtek ScanMaker 9800XL Flatbed Scanner
Pacific Image ImageBox 9Mp Standalone Scanner Logo
Top Pacific Image Computers & Internet Experts
David Payne
David Payne
Are you a Pacific Image Computer and Internet Expert? Answer questions, earn points and help others
